Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Sponsored Links (Register now to hide all advertisements)
Reply
Thread Tools Display Modes
Old 02-15-2010, 05:17 PM   #21
slopecarver
Senior Member
Default Re: How to separate stuck buckets?
I've only ever dealt with dirty buckets(dried dirt ironically), they don't stick together!
slopecarver is offline   Reply With Quote
Old 02-15-2010, 05:44 PM   #22
mrb
Senior Member
mrb's Avatar
The thing with buckets is, you must not stack dissimilar buckets. For example, if you put a blue bucket you inherited from an organization who no longer has a blue bucket inside an orange homedepot bucket they will become stuck together not unlike that self fusing silicone tape. I think home depot may have engineered their buckets to become permanantly attached to other buckets, although I have yet to come up with their motive in doing so.
mrb is offline   Reply With Quote
Old 02-15-2010, 06:43 PM   #23
Torque1st
Senior Member
Torque1st's Avatar
Quote:
That is a mating ritual and you must not disturb the buckets for at least 6 months or you will not get any new buckets.
Seriously, just drop a string down the inside or a wire... -Anything to break the air tight seal. Otherwise you are fighting air pressure to pull them apart.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 02-15-2010, 06:47 PM   #24
lawfarm
Senior Member
lawfarm's Avatar
I use a small amount of semtex...
Used to have a neighbor with an even better method. All of his buckets were oily on the inside. So they were easy to get apart...but once you had one, you didn't really want to use it!
lawfarm is offline   Reply With Quote
Old 02-15-2010, 09:38 PM   #25
nolatoolguy
I personally wist as i pully up and that usally works, if not i just pull harder, and when all else fails i just try to get the top 2 or something like that
nolatoolguy is offline   Reply With Quote
Old 02-15-2010, 09:46 PM   #26
mustangmccance
Senior Member
mustangmccance's Avatar
just drill a small hole in the bottom of the bucket and use an air compressor with a rubber fitting to force air between the buckets. of course then you have a hole in your bucket, but as professor lockhart would say the important thing is they are no longer stuck.
__________________
patience is not one of my virtues
"if it's not broke I haven't fixed it yet"
Welcome to the Doghouse!: http://www.garagejournal.com/forum/s...ad.php?t=44061
mustangmccance is offline   Reply With Quote
Old 02-15-2010, 10:01 PM   #27
msnow
Senior Member
Here are a couple ideas for you.
msnow is offline   Reply With Quote
Old 02-15-2010, 10:35 PM   #28
jklingel
Senior Member
I just wait till it's at least 20 below, then hit them w/ my 12 gauge and a 3" magnum w/ #6 shot. I've not had any two pieces stuck together after that. If you do that in your unheated garage, wear good ear protection.
jklingel is offline   Reply With Quote
Old 02-15-2010, 10:46 PM   #29
mrb
Senior Member
mrb's Avatar
Quote:
those appear to be stagehand people. I bet their pay is far greater than the cost of a bucket for the time spent trying to get a pair of buckets unstuck.
Old 02-15-2010, 10:56 PM   #30
Racecarl
Senior Member
Racecarl's Avatar
We have a powerwasher at work that puts out HOT water. I heat the bottom outside bucket with the pressure washer and [I]usually[I] the buckets will come apart.
Racecarl is offline   Reply With Quote
Old 02-15-2010, 11:13 PM   #31
mrb
Senior Member
mrb's Avatar
hmm, just had an idea. could keep a foot long piece of rope attached to the handle, then when stacking buckets put it into the bucket before putting in the next bucket.
Old 02-15-2010, 11:32 PM   #32
no2tracks
All s ya gotta do is hold yer tongue just right...
no2tracks is offline   Reply With Quote
Old 02-16-2010, 03:59 AM   #33
onewaydave
Senior Member
Whats interesting is that $.59 bucket we pay $2.99 for is cast to such high tolerances that msnow has to go to such extremes in engineering to deal with unintended consequences.
Stickers will solve the problem and unlike jklingle you don't have a mess to clean up that was a hell of a lot of fun to make.
onewaydave is offline   Reply With Quote
Old 02-16-2010, 06:41 AM   #34
Finley
Senior Member
Finley's Avatar
a little baby powder where the 2 buckets contact works
Finley is offline   Reply With Quote
Old 02-16-2010, 12:30 PM   #35
Donn
Junior Member
It is quite clear that you need to build a bigger shop, that way you would not have to stack your buckets, you could just line them up nice and neat!
Donn is offline   Reply With Quote
Old 02-16-2010, 01:00 PM   #36
ihredo4
Senior Member
One thought comes to mind. It involves a small hole, ether and a match. My problem is I never know which side of the bucket to stand on. After multiple tries I still havent found the right spot. I am about ready to just glue them all together and leave it at that.
ihredo4 is offline   Reply With Quote
Old 02-16-2010, 02:03 PM   #37
jklingel
Senior Member
Quote:
Originally Posted by onewaydave View Post
...and unlike jklingle you don't have a mess to clean up that was a hell of a lot of fun to make.
Mess? Hell, I take them over to my neighbor's property. The tolerance issue is a good point; I don't see much made to the specs of a freaking bucket.
Old 02-17-2010, 04:38 AM   #38
jackportd
Junior Member
Hello,
Invert the buckets and pour hot water over the bottom of the outer bucket. Holding the rim of the inner bucket between your feet, grasp the rim of the outer bucket and pull it off the inner one.
__________________
acecard
jackportd is offline   Reply With Quote
Old 02-17-2010, 08:32 AM   #39
diogenes
Senior Member
diogenes's Avatar
Quote:
Originally Posted by lawfarm View Post
semtex...
Quote:
Quote:
Originally Posted by ihredo4 View Post
ether
I have GOT TO party with you guys!
__________________
Just my opinion, of course. I've been accused of being an opinionated ass, and with some justification, in the past.
_
"An army of words escorting a corporal of thought"
--Ambrose Bierce
_
They who would enslave you will do so with the best of intentions.
diogenes is offline   Reply With Quote
Old 02-17-2010, 11:31 AM   #40
Rigmaster
Senior Member
Rigmaster's Avatar
Wow, this has gotten a bit of track to say the least--- but VERY entertaining!!!
On a somewhat-related note, does anyone have any tricks for getting the lids off 5 gallon buckets? I'm talking about the "UN" rated lids that don't have the little notches around the rim of the lid.
There's a tool called the "bucket buster" that says it will take the lids off no problem, but I don't know if we really need that. I'm looking for any tips/trick to get them off with "normal" tools.
We have a bunch of these buckets at work that need to have the lids removed so we can rinse them out then reuse them.
Thx.
Rigmaster is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
