Go Back   The Garage Journal Board > The Garage > Garage Gallery
Reply
Thread Tools Display Modes
Old 01-25-2015, 02:56 PM   #4041
Senior Member
Outlawmws's Avatar
Default Re: The 12-Gauge Garage
Quote:
Originally Posted by Denwood View Post
Shopvac + grinder = fire :-( Don't try this without a water/quench system in place.
Sure, if you fill it full of sawdust first... clean it out or dedicate a small one.
Heck they are wet/dry, put some water in the tank.
__________________
Outlaw's Camp Gear Thread
Outlaw's Shed Thread
Outlaw's Garage Sale
- For sale or trade... Last Update w/new items 8/21/2012 - P9, (More auto books)
Outlaw's Garage sale - Feedback
"It might be for sale or trade, it never hurts to ask..."
Outlawmws is offline   Reply With Quote
Old 01-28-2015, 08:33 PM   #4042
Jack Olsen
Jack Olsen's Avatar
I've thought about putting an elbow there, at least. I guess the advantage of having all those tools together is that it would simplify a vacuum system. I'd just need some place to put the cannister.
The sander is the thing that generates the most debris. But it's not easily rigged for a vacuum.
Jack Olsen is offline   Reply With Quote
Old 01-28-2015, 08:43 PM   #4043
Senior Member
Outlawmws's Avatar
It may not be the most convenient, but if it's plumbed, you can hook up only when you use them, or get a 1 gallon job and use that.
The belt sander just needs a tray, under it connected to the vac hose, and you can probably add a connection to the disc sander lower housing.
__________________
Old 01-28-2015, 10:48 PM   #4044
alpinewhite
Senior Member
Speaking of dust from a sander, have you tried throwing some into your fireplace?
__________________
"Engineering : the 2nd oldest profession"
alpinewhite is offline   Reply With Quote
Old 01-28-2015, 11:55 PM   #4045
Squankum
Senior Member
Squankum's Avatar
Vac canister up on ceiling?
__________________
"I don't vouch for this, but merely repeat what the Libyans say." - Herodotus
Underground Lair of the Squankum
http://www.garagejournal.com/forum/s....php?p=1796399
Squankum is offline   Reply With Quote
Old 01-29-2015, 05:16 PM   #4046
Jack Olsen
Jack Olsen's Avatar
That's something I'm thinking about.
Today, I got the home-made ID plate for the front of the thing. As you can see, it's printed onto an aluminum plate. The fine white print on black didn't come out very well. If I did it again, I'd use bolder type so the black wouldn't bleed in. But for a garage, it'll do fine.
If you read carefully, you can see my 'custom' warning text.
And here it is, ready for some use:
Old 01-29-2015, 05:18 PM   #4047
sean Buick 76
Senior Member
sean Buick 76's Avatar
Awesome, I love it...
__________________
Making do with what I have:
http://www.garagejournal.com/forum/s...8537&showall=1
sean Buick 76 is offline   Reply With Quote
Old 01-29-2015, 07:39 PM   #4048
Senior Member
Outlawmws's Avatar
Love the label mod!
__________________
Old 01-29-2015, 07:42 PM   #4049
Ksullivan
Senior Member
I think the label is a great addition!
Ksullivan is offline   Reply With Quote
Old 01-29-2015, 09:05 PM   #4050
Shadowdog500
Senior Member
Looks like you have grinders for every job. I'm up to three myself.
Quote:
Originally Posted by Outlawmws View Post
Looks good Jack!
Have you considered a shop vac hookup for the big grinder so it doesn't bury the "little" Craftsman? you could use a PVC elbow and Tee and have it come out next to the Craftsman.
I've been doing online research the last few days on different dust collection systems for my Baldor grinder and have seen vacuum systems on a lot of units. There are also a lot of comments that it will start at fire, but I havent seen anything about an actual dedicated bench grinder dust collector fire. When I saw the Baldor dust collection system (shown below). It made me wonder how many grinder fires actually happen since the stuff is discharged into a bag.
Here is a non vacuum dust collector I found on a grinder that I may try to copy with a large ammo can. My dad used two olive oil cans sitting behind the discharge of his bench grinder for years and it worked fine.
Chris
Shadowdog500 is offline   Reply With Quote
Old 01-29-2015, 10:24 PM   #4051
Denwood
Senior Member
Denwood's Avatar
Well, I can tell you from personal experience, that it's pretty easy to start a fire with a grinder, in my case a hand held one. The object of combustion was a pair of overalls.
Coincidently, I was wearing them at the time.
Learned to make better choices in work wear after that :-). Jack, the "easter egg" label is about perfect in my book :-)
__________________
Cheers,
Dennis.
Woody's Works Garage
Denwood is online now   Reply With Quote
Old 01-30-2015, 12:13 AM   #4052
BBChevro
Senior Member
BBChevro's Avatar
The new grinder looks great Jack, I love the "custom" label.
__________________
Mark
A tale of two sheds (and other distractions...)
http://www.garagejournal.com/forum/s...d.php?t=313543
Even duct tape can't fix stupid, but it can muffle the sound.
BBChevro is offline   Reply With Quote
Old 01-30-2015, 04:40 PM   #4053
Craptain
Senior Member
Craptain's Avatar
I love the label on your block grinder. Is that template available?
Sent from my LG-D801 using Tapatalk
__________________
Brute force and applied ignorance can move almost everything.
WWW.TheCaptainCanDoIt.com
Craptain is offline   Reply With Quote
Old 01-31-2015, 07:11 AM   #4054
softailgarage
Senior Member
softailgarage's Avatar
Uh oh, looks like Jack has contracted Blockhead Fever. Nice job,I like it, nothing fancy, but clean. Nice job on the tag too!
__________________
"OK We need more pictures or a puppy dies!!!! " - ratdoggy
"Harbor Freight sucks more than a whore on dollar day. "- panknuckshovel
"WTF are you givin them pain meds? Their "f"ed up enough to start with" - R6 Racer
softailgarage is offline   Reply With Quote
Old 01-31-2015, 07:45 AM   #4055
Tim The Tool Man
Senior Member
Tim The Tool Man's Avatar
In my shop I was able to modify my more modern el-cheapo grinders for dust collection. The shop is more of a woodworking shop but I do do a modest amount of metal work and fabrication. So when I originally laid out the shop I plumed my dust collection system to each of my bench tools and my grinders. In hind sight I realized it wasn't well thought out plan because once I used the grinder with the vac system running and saw all those sparks getting sucked away all I could think of was hot metal sparks and fine saw dust probably don't mix so good! I have since set the hoses up to be temporarily attached to my shop vac as needed.
Anyhow, I really wanted to show how I initially achieved successful dust collection with the grinders. I hope this picture illustrates how I cut some holes in the back of the grinder side guards and used some PVC pipes, elbows, and tees to collect the dust. I scavenged an old vacuum cleaner hose from the side of the road on a garbage day to complete the connection.
Tim The Tool Man is offline   Reply With Quote
Old 02-02-2015, 06:32 AM   #4056
shortykorte
Senior Member
shortykorte's Avatar
Is this a printed decal put on aluminum or printed directly on stock? Great ideal on the fine print.
shortykorte is offline   Reply With Quote
Old 02-02-2015, 10:40 AM   #4057
Jack Olsen
Jack Olsen's Avatar
Quote:
I'll check with the guy who originally made it. If it's okay with him, I'll link a copy.
Quote:
It's printed directly on aluminum. Details:
I got it printed by Bay Photo. Including shipping, it was about $15 -- which is steep relative to the cost of a second-hand grinder, but cheap considering how much the faded decal would have bugged me over the years.
It's a 4"x4" print with 1/8" rounded corners, printed with a gloss finish on aluminum. (Google how to get a 25% discount on your first order, if you use them.) Here's a link:
http://www.bayphoto.com/metal.../sin...and-prices.htm
I used the same type of metal print for the replacement Wilton ID plate I made for one of my vises.
But in that case, I just printed the stuff on a larger sheet and cut it out, which didn't work as well.
Old 02-02-2015, 10:44 AM   #4058
Trey T
Senior Member
Trey T's Avatar
Awesome mod to the name plate. I would like a template for print as well, Jack!
Trey T is offline   Reply With Quote
Old 02-02-2015, 12:16 PM   #4059
Fast914
Senior Member
Fast914's Avatar
Tim, I was looking at your Slat Grid in your post....I bought some as well....mounted to the wall on my garage to better store rakes, shovels, trimmers etc.
I could not see how you hung your tools from your post....can you show a closer pic of what you are using for attachment. Much thanks, Grant
Fast914 is offline   Reply With Quote
Old 02-02-2015, 12:38 PM   #4060
Tim The Tool Man
Senior Member
I found tons of Gridwall hooks and accessories on Amazon. Link.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
