Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 05-04-2012, 12:10 AM   #1
grego
Senior Member
grego's Avatar
Default Cleaning dirty bolts and hardware
Here's what I have. I got a giant tub of nuts, bolts, washers, all kinds of crap and hardware. To make a long story short, the people I got it from left it outside in the rain and the tub filled with water and sat like that for about a week before I came by to pick it up. I drained the water but now everything is has started to get a chalky coating like everything got galvanized.
What are my options to clean them up? I use these for areas where looks are not important so end finish is not important. I have a vibratory system and have tried it but it takes a long time and considering how much I have to process, it would take a year and a bunch of media. I have access to a media blaster also. Can I soak these in a solution to clean them up? To give you an idea about how much I have to do, the tub weights over three hundred pounds.
I'll post some pictures of the condition of the bolts in the morning.
grego is offline   Reply With Quote
Old 05-04-2012, 12:20 AM   #2
jake00
Senior Member
jake00's Avatar
Default Re: Cleaning dirty bolts and hardware
I'd clean em as you use them
jake00 is offline   Reply With Quote
Old 05-04-2012, 12:40 AM   #3
geologist
Senior Member
geologist's Avatar
Default
Soak them in vinegar for a few days. The type doesnt matter. Sulphated Molasses and water also works 1 molasses to 8 water. Has to be sulphated (feed store) otherwise it takes forever and doesnt work as well.
__________________
Quote:
Originally Posted by JimVonBaden View Post
Excellent example of Darwinism in action!
Quote:
Originally Posted by darwyn View Post
Just to be clear, I didn't do it!
Speak the truth, even if your voice shakes.
geologist is offline   Reply With Quote
Old 05-04-2012, 12:41 AM   #4
gonefirefighting
Senior Member
gonefirefighting's Avatar
Send a message via ICQ to gonefirefighting Send a message via AIM to gonefirefighting Send a message via MSN to gonefirefighting Send a message via Yahoo to gonefirefighting Send a message via Skype™ to gonefirefighting
I use a media tumbler (big one) such used for reloading brass.....works great and no mess
__________________
quattuor rota permoveo somes tamen duos rota permoveo animus
gonefirefighting is offline   Reply With Quote
Old 05-04-2012, 12:49 AM   #5
t100
Senior Member
t100's Avatar
$14 you can buy a gallon of WD40 at Lowes. soak them up then strain out the debris and you can recover most of the WD.
__________________
Quote:
Originally Posted by RbrtAWhyt View Post
Next time tell them "Yeah, well, if my aunt had a dick she would be my uncle..."
t100 is offline   Reply With Quote
Old 05-04-2012, 05:55 AM   #6
lilredex
Senior Member
I made up this basket to use with my pressure washer, to clean greasy hardware, etc. Really effective if your washer can run hot water. This might help others, but, with three hundred pounds.......you'll probably not live long enough to finish the job, this way.
Used to work at an engine re-builder and the dirty stuff was hot tanked in larger similar baskets, then hit with a steam hose. Everything came out looking like new, as it was all re-used.
lilredex is offline   Reply With Quote
Old 05-04-2012, 06:01 AM   #7
PCO6
Senior Member
PCO6's Avatar
I use B&G Rust Remover for most of my small rusty parts.
__________________
PCO6 is offline   Reply With Quote
Old 05-04-2012, 09:49 AM   #8
38Chevy454
Senior Member
38Chevy454's Avatar
Don't use vinegar or any acid unless you want to remove all the zinc. Mechanical cleaning is probably best. They will clean each other of you just have them loose in a container and let it shake around. The white on the surface is the zinc sacrificially corroding which protects the steel from rusting.
__________________
I used to have a handle on life........but it broke
My detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=66932
USA made high quality large bear claw latches - cheap:
http://www.jalopyjournal.com/forum/s...d.php?t=620485
38Chevy454 is offline   Reply With Quote
Old 05-04-2012, 10:00 AM   #9
TimeWarpF100
Alliance Member
TimeWarpF100's Avatar
Quote:
I use a similar product but found if a plastic container is used vs metal it works much better and lasts longer.
TimeWarpF100 is offline   Reply With Quote
Old 05-04-2012, 10:04 AM   #10
TimeWarpF100
Alliance Member
Old 05-04-2012, 01:17 PM   #11
PCO6
Senior Member
PCO6's Avatar
Quote:
I agree. I wouldn't use a metal container at all as the product I use would eat right through it. The tub pictured above is plastic. I put 2 cut down plastic garbage cans in it. The one on the left has the B&G Rust Remover in it. The one on the right has water for rinsing (... the level is usually higher than what is in the photo).
Here's a picture of my tank & dip basket ...
... and of my small tank & basket for nuts, bolts, brackets, etc. ...
... and of my vertical tank before I assembled it. It's basically a 6" dia. peice of ABS sealed into a bucket with concrete. It's good for long rods, pipe, etc. ...
__________________
Old 05-04-2012, 02:45 PM   #12
lilredex
Senior Member
PC06...B+G looks like good stuff. Where does one find it? Is it anything like deck cleaner?
Old 05-04-2012, 02:51 PM   #13
concealer404
Senior Member
How long do things last before they start rusting again with the B+G Cleaner? It seems like there would be no protective layer after treatment. (Though i suppose it was gone in the first place if it was rusty.)
concealer404 is offline   Reply With Quote
Old 05-04-2012, 02:58 PM   #14
PCO6
Senior Member
PCO6's Avatar
lilredex - B&G is a company from St. Catharines, Ontario and I think they sell only at automotive flea markets. I don't think they have a website and I'm not sure if they sell via mail order. I see them (same 2 guys) every year at the Barrie Flea Market (one of the first rows as you walk in) and the Ancaster British Car Flea market. They sell buffing and polishing supplies as well.
I have been using their rust remover for at least 25 years and it's great! They say you can dilute it 50/50 with water but I use it at full strength. It only removes rust - it won't touch paint. It does a good job on brass and aluminum and it won't hurt rubber, plastic or glass. The cost is about $10 per litre which is reasonable in my mind.
I'm not familiar with deck cleaner so I can't comment on that.
__________________
Old 05-04-2012, 03:02 PM   #15
PCO6
Senior Member
PCO6's Avatar
concealer404 - B&G is a lot like Redistrip but it does not have a protective layer on the metal after it is derusted. Depending on the type of metal (stamped, cast, etc.) the "re-rusting" process is different. I have had items sit for a year or more and only had a small amount of rust reappear. Five minutes in the tank will take care of that though.
__________________
Old 05-04-2012, 03:12 PM   #16
concealer404
Senior Member
Gotcha thank you.
I'm finishing up a car build and there were some bolts that i just couldn't source, and i'm to the point where i just want it together, so i was going to bite the bullet and re-use some mildly rusty hardware in the engine bay. If i can get the rust off and have it stay off for a year or two, i'd be happy.
I'll give this a shot!
Old 05-04-2012, 10:48 PM   #17
grego
Senior Member
grego's Avatar
PC06, another good reason to move up to Canada.
I will try and find something similar, I heard of the vinegar and the mollasses but did not want to strip the remaining protective coating if it has anything left in the first place. I like the wd-40 method and so far that is towards the top. I have the 5 pound media vibrator from Eastwood and while that gives me close to the desirable result, it takes a long time for each session and the corn husk material gets stuck in all the nooks and corners of allen head bolts, large nuts and other brackets that is sometimes harder to clean than the original condition. For regular hex head bolts, it works good.
Here is what I am dealing with. See picture below.
Old 05-04-2012, 10:51 PM   #18
grego
Senior Member
grego's Avatar
Oh and by the way, I already have sorted out over half of the large tote, this is whats left.
yikes!!!
Old 05-05-2012, 03:30 PM   #19
PCO6
Senior Member
PCO6's Avatar
Quote:
grego - We'd be happy to have you but you might not have to. I just checked the label and it provides a U.S. address too. Here are the addresses ...
B&G Restoration Inc.
P.O. Box 2325, Station "B"
St. Catharines,Ontario
L2M 7M7, Canada
M.P.O. Box 1092
Niagara Falls, New York
14302, U.S.A.
__________________
Old 05-06-2012, 09:16 AM   #20
Phxphenom
I'd really be interested in knowing what you put on the bolts after you remove the rust. I am restoring a '63 MGB very slowly and would need to store many bits for many months....Most of them would be stored in plastic ziplock bags.
Thanks
Phxphenom is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
