Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 03-04-2012, 11:27 PM   #1
FlaMick
Junior Member
Default 14/2 thru plastic conduent?
I want to adds two 4th T8's in my garage but being in condo everything must be in conduent or MC. I don't want to buy 3 spools (black,white,green) for this small job. Lowe's only has 500 ft spools of each. Can I run some 14/2 romex that I have thru 3/4 gray plastic?
FlaMick is offline   Reply With Quote
Old 03-04-2012, 11:29 PM   #2
RobertMo1988
Senior Member
RobertMo1988's Avatar
Default Re: 14/2 thru plastic conduent?
to me it might be hard to pull with romex, but maybe strip the lining off and then pull it?
RobertMo1988 is offline   Reply With Quote
Old 03-04-2012, 11:34 PM   #3
mrobins297aaa
Senior Member
i don't know why not, it'll fit thru it with no problems.
mrobins297aaa is offline   Reply With Quote
Old 03-05-2012, 07:34 AM   #4
hammlm
Senior Member
I would not pull the romex through it unless it was just a sleeve (think receptacle in a basement with a conduit stub coming down the wall), and then make sure you use a bushing on the end.
You shouldn't strip the romex down and pull those conductors, either. They are not marked/rated, plus the ground is bare.
You can buy single strands of THHN by the foot at my local lowes and home depot.
hammlm is offline   Reply With Quote
Old 03-05-2012, 08:47 AM   #5
pattenp
Senior Member
pattenp's Avatar
Yes you can run the 14/2 through the 3/4" conduit but is a pain to do, and as said before don't strip off the sheathing of the romex. Lowes and HD near me also sells single stranded wire by the foot.
pattenp is offline   Reply With Quote
Old 03-05-2012, 09:40 AM   #6
snorky18
Senior Member
Find a local electric supply house (hint: they will not have a big orange or blue sign, and they will also not carry lawn and garden equpiment) and you should be able to buy MC wire or THHN by the foot for much cheaper than the big box stores.
snorky18 is offline   Reply With Quote
Old 03-05-2012, 09:52 AM   #7
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Lowes and HD keep the 500 ft spools of 10, 12 and 14 in several colors on the rotating rack and will sell off of them by the foot, cost more, but if you don't need much, its no biggie. Just tell then you need wire cut.
Charles
Charles (in GA) is online now   Reply With Quote
Old 03-05-2012, 09:53 AM   #8
ishiboo
Senior Member
Quote:
Yes. It should not be difficult through 3/4". My temporary barn lighting is all PVC conduit/boxes with NM-B pulled through it.
ishiboo is offline   Reply With Quote
Old 03-05-2012, 10:08 AM   #9
paranoid56
Senior Member
Send a message via AIM to paranoid56
HD also now sells spools in 25ft rolls too
paranoid56 is offline   Reply With Quote
Old 03-05-2012, 10:23 AM   #10
Falcon67
Senior Member
Falcon67's Avatar
I'd run the MC - quicker and probably about the same price after you add in all the extra BS.
Falcon67 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
