Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-28-2010, 06:18 PM   #1
Stinger
Senior Member
Stinger's Avatar
Default How to Fix Harbor Freight Tool Chest Drawer Detent (Make it Easier to Open)
Many people have noticed the Harbor Freight Tool Chest has a small issue of the drawers being difficult to open because the detent is too tight. This is the tool chest we are talking about:
I decided to figure out the problem and a fix.
Here is a picture of the rubber stopper at the back of the box that each drawer detent slides over when fully closed:
Here is a detent on the rail as delivered (note the end of the rail is bent towards the center:
It appears while they are punching the small detent into the rail, it bends the rail in varying amounts on each drawer. This is what creates the problem with the drawers being difficult to open. To fix it, simply put an adjustable wrench over the rail and bend it "close" to straight, leave just a little bend in the rail:
Fixed Rail:
After you do a few of the drawers you'll get a good idea how much bend to leave to get proper tension.
One additional bonus to this fix is it will decrease wear on the rubber stopper which will allow it to last longer. If it does begin to wear out, simply remove the drawers and add a little more bend to the rails to bring the detent tension back
Stinger is offline   Reply With Quote
Old 01-28-2010, 06:50 PM   #2
jefferson
Default Re: How to Fix Harbor Freight Tool Chest Drawer Detent (Make it Easier to Open)
Awesome, thanks!
Couldnt be easier.
jefferson is offline   Reply With Quote
Old 01-28-2010, 07:28 PM   #3
mr2autoxr
Thanks Stinger....now I have a good weekend project.
Mike
mr2autoxr is offline   Reply With Quote
Old 01-28-2010, 08:42 PM   #4
devilphrog
Senior Member
devilphrog's Avatar
Good Solution!! I was having the same problem with my Craftsman box and I solved it by removing the detents and adding magnets. A little bit costlier but same result
devilphrog is offline   Reply With Quote
Old 01-28-2010, 08:59 PM   #5
musgofasta
Senior Member
I have the inverse problem - I'm going to use this to make some of mine harder to open because they don't stay closed...
Thanks!
musgofasta is offline   Reply With Quote
Old 01-28-2010, 09:18 PM   #6
Mr_fixit
Senior Member
Mr_fixit's Avatar
Quote:
Thanks!
If they don't stay closed it's probably because the box isn't level....?
Mr_fixit is offline   Reply With Quote
Old 01-29-2010, 12:12 PM   #7
Stinger
Senior Member
Stinger's Avatar
Quote:
Yes and no. While not being level would cause them to slide open, if the detent has sufficient tension they shouldn't open by themselves regardless of the angle.
Old 01-29-2010, 12:14 PM   #8
tonydanzah
Senior Member
tonydanzah's Avatar
that is pretty cool, but i like that magnet solution that was posted a while back
tonydanzah is offline   Reply With Quote
Old 01-29-2010, 02:36 PM   #9
drsifu
thanks. seems like a good option.
about that magnet solution...you have a link? will go and try the search right now.
i've just closed the drawers far enough before the detent. unless you are locking the cabinet, any reason you guys are shutting it all the way?
drsifu is offline   Reply With Quote
Old 01-29-2010, 02:55 PM   #10
jefferson
I dont have a link, but the main idea was glue some magnets to the inside of the box on the rear piece of metal, glue some magnets to the back of the drawers.
Old 01-29-2010, 03:07 PM   #11
devilphrog
Senior Member
devilphrog's Avatar
Here is the Magnetic Box Mod thread.... enjoy!
http://www.garagejournal.com/forum/s...ad.php?t=51731
Old 02-01-2010, 12:46 AM   #12
Stinger
Senior Member
Stinger's Avatar
That's what I was doing until I modified the detents. I just didn't like it not being the "right" way to do it. I'd just rather fix the problem then band aid it is all.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
