Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Sponsored Links (Register now to hide all advertisements)
Reply
Thread Tools Display Modes
Old 07-10-2006, 12:28 PM   #1
jarhead
Senior Member
jarhead's Avatar
Default 4 foot wide garage door
Does anyone make a 4 foot wide garage door? I want to bring my motorcycle in from the side of my garage so I dont have to back out a car or truck to get in/out of the garage.
Thanks, Joe
jarhead is offline   Reply With Quote
Old 07-10-2006, 12:49 PM   #2
OldCarGuy
Senior Member
OldCarGuy's Avatar
Default Re: 4 foot wide garage door
I am planning on installing a 7 wide by 7 high steel roll-up door on the side of my 30x50 pole barn so that I can pull in my John Deere tractor inside without pulling out my motor home and car hauler trailer.
I would suggest that you special order and install a 48 steel mandoor. You can get one in 6 8, 7, or 8 height. http://www.doormartusa.com/doormart/...&idcategory=66
OldCarGuy is offline   Reply With Quote
Old 07-10-2006, 01:09 PM   #3
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
A sheet type roll up door like used in mini storage units, available in nearly any width and height.
Contact the various garage door makers, they might be willing to custom make a narrow door for you also.
Charles
Charles (in GA) is offline   Reply With Quote
Old 07-10-2006, 01:27 PM   #4
nova65ss
Senior Member
nova65ss's Avatar
Charles
Just call a garage door manufacturer they can make you a door pretty much any size you want. You will likely pay for the next size up and they will just cut it doen the size you want.
Jimmy
nova65ss is offline   Reply With Quote
Old 07-10-2006, 02:16 PM   #5
DIGGER_DAVE
Senior Member
Quote:
Thanks, Joe
I wish I had made my "man door" 48" wide. (only 36" now)
If it was 48" wide, I could roll my engine stand (with engine(s) attached) in and out without having to "jockey" the darn thing all over the place.
48" hinged doors, pre-hung with casing, are readily available at most building supply stores. (and cheaper than "roll-ups")
One of these days ....
__________________
Digger Dave
DIGGER_DAVE is offline   Reply With Quote
Old 07-10-2006, 06:53 PM   #6
boiler7904
Senior Member
boiler7904's Avatar
I don't think I've ever seen a 4' wide overhead door. I just looked through our overhead door catalogs at work and the the narrowest that I see is 8'. Unless you want to go through the excercise of building your own overhead door, I think Digger Dave is on the right track.
How about a pair of 3'-0" wide hinged doors? They have a few positives going in their favor:
1. They're usually a stock item (more so than a single 4'-0" door).
2. They're likely less expensive than the other options listed.
3. They allow more flexibilty for use. You know as soon as you put in a 4' door, you're going to want to take something 4'-0 1/2" wide through it.
4. A 3'-0" door weighs less than a 4'-0" door. That puts a lot less wear and tear on the hinges and frame.
5. More likely to find a pair that matches the other doors on your house.
Two disadvantages:
1. You lose 2'-0" of wall space compared to the 4'-0" door.
2. You need a longer (potentially deeper) strucutral header when you cut in the opening.
Just a couple of thoughts. Let us know what you decide to do.
boiler7904 is offline   Reply With Quote
Old 07-10-2006, 07:30 PM   #7
nova65ss
Senior Member
nova65ss's Avatar
They can make you an overhead door any size you need. They don't list them in catalogs but they can do it. We put them on alot of upper end golf homes for the golf carts.
I'm not sure I'd like to have the threshold that comes with most double entry doors, nor or they very secure in my opinion. Plus you can't motorize them.
Jimmy
Old 07-10-2006, 08:30 PM   #8
jarhead
Senior Member
jarhead's Avatar
Thanks everyone, allot of good ideas were given I had not thought of.
This is a great site!
Old 07-12-2006, 05:40 AM   #9
Three Stooges Racing
Junior Member
I saw some of the steel roll up doors cheap on ebay the other day. They may still be there.
Semper Fi
Mike
Three Stooges Racing is offline   Reply With Quote
Old 07-14-2006, 06:49 AM   #10
ultgar
Senior Member
A 4' door is easily made from a larger unit. Ask you local garage door guys if they have any scratch and dent doors they want to get rid of cheap and you can cut it down to size and recap one of the ends.
SD
ultgar is offline   Reply With Quote
Old 07-14-2006, 12:44 PM   #11
sberry
Senior Member
sberry's Avatar
Yup, my Bud did one from a salvage door, made it 5 ft wide. Easy.
sberry is offline   Reply With Quote
Old 07-19-2006, 10:26 PM   #12
jarhead
Senior Member
jarhead's Avatar
Quote:
Jimmy
Thanks for the idea. I have been doing some calling this week and that is the best option.
440.00 from a local Anderson dealer. Two inch thick and insulated.
Home Depot wanted 687.00 for a clopay custom order.
I also checked on the roll up and it was 312.00 and not insulated.
A double man door was going to be 410.00
I appreciate everyones help.
Joe
Old 07-23-2006, 09:11 AM   #13
tommy
Junior Member
I ordered a double door with a removeable astricle(spl?)(divider).
99% of the time it's used as a standard door like in the picture saving the heat in the winter. If I want to roll something big inside it only takes a few seconds to convert it to wide open.
tommy is offline   Reply With Quote
Old 07-24-2006, 07:03 AM   #14
atch
Senior Member
i agree with tommy. i built a house in '87 and put in a 5'-0" double door (two 2'-6" leaves) in the walkout basement. i stored a garden tractor in there and it was great. the threshold was a small nuisance, but it never actually bothered me or slowed anything down. mine didn't have an astragal so that wasn't an issue. the one leaf had locks, more or less deadbolts, that went up into the jamb and down into the threshold that you could get to when the other leaf was open.
i loved it.
__________________
atch
(Mike Atchley)
Procrastinate NOW!!!
atch is offline   Reply With Quote
Old 07-24-2006, 07:45 AM   #15
trovato
Senior Member
Thanks, Joe
You know, in Florida it seems like every house built on a golf course has a separate narrow garage door for the golf cart. I don't know exactly how wide they are. Just another thought for where to look for ideas.
trovato is offline   Reply With Quote
Old 07-24-2006, 04:03 PM   #16
jarhead
Senior Member
jarhead's Avatar
After a couple of phone calls it appears the double entry door would be around 450.00.
I like the idea of it due to having a door to open and shut quickly as oppossed to the overhead door.
I was told they would not warrant leakage so that was a little disturbing.
It looks like the overhead is the best solution still.
The 4 foot man door would be a problem opening in.
Any other ideas anyone?
Thanks, Joe
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
