Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
After throwing my driveshaft since I didn't use locktite on that bolts that go into the yoke(live and learn) I thought about it and the reason I don't use it on all sorts of stuff is just how dang expensive it is!
Is there anything cheaper that works similarly? I've seen some at HF but don't know how good it is, anybody know from experience? Or maybe there's a cheaper place to get the real stuff than the local autozone? I haven't looked at ebay, maybe that's the trick to stock up before you need it! Anyway thanks in advance!
#2 |
Senior Member
Any worthy alternative will likely have a similarly high cost.
How much do you need? I found that larger quantities via industrial supply isn't much cheaper than what you can pick up at Lowes or HD.
__________________
ToolGuyd Blog (Tool reviews, deals, new tools) Amazon 50-70%-off Tool Deal-Finder |
#3 |
Moderator
Do you have enough threads to install a locking washer?
__________________
The colossal prick even managed to sound magnanimous. |
#4 |
Moderator
You could wire tie them to!!
__________________
#5 |
Moderator
Drill a small enough hole thru the bolt head and get some metal wire and thread a piece thru each bolt connecting them with wire.
__________________
#6 |
Senior Member
I've been using the sticks - picked up one of the blue and one of the red a few years ago. I find them easier to use than the little vials - just wipe the bolt across the stick and you're set.
They're about $15 ~ $20 each depending on where you buy them. As I said, I've had them for a few years and still using them. I also see that they now have anti-seize sticks and some other formulations. As you found out with your driveshaft, I'd say the price is cheap insurance. |
#7 |
Senior Member
Permatex is cheaper, and very good stuff too.
As for the price, a bottle of Loctite may run you $30-40 (i don't know what it costs your side of the pond) but it'll last you, and you'll get your money's worth out of it. When you consider the amount used on each bolt, and how long a bottle lasts. Unless you use it everyday, it'll last you years. |
#8 |
Senior Member
so the sticks are just as good as the liquid? doesn't it dryout.
#9 |
Senior Member
You never got new brake caliper bolts with the dry threadlock on them already?
#10 |
Senior Member
Please advise which vehicle bolts need Locktite.
#11 |
Senior Member
DHC: I cap my sticks when not in use, but they're still as gummy as the day I bought them after several years.
Jay: Typically the shop manual will tell you which ones get threadlocker. |
#12 |
Senior Member
thanks PAT, I'll have to try those when I runout. the liquid one get's a little messy sometimes.
So is the stick the preferred type, I use the liquid but niticed they had a gel and stick too. one more thing, does the stick come in red and blue? |
#13 | |
Director of Bands
Quote:
I have been using the blue Loc-Tite gel and it works great. Less waste. I don't remember it being that expensive. However, I would really caution anyone to 'cheap-out" on something as critical as thread lock. The consequences could be tragic. |
#14 |
Moderator
Nascar crews saftey wire's bolts!!! That is what I was suggesting.
__________________
#15 |
Senior Member
I'll bet the drive shaft that came loose was a Ford. The Fords with the aft u-joint with the flat flange and four twelve pointed capscrews holding it to the differential flange, must have locktite on the threads. My father had the transmission in his '84 LTD (Fairmont sized car) rebuilt about '90 or so and they didn't use locktite on the threads of those rear driveshaft flange bolts. Soon after we started hearing a clunk when you shifted to reverse from park, or from drive to reverse, and I found the bolts loose. I bought new ones (the original ones were damaged by that point) and the new ones had been pre-locktited.
More recently I replaced the clutch in my '91 Ranger and was smart enough to use locktite on those bolts when I reinstalled the driveshaft, no problems. The sticks are a very good idea, since the bottles go bad after a while, and I had resorted to buying the tiny tubes of the liquid. Charles |
#16 |
Alliance Member
After all of the recent problems with everything from imported toothpaste, pet food, to tires, would you really want to cheap out on something that is critical enough to want to use a thread locking compound on?
I would watch the sales, look at the sticks or gels to reduce waste, and compare reputable brands.
__________________
It's not the tools in the toolbox, it's the mechanic who knows how to use them that matters. |
#17 |
Moderator
I have both the Permatex red and blue plus the Loctite red and blue. Never noticed any difference between the brands ...
#18 |
Senior Member
I tend to buy my antiseize, and loctite compounds, from a damaged freight store, for less.
For LOW torque stuff, my father has used nail polish that my mom didn't like. He would probably use it on the car to, if he did his own work (only oil changes, and putting on the snow tires). |
#19 |
Senior Member
heard about the nail polish thing and have used it in a pinch too with no probs..............also notice a lot of waste when others use loctite..............just remember, a lil' dab will do ya..............
#20 |
Senior Member
Example: Nut backing out of a yoke on a Trans and losing the yoke,the driveline and possible the rear input bearing. Cost of repair approx $600.00
Cost of a bottle of Loctite that would prevented said loss. $30.00 Lesson Learned "Priceless" DDM
__________________
"Borrowing Tools are for the Weak" |
| Thread Tools | |
| Display Modes | |
