Go Back   The Garage Journal Board > The Garage > Garage Gallery
Reply
Thread Tools Display Modes
Old 03-26-2014, 12:08 PM   #21
rdougan
rdougan's Avatar
Default Re: Townhouse garage in The Netherlands
Thanks everyone!
Quote:
Originally Posted by GrantT View Post
Great looking space, first thing I thought was I hope he goes for a glass wall between the two spaces!
Yes! My wife is still a little... sceptical of the glass wall. But I think it will really work. In my head, I see the garage extending out from the kitchen/living area, and there maybe even being a TV/sofa in there. And with the floor and one of the walls having the same finish, it will look like 1 long space. Exciting!
My only concern is any fumes when driving into the garage. The car isn't driven much really, mostly a track car (bicycle is the main form of transport here). So that helps. But I might mount a massive extractor onto the garage door which I can switch on for 10-15 minutes when the car drives in.
rdougan is offline   Reply With Quote
Old 03-26-2014, 02:46 PM   #22
rydeshed
Senior Member
rydeshed's Avatar
I love the idea. The garage extends into your home... a dream that I thin we all have!
__________________
Dave
Machospelaeologist
Specialising in photographing, blogging about, and wasting time in man caves, sheds, garages, workshops and similar.
Making the world a better place, one Shed at a time.
rydeshed is offline   Reply With Quote
Old 03-26-2014, 03:44 PM   #23
GrantT
Junior Member
Building regulations in the UK would have you put a fire door there which would mean the horrible glass with the wire in and a smoke sealing door
GrantT is offline   Reply With Quote
Old 03-26-2014, 04:17 PM   #24
rdougan
rdougan's Avatar
Yup, definitely. And the same in the US too, I believe. The building regulations seem to be very laid back here. I'm more worried about the fumes than a fire. Though I'll have multiple extinguishers and fire alarms just in case.
Old 03-26-2014, 04:29 PM   #25
rdougan
rdougan's Avatar
I've been busy with work so hard to get a lot of time to work on things.
New sewage pipe installed properly and sealed at the bottom. You can see where the washer and dryer will be placed (under the old staircase):
Of course I'll add some nice trim around them at some point..
Ceiling joists also installed on the utility room:
And the uprights for the little nook in the utility room. There will be bins at the bottom (for clothes and rubbish) and then shelves above:
Old 03-26-2014, 06:15 PM   #26
HSpencer
Alliance Member
HSpencer's Avatar
WOW I am thinking what a beautiful place that is and you go and tear it all out!! LOL.
I am seeing some really nice construction work and some very good ideas in the pictures.
"IF" you could get anyone to do that kind of work in the States, you could NOT afford it.
Everything your doing is going to be great!!
Best Regards
Herb Spencer
__________________
My Shop Thread
http://www.garagejournal.com/forum/s...d.php?t=183123
HSpencer is online now   Reply With Quote
Old 03-27-2014, 04:19 AM   #27
andyaus
Senior Member
andyaus's Avatar
Great work looking forward to your updates ....
__________________
My Workshop Build
andyaus is offline   Reply With Quote
Old 03-27-2014, 04:45 PM   #28
rdougan
rdougan's Avatar
Had some time this morning to start putting the insulation on the roof. The boards aren't ridiculously heavy, but enough when you are alone. Can't beat a trust wooden helper:
The joys of working in a very old house; the joists are very randomly space out. Some 65cm, some 70cm, some 80cm. The plasterboard/insulation is 60cm wide, so I'll have to cut little pieces to fit in-between. Horrible..
Got half the garage done today. Only took a few hours as well. And some extra space, which helps!
Old 03-29-2014, 01:49 PM   #29
mattyschopshop
Junior Member
very cool building love the over seas builds
mattyschopshop is offline   Reply With Quote
Old 03-29-2014, 02:42 PM   #30
Hugo L.
Senior Member
Quote:
No kidding, doesn't look like the original design had much of a vapor barrier, nor a (mandatory here) automatic door closer.
I'd be worried about CO2...
Hugo L. is offline   Reply With Quote
Old 04-05-2014, 02:38 PM   #31
rdougan
rdougan's Avatar
This week has been focusing on electrics. All the existing wiring had to be ripped out because a) it was all over the place and b) most of it was very old. Random coloured wire used..
I managed to put in all the circuits for lights, outlets, washer/dryer and gas boiler, and all the old stuff got ripped out.
Here is the downstairs consumer unit. I didn't want to actually remove it from the wall, so I had to work around some things. I managed to keep things fairly tidy though, though I wish I could redo the entire thing...
The water pipes still need to be clipped onto the wall and I'll move them above the meter.
Same goes for all the water pipes going along the wall of the 2 rooms. They'll all be boxed up, too. This is the utility:
Here is the first new light switch! Exciting, as I love the old switches we got. The conduit will be either replaced with some nice material, or we will paint it black.
Old 04-05-2014, 02:39 PM   #32
rdougan
rdougan's Avatar
The barrier will be a large glass wall/door. Good call on the door closer though, that would certainly help.
Old 04-05-2014, 02:46 PM   #33
Sunbimmer
Senior Member
Sunbimmer's Avatar
Maybe this is something for you, they got the old bakelite stuff brand new...
http://www.allbakelite.com/
Sorry guys it's only in Dutch language
__________________
My...
Sunbimmer is offline   Reply With Quote
Old 04-05-2014, 02:57 PM   #34
rdougan
rdougan's Avatar
Wow, thanks! I got all my switches and outlets from here: http://www.bakeliet.nl - and struggled finding other things. But this is great! $$$$$$$
Old 04-05-2014, 03:08 PM   #35
Sunbimmer
Senior Member
Sunbimmer's Avatar
Your welcome, yes it is expensive but very nice stuff
__________________
My...
Old 04-10-2014, 03:27 PM   #36
rdougan
rdougan's Avatar
The garden got a little clean up; getting ready to install the roof window in the future. Had to rip out all the old ivy from the fence and remove it from the 3 soil boxes. It was horrible. The ivy roots were everywhere. Around everything. And then I had to carry it downstairs. Horrible.
The next thing was to give the garage a good clean. It had really gotten out of hand. At the start of the project I had a rule to clean up everything at the end of everyday, but that hadn't happened in about 4 weeks :/ Took my wife and I a full day to clean everything up and organise things. So much better, and so much more space.
This morning I also added the first of the wall insulation in the utility room, and plaster boarded up the final wall in there. It's nice to finally have a enclosed room. I will maybe put the ceiling up tomorrow.
Safety first!
And finally, I started removing the many layers of plaster and paint from the long wall int he garage. We want to go with a brick wall in both the garage and kitchen, and of course it is much cheaper to expose the wall that is there. I'm not sure how promising that idea is though. The wall is pretty ugly. I'll see, though.
Old 05-20-2014, 04:44 PM   #37
rdougan
rdougan's Avatar
A small update..
I've been busy with real (paying) work, so progress on the house has slowed down a little. Some things I've had the chance to work on:
I will need to tile the new WC downstairs, and eventually a new bathroom on our first floor. I thought I'd try tiling a bit upstairs, around a old fireplace, as a way to practise before doing it else where.
The existing tiles on the floor were just sitting there, so we just lifted them up and dumped them:
I lay down some plywood and started laying the tiles:
Finished the floor:
Tiled the wall and then grouted it:
Everything went fairly smoothly. Wasn't difficult, but time consuming and quite dirty. My main problem was that I directly put the tiles and adhesive onto the bricks on the wall. The problem with that is that the wall was very uneven and it meant I had to use a lot of adhesive. If I were to do it again, I'll put some plaster or wood on the wall first, then put the tiles on that.
I'm not 100% happy with the finish, but the other places will be easier.
Next we started sanding down the inside of the main garage door. We plan to replace the glass with regular clear insulated glass. The top 4 rows, and maybe even the 5th, will be glass. I will leave 1 space for an extractor for any fumes.
We aren't sure on the finish yet. Maybe stain it. Maybe just paint it white again (there was about 50 coats on there before). And I'll paint all the fittings and hinges black.
Outside the garage, I put up some fencing in our terrace. The existing fencing was just falling apart so it definitely needed replaced. Gave everything a nice fresh coat of paint too:
I also removed and dumped all the existing decking. I will lay nicer decking when we install the roof window.
And finally, I removed the existing plaster roof from the back room. One of the last remaining dirty, horrible jobs. Very time consuming and fills the place with dust.
And what was left afterwards:
My car needs cleaned almost every time I leave the house. Thankfully, I rarely need to drive the car:
Great for towing. Who would have thought?
And finally, I rinsed out the garage with some water to get rid of some of the dust, as some family were staying over. 3 cars in the garage this week:
Old 05-20-2014, 04:46 PM   #38
rdougan
rdougan's Avatar
Oh, and a picture from the Nurburgring at the weekend:
Old 05-21-2014, 01:01 AM   #39
Crazy Backyard Builder
Senior Member
Crazy Backyard Builder's Avatar
Cool build thread, it is so interesting to see how things are done in other countries. You are making great progress, keep up the good work.
Crazy Backyard Builder is offline   Reply With Quote
Old 05-21-2014, 01:22 AM   #40
rixtrix1
Senior Member
rixtrix1's Avatar
This car guy likes where you get to drive your car, on one of your seldom drives! I'd gladly ride a bike ifI got to drive the 'Ring when I drove the car!
__________________
Ric
Small, Messy Carport to Garage
http://www.garagejournal.com/forum/s...carport+garage
My fab table thread: http://www.garagejournal.com/forum/s...=1#post6191211
1966 Chevelle Malibu drag car. Rebuilding for track/street
1989 Chevy 3/4T Suburban 454; tows anything ,eats gas
1995 GMC G2500 conversion van, to haul our wheelchair boys
2000 Chevy S10 ext. cab, DD
rixtrix1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
