Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 11-12-2012, 08:02 AM   #1
redpost
Junior Member
Default Epoxy Coat Six Month Report
It's been six months since I applied Epoxy Coat to a new 1500+ sq. ft. garage. I don't have any UV issues so I did not use the UV protection coating. I do have a heavy flake in the finish. This is a combination workshop/garage so I do a fair share of various automotive and woodworking type projects in it.
It does receive a lot of compliments and still looks good. It is very easy to keep clean. Spills are easily wiped up and there are no stains. It does not pick up tire marks. The main downside so far is poor abrasion/impact resistance. I'm careful when working and don't typically drag heavy items across the floor or drop heavy objects on it but it doesn't take much weight or impact to scar the surface. Even dropping a 1" box wrench (that is pretty light weight) on the floor will ding the surface. Last week I lowered a tractor/loader bucket onto the floor and that left a couple of 1" scars- I didn't expect that to happen so easily. I've taken to marking these dings with blue painter's tape and periodically mix a small batch of leftover Epoxy Coat and touch them up with a brush.
So my overall rating would be B+. With better resistance to scars and dings I'd rate it higher.
redpost is offline   Reply With Quote
Old 11-12-2012, 07:53 PM   #2
stealman
Default Re: Epoxy Coat Six Month Report
I have epoxy clear coat over acid stain and I have the same complaint. It scratches and chips easy. I am considering applying a urethane top coat over the epoxy in hopes that it will help.
stealman is offline   Reply With Quote
Old 11-12-2012, 08:22 PM   #3
Baada
Senior Member
Baada's Avatar
When you go to patch it up make sure you mix up enough so you can get the ratio right. I did a few little mix up jobs that I eyeballed, about 1 thimble of A and 2 thimbles of B and it didn't harden correctly.
__________________
Never let the operational needs of the mission interfere with the administrative requirements!
Basement overhaul with epoxy floor - Shed Build
Baada is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
