Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-18-2011, 12:36 AM   #1
thumper1
Junior Member
thumper1's Avatar
Default melamine prep for painting
How do you prepare the white melamine cabinets from Lowes to accept paint?
I have tried sanding, priming and paint, all without success. Paint just will not stick to this stuff. Any success stories.
thumper1 is offline   Reply With Quote
Old 05-18-2011, 01:48 AM   #2
dankicksass
Senior Member
dankicksass's Avatar
Default Re: melamine prep for painting
Isn't the attraction of melamine that you don't have to paint it? I'd be inclined to use vinyl dye if I wanted to change the color of the laminate.
dankicksass is offline   Reply With Quote
Old 05-18-2011, 02:43 AM   #3
wantedabiggergarage
Senior Member
How would I prep them? By adding 1/4" plywood to act as a veneer over them.
__________________
Tools DON'T make the mechanic, they make the mechanics job, EASIER!
wantedabiggergarage is offline   Reply With Quote
Old 05-18-2011, 08:27 AM   #4
dadsEH
Senior Member
dadsEH's Avatar
Location: Tangambalanga in the Kiewa valley of North Vic.AU
automotive etch primer...... will stick like sheeit to a blanket!!!
__________________
" send Lawyers,guns,and money......
The shit has hit the fan."
dadsEH is offline   Reply With Quote
Old 05-18-2011, 06:53 PM   #5
tcianci
Senior Member
tcianci's Avatar
Send a message via AIM to tcianci
Look for a product called Zinsser Bullseye 123. Lowes and depot sell it. It is designed specifically for bonding to surfaces like melamine (which is the same material as Formica and other plastic laminates) glass and tile. Don't be alarmed that the stuff seems to peel right off with a fingernail after it dries. Follow label directions, the stuff doesn't reach full bond for about a week after it's applied but can be topcoated soon after application.
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
tcianci is offline   Reply With Quote
Old 05-18-2011, 10:37 PM   #6
kfainf
Senior Member
kfainf's Avatar
tcianci is right. I built some wall cabinets by cutting up a trash find melamine type, RTA tall storage cabinet. I sanded them pretty good first and primed with KILZ, then painted the outsides with Rustoleum. I have had no problems with the paint sticking, and the cabinets have been in use for over a year now. I used the oil based KILZ. Zinser Bullseye 123 is latex based primer and is excellent. I once painted a sheet vinyl floor after sanding then priming with Zinser Bullseye 123. This was intended to be a temporary fix, but held up for six years before replacing the flooring. Zinser Bin is their oil based primer and I have known of some paint contractors using it to prime ceramic tile before repainting bathrooms with no issues.
kfainf is offline   Reply With Quote
Old 05-18-2011, 11:58 PM   #7
thumper1
Junior Member
thumper1's Avatar
Thanks for the info guys.
What grit sandpaper should I end up with? Should I sand the primer also before final paint?
Old 05-19-2011, 06:31 AM   #8
ddawg16
Senior Member
ddawg16's Avatar
I guess you already have the cabinets.....
For future reference....they make more than one color.....I made my cabinets out of gray melamine....the doors were left over from the MIL's kitchen remodel....I painted them the same color.
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 05-19-2011, 06:49 AM   #9
Kevin54
Senior Member
Kevin54's Avatar
What about sanding, then use an adhesion promoter, spray prime with automotive primer, then paint with your choice of paint.
__________________
THE ADDITION
Kevin54 is offline   Reply With Quote
Old 05-26-2011, 04:19 PM   #10
thumper1
Junior Member
thumper1's Avatar
Ok let's see if I have this right.
1.Sand well.......what grit should I use?
2.Prime with the KILTZ or Zinser Bullseye 123........how long to set? should I sand this coat? grit?
3.Paint the final color.........Can I use water base paint over the KILTZ or the 123?
Question.......will the final coat adhere good enough to use blue tape on it as a guide to paint a stripe over it and then be able to pull the tape off? Is the bond going to be good enough not to pull the paint when pulling off the tape?
Old 05-26-2011, 07:57 PM   #11
kfainf
Senior Member
kfainf's Avatar
I just used 120 or 150 grit sandpaper to sand my garage cabinets before priming. I used the regular KILZ because it is oil based and I painted over it with Rustoleum oil base paint. I did not sand my primer coat befor painting over it, but I did let the primer dry for about 36 hours before painting over it. The KILZ is designed to be a primer for oil or latex paint. The Zinser Bullseye 123 is a latex based primer. I know it will work great for latex paint, but I'm not sure if it will work for oil based paint. Hope this helps.
Old 05-27-2011, 10:58 AM   #12
thumper1
Junior Member
thumper1's Avatar
Quote:
Kfainf.......do you think the bond will be strong enough to use blue tape as a stripping guide over the newly painted surface and after painting the strip, will it pull off the paint when removing the tape?
Sorry for beating this question to death, I just don't want to screw this up.
Old 05-27-2011, 11:25 AM   #13
csp
Senior Member
You can find tape that has lower adhesion than the regular blue tape. I don't have the answer to the question about pulling the paint, but there are less sticky tapes than the regular blue stuff.
csp is offline   Reply With Quote
Old 05-27-2011, 01:43 PM   #14
JMURiz
Senior Member
JMURiz's Avatar
123 has worked for me as well, did the kitchen cabinets with it, as a hold-over till we could afford new ones. Even used it to prime/paint some flowery-awful tiles in the kitchen too.
__________________
Nathan
22'x24' detached garage *Outside complete, working on interior*
Various cars and motorcycles to be stored inside.
JMURiz is offline   Reply With Quote
Old 05-27-2011, 03:09 PM   #15
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
Use the green Frog Tape if you can find it. It seems to work better than the blue 3m
stuff for stripes, or general masking off areas. It removes real easy.
Your best option would be to prime using the killz, but let it dry for a few days or a week as suggested before painting. Then tape your stripe and paint that, but remove the tape after a few hours and then let it completely dry.
__________________
-Dipper
20x22 Build Pics: http://s630.beta.photobucket.com/use...e/1_Demolition
dipper is offline   Reply With Quote
Old 05-27-2011, 07:10 PM   #16
kfainf
Senior Member
kfainf's Avatar
Thumper1.... I think I would use the green FROG tape as suggested earlier, but I would let any painted surfaces dry for several days before taping off for stripes. Here is a few pics of the cabinets I built. The outsides are painted with Rustoleum and actually the insides are all painted with some left over latex interior paint. I have had the two green cabinets in use for over a year and the finish is holding up great. The two red ones have been in use for at least ten months and their finish is holding up great also.
Old 05-31-2011, 07:39 PM   #17
thumper1
Junior Member
thumper1's Avatar
Kfainf......Nice job. Was the surface melamine to begin with? Where do you get the green FROG tape? I'm not sure I have seen it in the local box stores.
Old 05-31-2011, 07:46 PM   #18
thumper1
Junior Member
thumper1's Avatar
ddawg.....did you repaint the doors or did you leave the doors gray and paint the rest of the cabinets to match.
Yep already have the cabinets, decided to paint the garage a gray color and would like to paint the boring white to match the rest.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
