Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-14-2012, 10:57 AM   #1
Ryan
Administrator
Ryan's Avatar
Default Woodcraft
Here's an interesting alternative to your trusty pencil. Essentially, Woodcraft is a 3d environment that you install on your iPad - allowing you to plan projects before you start them. I've tried it... It's pretty easy to understand and use, but it d...
Ryan is offline   Reply With Quote
Old 02-14-2012, 11:28 AM   #2
Toolbag
Toolbag's Avatar
Default Re: Woodcraft
Wow that's pretty cool!
Toolbag is offline   Reply With Quote
Old 02-14-2012, 11:38 AM   #3
Falcon67
Senior Member
Falcon67's Avatar
Some other handy stuff out there - search turned up Carpenter Cut. $10, not cheap. Put your plywood cuts from a 4x8 sheet in it and the app will gen a cut layout for the sheet.
Falcon67 is offline   Reply With Quote
Old 02-14-2012, 07:51 PM   #4
david594
Makes me wish I owned an iPad. Temped to get it to try it out on the iphone though.
david594 is offline   Reply With Quote
Old 02-15-2012, 08:38 AM   #5
DekeT
Senior Member
I am surprised the chopsaw operator still has a thumb. Do people actually do that?
DekeT is offline   Reply With Quote
Old 02-15-2012, 12:46 PM   #6
Sarbatche
Junior Member
Sarbatche's Avatar
The machining industry has been crying for a tool like that since the first iPad was just a rumor. Of course, we'd like it use different materials than wood and dimension things like tapped holes, bevels, etc... Then ultimately be able to port directly to a CNC machine.
Very cool app, but I'm not sure that it would more efficient than just pencil, paper, and calculator.
Sarbatche is offline   Reply With Quote
Old 02-15-2012, 07:09 PM   #7
Velbain
Junior Member
Velbain's Avatar
Thumbs up Re: Woodcraft
Ouarf,
Quote:
iPad is already obsolete, that are tools of future :
Velbain is offline   Reply With Quote
Old 02-17-2012, 09:42 AM   #8
oberst
Quote:
Originally Posted by Velbain View Post
Ouarf,
For the whole luddite experience, you should throw away that calculator and get a slide rule.
oberst is offline   Reply With Quote
Old 02-17-2012, 10:29 AM   #9
porphyre
heh. I've got a TI-83 Plus.
porphyre is offline   Reply With Quote
Old 02-17-2012, 02:26 PM   #10
NitroPress
Senior Member
NitroPress's Avatar
Quote:
Why? I already have four or five - the rolls royce of slipsticks, K+E Log Log Duplex Decitrigs. Six inch, ten inch and twenty inch models, with some backups.
__________________
Si Opus Quadratum vis, angulos praecidere noli.
Admiring your chains doesn't make you free. Go Renegade!
NitroPress is offline   Reply With Quote
Old 02-18-2012, 11:12 AM   #11
trojandj
Junior Member
I took a look at this and it is nice if you have trouble visualizing objects in 3D. It allowed me to "use" the piece I wanted to make it for a little while and then make modifications.
Thought I would share the mobile wood cart I had planned with you guys. I have been lurking here long enough. Take a look at Doug's Mobile Wood Cart in the woodcraft galleries if you are looking for a place to start. I did add a 2x4 on the top of each side after uploading the plans.
trojandj is offline   Reply With Quote
Old 02-18-2012, 11:37 AM   #12
NitroPress
Senior Member
NitroPress's Avatar
Quote:
I haven't built much of anything in the last few years without drawing at least some working plans in CAD. You make all your mistakes and work through all the options in empty space and then can build the widget the right way - concentrating on the work and the finish instead of on details like strut lengths or hole placement.
Most recent thing was a heavy-duty tripod trolley that I wanted to fold - I could work out the folding leg pivot points to the fraction, so when I built it, they fold precisely flat against the others. It was meant to be a quick fill-in project but I've carried it on several location shoots and it always gets comments and compliments. Fun.
So yeah, I recommend even a simple sketchup or CAD program as a tool to start projects. Time to master the basics will pay off over and over.
__________________
Old 02-19-2012, 10:01 AM   #13
aroncornell
Senior Member
Holy cow that guys thumb is pretty close to the blade.
aroncornell is offline   Reply With Quote
Old 02-19-2012, 09:18 PM   #14
Alfster
Junior Member
Quote:
Too close for my liking.....
Alfster is offline   Reply With Quote
Old 02-20-2012, 07:59 PM   #15
Nitsuj
Am I just reckless? It didn't appear that close to me, considering the tool. It looked to be about 1.5 to 2 inches away, and on a chop saw, the work piece is stationary that the blade only moves up and down. Seemed a little close, but risk is minimal. It's not like that blade can suddenly jump to the right. IMHO.
Nitsuj is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
