Go Back   The Garage Journal Board > The Garage > Garage Gallery
Reply
Thread Tools Display Modes
Old 07-09-2007, 09:19 PM   #1
d110pickup
Senior Member
Default My New Garage Build
Hey Guys,
Here's my new shop build. I'm using the fittings from Socket Systems and building a "monitor" style barn (also known as a "raised center aisle"). It'll be 30X40 with 10' side walls and a total height of 24'.
My drawings are done in Sketch-up and I can't get the damn things to post.
Here's a few photo's of the work done so far.
Mike
d110pickup is offline   Reply With Quote
Old 07-10-2007, 07:34 AM   #2
PAToyota
Senior Member
PAToyota's Avatar
Send a message via AIM to PAToyota
Default Re: My New Garage Build
You won't be able to post the skp files directly. You'll have to export to a jpg (under the file menu) and then post that.
PAToyota is offline   Reply With Quote
Old 07-10-2007, 10:21 AM   #3
tccracer
Junior Member
I am looking at that system also. I think I will hold off for a few weeks and see how you like it!. Good luck and keep posting!!!
Robin
tccracer is offline   Reply With Quote
Old 07-10-2007, 10:47 AM   #4
d110pickup
Senior Member
Robin,
I'm actually a bit further along but I didn't want to post more photo's at a time than that.
I'll try to post a few more tonight.
I've received all of the fittings from Socket systems and should finish painting them tonight. I've scheduled a shop raising for the 21st of July and I'm hoping to have all of the frames up that day. My timbers and framing lumber will be delivered Thursday and I'll have time to do some pre-cutting before the build day.
Mike
Old 07-10-2007, 02:00 PM   #5
Don T
I've always liked the style of monitor buildings, looking forward to seeing more.
__________________
Don
To see it from the very start...
http://www.garagejournal.com/forum/s...ead.php?t=9601
Follow the progress...
http://www.garagejournal.com/forum/s...ead.php?t=9842
We're All Here Because We're Not All There!
Don T is offline   Reply With Quote
Old 07-10-2007, 09:17 PM   #6
d110pickup
Senior Member
Here's a few more photos. This time of the concrete work and one of the Socket System base plates. Also a shot of the first two pallets of fittings from Socket sys, I think it was 1400 lbs. I finished painting all of the fittings tonight; they're now silver hammer tone.
Mike
Old 07-11-2007, 11:45 AM   #7
tccracer
Junior Member
I assume that you are painting them with some sort of anit-rust stuff?. Are you using PT or did you get some lumber milled?.
My barn is going in just up the road from you in Murphy. I have the land cleared and I want to get started next trip up.
Robin
Old 07-11-2007, 12:44 PM   #8
d110pickup
Senior Member
Robin,
I'm using non-pt'd #1 6x6, the lumberyard is getting them from the treating company but before they are treated. I priced them from a couple of sawmills and the price was about the same; But . . . . the ones from the sawmill weren't kiln-dried nor were they the nominal 6x6 size which means a lot more work for me cutting them down to fit in the sockets.
Mike
Old 07-13-2007, 01:00 PM   #9
tccracer
Junior Member
Thanks for all the good info!.
Robin
Old 07-13-2007, 10:33 PM   #10
d110pickup
Senior Member
Robin,
No problem regarding the info. I'll have more photos after this weekend.
If you want to check out the building on the way to Murphy sometime let me know.
All of the timbers, framing lumber, & OSB was delivered yesterday. Today I cut all of the haunch braces and began cutting the timbers to length; that should take the weekend.
Mike
Old 07-23-2007, 09:02 PM   #11
d110pickup
Senior Member
Here are a few more photo's of the shop build.
The first photo is the sub-assembly of the upper roof and the next are the drill jig for the haunch braces.
So far I'm pretty pleased with the Socket Systems products.
Mike
Old 07-23-2007, 09:20 PM   #12
d110pickup
Senior Member
These should have come before the ones in my previous post.
The first is my version of work smart not hard. The 14" x 21 ft LVL beams were on top of lumber stacks. So I used my car dollies to move them. The other is the 18' scissors lift I bought, I'll sell it when the shop is finished.
Mike
Old 08-03-2007, 07:22 PM   #13
tccracer
Junior Member
Mike,
I am coming North within the next 2 weeks. Think I could get a tour?. I drive through Canton on the way to Murphy.
Robin
Old 08-03-2007, 08:07 PM   #14
Kevin54
Senior Member
Kevin54's Avatar
Need some bigger pics.
Kevin
Kevin54 is offline   Reply With Quote
Old 08-04-2007, 10:49 PM   #15
d110pickup
Senior Member
Robin - PM sent.
Kevin - If you can tell me how to post larger photos I'll do it.
More updates soon hopefully, we're having internet issues.
Mike
Old 08-06-2007, 12:24 PM   #16
comp
Senior Member
can'r what to see more
comp is offline   Reply With Quote
Old 08-09-2007, 08:53 PM   #17
Big Dad
Senior Member
Quote:
Originally Posted by d110pickup View Post
Robin - PM sent.
Mike
Do you know how to use www.photobucket.com ?
Open 2nd window while www.garagejournal.com is open
Load pics in there, click on THE URL spot under photo(it should say"copied")
Then click on reply here ..look at top see tan box with what looks like a mountain ?
click on that , should pop box up, then right click PASTE, THEN OK
THEN SUBMIT REPLY ,should work, try it
Like this !
Big Dad is offline   Reply With Quote
Old 08-12-2007, 06:16 PM   #18
comp
Senior Member
Like this !
sweet ride
Old 08-15-2007, 10:33 PM   #19
john300k
Senior Member
john300k's Avatar
Is that a Stage III Max Wedge or Hemi 64 ? I use to have a 64 Max Wedge 415 HP Belvedere Station Wagon...it would run D Stock automatic...steel body and would pull the front wheels off the ground...SWEET!
john300k is offline   Reply With Quote
Old 08-17-2007, 10:25 PM   #20
d110pickup
Senior Member
OK, I need to get this thread back on track. I'm way behind on posting the photos and giving a little commentary.
These 3 photos are of the first frame going up. I had 10 or 11 friends over a few weeks ago and we spent a day assembling and raising all of the frames. I had cut all of the timbers beforehand.
Mike
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
