Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-02-2009, 06:07 PM   #1
TONE
Senior Member
Default Ideas or product for hanging extention ladder from ceiling
Folks..........
Ive been hunting and searching for a product to hang my extention ladder from my garage ceiling.
I'd like it to lay flat up against it, not just hangin from j-hooks. I need it flat against the ceiling or as close to it as I can get.
I dont want it on the walls.
Anyone know of anything?
thanks
TONE is offline   Reply With Quote
Old 11-02-2009, 06:42 PM   #2
1320stang
Senior Member
1320stang's Avatar
Default Re: Ideas or product for hanging extention ladder from ceiling
How about 4 j-hooks? space 'em to get the rungs, face them all the same way.
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1990 Dodge Shadow
2000 Explorer 4 door
2000 Windstar SE
2003 Explorer Sporttrac
1320stang is offline   Reply With Quote
Old 11-02-2009, 06:54 PM   #3
babzog
Senior Member
babzog's Avatar
In my uninsulated shop, I just slip it up between the trusses and block it. If I were to hang it in a finished space, I'd make a couple of brackets, one fixed, the other not. The fixed one would be a basic box, screwed to the ceiling, where I'd slip one end of the ladder. The non-fixed one would receive the ladder (pushed up into it) and then a dowel or some such slipped through a couple of holes (completing the "box") would secure it.
__________________
You get what you pay for.
“Progress is man's ability to complicate simplicity.” - Thor Heyerdahl
“Success is the ability to go from one failure to another with no loss of enthusiasm.” - Thor Heyerdahl
babzog is offline   Reply With Quote
Old 11-02-2009, 07:14 PM   #4
D.J.
Senior Member
Two pulley.s with rope to secure it up flat and tight against the ceiling and a couple pul lys on the wall (where ceiling and wall meet)and a couple cleats on the wall to secure the excess rope
D.J.
D.J. is offline   Reply With Quote
Old 11-02-2009, 08:59 PM   #5
onewaydave
Senior Member
Fab up a cup for one end and mount at the spot you want the ladder to start, mount a pulley at the other end. Slip the ladder into the cup, attach a hook to one end of the pulley rope and pull up tight to the ceiling.
Pulley and rope about 3 bucks, wooden cup from shop scrap.
Dave.
onewaydave is offline   Reply With Quote
Old 11-03-2009, 08:39 AM   #6
bluesman2a
Senior Member
IDASHO did it...
Do this:
http://www.garagejournal.com/forum/s...7&postcount=16
Could do the same thing, with hooks instead of the frame. Or not, your call.
bluesman2a is offline   Reply With Quote
Old 11-03-2009, 08:43 AM   #7
rieferman
Senior Member
rieferman's Avatar
Our whole neighborhood (literally 6 guys all copied the same idea) does what larry mentions above (4 j-hooks spaced properly and facing the same direction). Works perfectly, costs almost nothing, and took about 10 minutes to put together.
__________________
My barn saving thread
rieferman is offline   Reply With Quote
Old 11-03-2009, 09:37 AM   #8
348guy
348guy's Avatar
Quote:
Originally Posted by TONE View Post
Folks..........
thanks
What I did was build a small shelf that mounts to the wall above the garage door. This shelf holds the bottom of the legs. Then I put a J-hook in the ceiling that I hook the other end of the ladder to. This makes it very easy to store and retrieve. I'll try to remember to take a picture or 2 and post when I get home. This makes VERY good use of the space between the low ceiling and the opened garage doors.
__________________
2-car attached townhouse garage. Too damn small, 19'x21'x8'3".
348guy is offline   Reply With Quote
Old 11-03-2009, 11:37 AM   #9
lawfarm
Senior Member
lawfarm's Avatar
I did the J hooks plus 2 pulleys setup.
On one wall, I have the J hooks.
Then, in the middle of the ceiling, I have a pulley securely attached to a joist. On the wall opposite the J hooks, I have a second pulley. Below the second pulley, I have a hook to secure the rope to.
I carry the ladder in and set one end on the wall-mounted J hooks. I hook the rope to the ladder, and pull the end attached to the second pulley. It pulls the ladder up to the ceiling...then I tie off the rope on the wall-mounted hook. Ladder gets stored flat against the ceiling. The ceiling is 10' tall, so I can't just reach up and hook it...hence the pulleys. Rope remains tight against ceiling and wall, and out of the way. It works quite well as a system.
Just because I'm a bit AR, I also tie a safety rope from another eye bolt to the ladder, once I have it up, in case a pulley or hook fails.
lawfarm is offline   Reply With Quote
Old 11-03-2009, 12:18 PM   #10
kbs2244
Senior Member
You will never get it dead flat against the celing.
There has to be some rom for play.
But 388guy is pretty close to the way I did it.
You make the shelf about a foot deep so you can push the feet in then pull the ladder out enough to set in the hooks.
If it is a normal 2 part ladder it will clear a normal garage door just fine.
You do need to yse a step ladder to do it this way,
so you need some floor space to store it.
kbs2244 is offline   Reply With Quote
Old 11-03-2009, 12:33 PM   #11
Auzivision
Senior Member
Auzivision's Avatar
It depends on if you are looking for something cheap and functional or eloquent and functional. A couple of these would get you within about 6 inches:
http://www.prohoists.com/1_Bike_Gara..._bicycle_hoist
They could probably be modified for less and a remarkably easy to install and use. You could easily lengthen the distance between pulleys for better balance. Plus I see them for $7.49 at Harbor Freight all the time.
Two of these are strong enough to hold my 8Ft truck shell (at least momentarily). I use them to balance the load, but leave most of the weight on the electric hoist when storing.
Auzivision is offline   Reply With Quote
Old 11-03-2009, 12:51 PM   #12
travisd
Senior Member
At my old townhouse garage, I made a little "shelf" wide enough to support the base of a 12' or so wooden ladder, and used a chain and hook on the other end to support it form the conveniently located garage door opener mount.
travisd is offline   Reply With Quote
Old 11-03-2009, 02:52 PM   #13
lawfarm
Senior Member
lawfarm's Avatar
With the rope/pulley system described above: 1) I don't need a step ladder to store my extension ladder; and, 2) the extension ladder is within 3/4" of the ceiling at both ends.
Old 11-03-2009, 04:06 PM   #14
348guy
348guy's Avatar
Here's what I did.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
__________________
Old 11-03-2009, 04:17 PM   #15
TONE
Senior Member
Hmmmmm, thanks guys.
great idea.
i think what 348 did is similair to what i need.
thanks again!
Old 11-05-2009, 02:22 PM   #16
ProGun3400
Senior Member
I was looking for the same to hang my extension ladder. The last trip to Menards I noticed a set of these brackets. It was a bracket that would allow the ladder to be held up flat against the ceiling. I'll be making a trip there either tomorrow or Saturday. I'll get the skew number when I'm there.
ProGun3400 is offline   Reply With Quote
Old 11-06-2009, 10:08 PM   #17
7echo
Look at the Jet Rack. Guys use them in work vans, but they will mount on most any ceiling. Check out this vid...
http://www.youtube.com/watch?v=XVepAHWSNG8
7echo is offline   Reply With Quote
Old 11-10-2009, 02:53 AM   #18
nyjets53
nyjets53's Avatar
harken hoist
__________________
Rich
'70 DeVille
BackYard Buddy
nyjets53 is offline   Reply With Quote
Old 11-10-2009, 09:24 AM   #19
NUTTSGT
Senior Member
NUTTSGT's Avatar
Some good ideas in here. I have mine standing up in my garage in the corner. I guess I never thought about hanging them from the ceiling.
__________________
ERIC
Too much is.... Just enough.
NUTTSGT is offline   Reply With Quote
Old 11-10-2009, 10:58 AM   #20
Great white
Junior Member
Great white's Avatar
Quote:
Originally Posted by 348guy View Post
Here's what I did.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Heck, I'd need a ladder to get the ladder down....
Great white is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
