Welcome to the The Garage Journal Board forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Sponsored Links (Register now to hide all advertisements)
Reply
Thread Tools Display Modes
Old 02-21-2011, 05:23 PM   #1
ChristopherLutz
Senior Member
Default Best Shower Head?
Ok...a bit off topic; however, I WAS in my garage over the weekend pulling apart a new shower head to remove the flow restrictor in a moderately successful attempt to get a good shower.
Any brands, suggestions, tips or "hot rod" ideas for shower heads? My water pressure seems "ok" - but, I can't seem to find a shower head that delivers a good shower.
the Mrs. complains she can't rinse her hair, etc. etc.
Ideas wanted - thanks.
ChristopherLutz is offline   Reply With Quote
Old 02-21-2011, 05:30 PM   #2
kartracer23
Senior Member
kartracer23's Avatar
Default Re: Best Shower Head?
Well there was this girl that I met one night in a bar, went back to my place, decided to take a shower and...
oh. wait. nevermind.
kartracer23 is offline   Reply With Quote
Old 02-21-2011, 06:38 PM   #3
54FordPanel
Senior Member
54FordPanel's Avatar
54FordPanel is offline   Reply With Quote
Old 02-21-2011, 05:31 PM   #4
Regnar
Senior Member
Mine use to complain about not getting the soap out of her hair. Now she complains there is not hot water after 8 minutes.
Regnar is offline   Reply With Quote
Old 02-21-2011, 05:37 PM   #5
SgtRauksauff
Senior Member
I really like this kind:
I first used them in the dorms in college, then have them in the house now. My concern with the big "fancy" shower heads, is that unless you have a LOT of pressure, you wont' get a strong stream, because the huge head allows the water to pool, rather than continuing to stream.
With the head above (you can even get 'em at wal-mart, I believe), there isn't really a collector on the end of it. I've never done any measuring, but I really believe that with this shower head, I actually use less water per given time of showering, because I don't have to crank up the pressure so much to get a good solid stream. a few times in the past, when I've become chilled from working outside too long in the cold, I've been able to take 1.5hr showers, and had wonderfully hot water the whole time. Whenever I'd try that before, I'd always end up getting about 25 minutes before the water would noticeably become cooler.
That's my opinion anyways.
--sareg
SgtRauksauff is offline   Reply With Quote
Old 02-21-2011, 05:40 PM   #6
rickairmedic
Senior Member
rickairmedic's Avatar
1 tankless water heater
2 rainshower overhead
3 firehose looking showerhead on main wall
4 2 showerheads on backwall both with multiple spray patterns
These make for a possible never ending shower and plenty of water to get squeeky clean ( or really dirty ) depending on the shower .
Rick
rickairmedic is offline   Reply With Quote
Old 02-21-2011, 05:42 PM   #7
JerseyJim
Senior Member
JerseyJim's Avatar
There's a Seinfeld episode on shower heads. I had tried a lot of different shower heads over the years and had been disappointed in some way or another with all of them. Went on Amazon and started reading reviews. Came up with one called the Alsons Fluidics Water Saving Shower Head. The model that I bought was the 656 rated at 1.85 GPM.
This is a standard shower head. It is not hand held. No adjustments. Nothing fancy. What I liked about this one is that the spray consists of large droplets. The volume of water seems much higher as a result.
It looks like Delta is now selling the same type of shower head. They call it H2OKINETIC.
Check both out on Amazon.
JerseyJim is offline   Reply With Quote
Old 02-21-2011, 06:07 PM   #8
metal1313
Senior Member
metal1313's Avatar
i tend to use mine on a "mist" mode, but it seems much stronger this way, and is supposed to use less water. one thing that made a major difference for me was to have the shower head mounted higher. im 6'3'' and they wanted to mount the shower head right at 6ft. i hate bending to shower so i had them mount it higher, and now its perfect.
metal1313 is offline   Reply With Quote
Old 02-21-2011, 06:33 PM   #9
Berserker
I had a bad shower valve, cut open the wall with a sawzall and put in a T with two ball valves, with the handles bent out. Best damn shower.
Berserker is offline   Reply With Quote
Old 02-21-2011, 07:30 PM   #10
ChristopherLutz
Senior Member
Quote:
Can you explain this a bit more? Did you create two shower heads?
Old 02-21-2011, 07:32 PM   #11
Torque1st
Senior Member
Torque1st's Avatar
Quote:
Think about it for a moment. Surely you can figure it out.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 02-21-2011, 07:19 PM   #12
Trainman
Senior Member
My vote is for a Sirolflex. Cheap white plastic, just one mode, but a really good shower especially if you take out the water saver parts. You can get them on feebay for less than $10.
Trainman is offline   Reply With Quote
Old 02-21-2011, 07:31 PM   #13
PassnThru
Senior Member
PassnThru's Avatar
Understand that you may not be getting enough water through the pipe to begin with to ever be happy with any showerhead. Do you have an older home with old pipe? It might be getting clogged up. Of course, if it's copper that probably isn't a problem. Maybe someone ran an undersize pipe to the bathroom to begin with? I would first try a little redneck measuring without a shower head into a 5 gallon bucket and figure out the flow rate just to make sure.
__________________
*** Looking to quote you here - preferably a quote you would rather we all just forgot. I'm watching......
(Excluding TampaGT - no shock value left there)
PassnThru is offline   Reply With Quote
Old 02-21-2011, 07:25 PM   #14
Frank The Plumber
Senior Member
Frank The Plumber's Avatar
Hansgrohe, pull the o ring out of it, Chicago faucet sells a commercial style head for public showers etc. Fully clean able, solid brass, costs a few bucks but you will never need another.
__________________
Visit My angelfish room at
http://www.facebook.com/pages/Indian...64072983609849
Frank The Plumber is offline   Reply With Quote
Old 02-21-2011, 07:30 PM   #15
Torque1st
Senior Member
Torque1st's Avatar
SgtRauksauff, has it right. The same Peerless shower head is available at Alson's, Walmart, Lowe's, and Mills Fleet and Farm. All around $8-10.
The following link is for one version. I think the packaging differs slightly at different retailers:
http://www.peerlessfaucet.com/produc...duct.sku=76150
__________________
The FairTax
Old 02-21-2011, 07:35 PM   #16
Frank The Plumber
Senior Member
Take your shower head off and do a gpm flow test with just the arm into a 5 gallon bucket, mark a 2 gallon mark in it, time the fill to the 2 gallon mark, adjust to a minute. Most new shower heads deliver 2.5 gpm out of the box.
__________________
Old 02-21-2011, 08:17 PM   #17
volvo
Senior Member
volvo's Avatar
Love my Holiday Inn/Suites shower heads, had to buy two, one for each bath. Always get complements from those who use them.
KOHLER K-10284-CP Forte Multifunction Showerhead,
http://www.amazon.com/gp/product/B00...SIN=B000MVTMMO
volvo is offline   Reply With Quote
Old 02-21-2011, 08:34 PM   #18
Homoudont
Senior Member
Homoudont's Avatar
I'm not a plumber but I'll try and explain what was told to me by a plumber regarding water pressure. The further away your from the main line the less pressure you have, the closer you are the more pressure you have. If your too close to the main line then you run the risk of blowing out your plumbing fittings so they outfit regulators to houses to decrease the pressure. He showed me a diaphragm looking thing connected to the main line coming into the house. I believe he had me turn it counter clockwise a quarter turn at a time to increase the house pressure. He said you wanted to do it in small increments over a period of time so your not blowing out fittings in your house. Anyway a small turn was suffice enough to increase our water pressure to acceptable levels.
Maybe a plumber can chime in and give a more detailed or correct explanation of this.
Homoudont is offline   Reply With Quote
Old 02-21-2011, 08:41 PM   #19
OccupantRJ
Senior Member
OccupantRJ's Avatar
I buy a cheap one and drill out the restrictor plate instead of removing it altogether. You can keep drilling in increments until it suits you. When I have moved in the past, I took the shower heads with me and replaced the ones in the house I was selling.
__________________
RJ
It's always easier to find a reason NOT to do something.....
The sum of all your choices, good and bad, become your life.....
OccupantRJ is offline   Reply With Quote
Old 02-21-2011, 08:48 PM   #20
MP&C
Senior Member
MP&C's Avatar
The Commando 450:
__________________
Robert
MP&C Shop Projects-Metalshaping Tutorials
Super Street/Super Gas 65 Fairlane build
Instagram @ mccartney_paint_and_custom
MP&C is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
