Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-14-2011, 05:29 PM   #1
Brad54
Senior Member
Brad54's Avatar
Default Ceiling covering: cheap, good looking, easy to put up?
I did a search, but after 17 pages didn't really see anything.
I'm finishing up the walls in my shop in the next two weeks, and it's time (well-past time, actually) to attend to the ceiling.
The shop is 32x40, with open rafters. The sun passes directly over it from 10am to 6pm, the long way, heating the roof shingles and turning the interior into an oven.
On one corner, I have a 10x10 office with storage loft above it, protruding into the rafters. I have "walled" this loft off with foam panels on the rafter trusses and against the roof trusses (allowing air to the eaves) to make a decent, insulated storage area. It is noticeably cooler there than the rest of the open ceiling.
In the back corner, I have a 4x6 closet with storage above it, and will do the same thing with the foam boards.
For the rest of the shop, it's going to get a basic ceiling with no storage in the rafters.
I'm looking at some kind of metal roofing or siding. Eventually I'll blow insulation into the rafters, but for now, just having a barrier between shop and ceiling will make a huge difference.
What have you guys used to cover your ceiling? Sheet rock is time-consuming, messy and very labor intensive, and by the time you get done with all the other supplies (mud, tape, sand paper, dust masks, paint and supplies) it's expensive.
Any suggestions? I'd like it to look semi-decent, but I'm not a TV studio set.
-Brad
__________________
I'm not arguing: I'm explaining why you're wrong. YOU are the one who's arguing.
Brad54 is offline   Reply With Quote
Old 05-14-2011, 06:21 PM   #2
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
Default Re: Ceiling covering: cheap, good looking, easy to put up?
I'd use a T-Bar grid ceiling. You can get tiles of every description and it will hold insulation.
http://www.google.com/search?hl=en&b...eiling%20tiles
Zeke is offline   Reply With Quote
Old 05-14-2011, 06:47 PM   #3
Jeff Ivers
Senior Member
I recently helped a friend install 29 gauge raised ridge white barn siding tin on his shop ceiling. Came out really nice.
Jeff Ivers is offline   Reply With Quote
Old 05-14-2011, 07:24 PM   #4
TheShrine
Senior Member
TheShrine's Avatar
Easy, cheap, fast and it comes in different colors.
__________________
The "Shrine" Project....
Unfortunately most of my years of pics are missing! PhotoBucket sucks BTW!!
The build http://www.garagejournal.com/forum/s...tbox&showall=1
The finish http://www.garagejournal.com/forum/s...tbox&showall=1
TheShrine is offline   Reply With Quote
Old 05-14-2011, 08:06 PM   #5
Brad54
Senior Member
Brad54's Avatar
Quote:
Is that plastic or metal?
What are the dimensions of each panel? And how much was each panel?
-Brad
__________________
Old 05-14-2011, 08:16 PM   #6
JC23
Senior Member
JC23's Avatar
I used OSB. It's tough, will hold lots of insulation and I had no prob screwing hooks for hangin' lights. I caulked the seams and hit it with semi gloss paint to bounce the lights.
I'd do it again.
JC23 is offline   Reply With Quote
Old 05-15-2011, 09:00 AM   #7
TheShrine
Senior Member
TheShrine's Avatar
-Brad
It is metal. Not the light grade stuff because I used it on some walls as well and wanted it to have the ability to take some bumps. I used both 12 ft & 6 ft panels. Easy to cut w/ everyday circular saw. As for the cost...can't remember but cheap.
__________________
Old 05-15-2011, 09:20 AM   #8
djmartins
Senior Member
I am using 1/4" luan plywood at $10 a sheet nailed with 18ga staples from a nailer.
Painting it all white like the rest of the garage, fill the holes with spackling and sand out and you are good to go.
djmartins is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
