Welding Table
I’ve always wanted one of those bad ass welding tables you see in super high-end fabrication shops. I figured they were… well, fabricated by the folks that use them. Apparently, that’s not always the case. The above is Strong Hand Tool’s BuildPro Welding table. It features a top of ground-steel 5/8″-thick plates that feature CNC-machined 5/8″ through-holes spaced in a grid every 2″ apart.  The table is flat to within 0.004” per foot and the hole spacing is accurate to ±0.0015″. The whole damn thing weighs close to 600 pounds and will set ya back over $2000.
Ouch.
Max out your credit card here.
(25) Comments on the forum.
Plastic Bins
Plastic Bins
