Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
I'm trying to repurpose a combination switch with pilot light. I removed it from somewhere a few months ago and figured I could just "figure it out" when I went to rewire it. Unfortunately, I am not able to get both the light and LED to work at the same time (and LED shut off when the switch is off).
The diagrams I find online only have a single screw on one side and a double on the other (with a tab which can be broken off). However, my switch has a double on one side (tab between them is in tact) and TWO screws on the other side (one at each end) plus what appears to be a ground screw in the middle because it is connected to a metal strap which goes across the back of the switch. Can someone suggest how to wire this? If I hook up the black and white wire across from the switch itself, the lights turn on. However, no matter which way I hook up the other screw to the side of the LED, it either stays on all the time or doesn't turn on at all. Thanks in advance. I diagram would be awesome if you figure out better search terms for Google than I did.
__________________
My Garage Refurb Mr. Heater 75k BTU Installation Stacked two 44" HF 13 drawer boxes |
#2 |
Senior Member
You might try a web search using the manufacturer's name and the part number of the switch. Or try posting them here ... and pictures always help.
#3 |
Senior Member
One of the screws on the non-tab'd side has the word "LINE" on the back. There are no other words on the switch.
From my 220V thermostat work, I thought LINE was for the incoming power source.
__________________
#4 |
Senior Member
Give us a picture of the back of the switch.
#5 |
Senior Member
Without seeing it I'm not sure, but one version of a switch with a pilot light which is on when the circuit is on requires a four wire hookup. I use one for a thermostatically controlled barn fan which I do not want to leave energized when I am not around - the pilot light helps remind me to turn it off. Maybe that's what you have.
__________________
Martin My 19 X 19 wood-metal-car shop redo - Major Milestones Update July '12! http://www.garagejournal.com/forum/s...ad.php?t=92642 1. You stop doing your favorite things when you die, or 2. You die when you stop doing your favorite things. I'll choose # 1. |
#6 | ||
Senior Member
Quote:
Quote:
Do you want the indicator light to be on all of the time ? Leviton Single Pole Switch with Pilot Light Last edited by theoldwizard1; 11-13-2012 at 09:01 AM. |
#7 |
Senior Member
It is an "indicator" of when the switch is turned on, not that the switch has power. There is the same type of switch next to the door in my house which tells me if the basement lights are on. I can probably pull that out to see how it is wired.
I have class tonight after work, but if I get a chance I'll put up a picture.
__________________
#8 |
Junior Member
Pilot light switches require a neutral to function. The screw marked line goes to the unswitched hot wire (black). The tabbed screw across from it goes to the load (light). Leave the tab in place and no wire on the tabbed screw across from the pilot (this is the switched hot to the pilot light). The other screw across from the pilot needs to be wired to a neutral (white). The ground (obviously) gets wired to a ground wire.
I've not seen one like this in real life but this is the only way that makes any sense. If you don't have a neutral in the box you are SOL. |
#9 | |
Senior Member
Quote:
I could have sworn I tried it that way but I will try it again. I am dealing with nearly all black wires and the other item in the box is a switch with outlet combination where the outlet is always hot and the switch controls an exterior light. It is possible that I have the line and load backwards as they are nearly all black wires. I'll have to take a multi-meter to confirm.
__________________
#10 |
Senior Member
Are you sure this isn't a nightlight switch instead? One meant to be lit when the switch isn't on so you can find it in the dark? I've seen those installed and in stores and they look nearly the same.
__________________
If it isn't broken, then you're not trying hard enough. |
#11 |
Senior Member
Let me try to clarify my earlier post. There are actually two types of pilot light switch. In one type, the pilot light is on whenever the switch is in the "on" position, and in the other, the pilot light is on when the switch is in the "on" position AND the load is drawing power. For example, in my application I wanted the pilot light to be on whenever the switch is in the "on" position- that is very different from having the pilot light on whenever the switch is "on" and the load is drawing power, the usual configuration. Think it through and you will see what I mean. The switches for the two applications are different, and from your description I think you have the switch that can be wired to turn on the pilot light when the switch is in the "on" position, whether the circuit is drawing power or not.
__________________
Martin My 19 X 19 wood-metal-car shop redo - Major Milestones Update July '12! http://www.garagejournal.com/forum/s...ad.php?t=92642 1. You stop doing your favorite things when you die, or 2. You die when you stop doing your favorite things. I'll choose # 1. Last edited by Thruxton; 11-13-2012 at 05:32 PM. Reason: wrong! |
#12 |
Senior Member
Here are pictures of the switch. The other item in the face plate is a switch on top (powers outside light) and outlet (always on) on bottom.
__________________
#13 |
Senior Member
#14 | |
Senior Member
Quote:
__________________
#15 |
Senior Member
Thanks guys, I'll let you know how it goes.
__________________
#16 |
Junior Member
Not sure about my advice now. The "line" looks like it has the tab. If that is the case then I would think the "line" screw should go to the load, the screw opposite the "line" by the switch should go to the load (the light) then a neutral needs to be on the other (non-tabbed) screw.
Do you have an ohm meter? The top two screws (line and the other one) should be controlled by the switch. For sure you will need to hook a neutral up somewhere. |
#17 |
Junior Member
I'm pretty sure this is how the switch is wired internally (first pic). If so, this would be the easiest way to wire it up (second pic). I'm confused by them marking the tabbed screwes "line" but this is an industrial switch and the light can be controlled by anything.
#18 |
Junior Member
We had light switches in a house I used to own that the light in them was on when the load was off so that you could find the switch in the dark.
#19 |
Junior Member
yousesteers - that is the "normal" residential lighted switch. From a wiring standpoint it doesn't look any different from a non-lighted switch. Internally the lamp is wired between the switch contacts. It relies on leakage current through the load (the light bulb) when the switch is off.
#20 |
Senior Member
Thanks for the help guys. I was thinking originally that the indicator would basically be in series with the attic lights being powered. The white wire is what I was missing. If you look at the original pictures I posted, you can see there are no white wires going to the switch.
I attached a couple of the completed installation pictures. It is an old (repurposed) switch so the light is not that bright plus my phone's flash went off so that probably drowned it out too.
__________________
| Thread Tools | |
| Display Modes | |
