Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Here's my new build i started last July (2010).
Area was wooded and hilly. Cleared and graded with a big piece of ledge that was a pain to remove. We kept the big piece of granite on the left in the third pic that was pulled out with many others. Kind of funny watching the big John Deere struggling to move it around. Foundation has 4' frost walls, floor is 5" thick with controlled joints, vapor barrier and fiberglass added for strength. ![]() ![]()
#2 |
Senior Member
I didn't get too many shots inbetween construction as she went up pretty quick.
#3 |
Junior Member
What is your plans for access to the upper level? Im building a similar building.
#4 |
Senior Member
Access to the upper level is a two tier stairway.
#5 |
Junior Member
Looks great! I am planning a similar garage. Do you have any plans you could pass along?
#6 |
Senior Member
jsandlin0803,
Thanks, unfortunately i don't. The original design was kind of changed a bit at the last minuite. The full dormers were added as well as the decision to go with I joists for the floor. I also added and upgraded the additional windows. The transums above the garage doors as well as the doubles on one side and the 3 tier in the front. The lower windows are at 6' for added security/privacy. 2X6 Construction, R19 Insulation for the walls and R30 in the floor. The rim I joists were filled with foil foam board and sealed with spay foam. ![]() ![]()
#7 |
very nice!!!! Can't wait to see you outfit the interior.
#8 |
Junior Member
Thats very nice. What are the plans for the inside finish?
#9 |
Senior Member
Nice. Surprised you insulated the floor. Will the upper level be outside the heating envelope?
__________________
Plan ahead. Sweat the details. My photos: http://www.flickr.com/photos/ratpoison/ |
#10 |
Senior Member
Beautiful Garage.
#11 |
Junior Member
So nice, you're living my dream...
#12 |
Junior Member
Mind sharing your rough cost on this build for materials only?
#13 | |||
Senior Member
Quote:
Half the garage area (left side) will be the "clean" side per say and will be plaster and not sheet rock (Here in New England it's cheaper) the right side, or dirty side will be OSB. There will be no solid seperation between each side. The floor will be epoxied, heat will be 75K BTU Mr. Heater. Compressor will be in vented, waterproof shed mounted on slab outside. Inside on adjacent wall has switched 240V with indicator for power. Airline will be 3/4" black iron pipe plumbed around the shop. A lift may be an added item in the future. The upper floor will be open concept with tounge and grove pineboard. Cathedral ceilings with a post and beam theme. Haven't fully decided on how i want to implement. The upper floors intent will have a small area partitioned for my Amateur Radio "shack". The remaining area will be the Man cave with hardwood floors. Primary heat will be wood with propane as likely secondary. Quote:
Quote:
#14 |
Senior Member
any access to area under stairs for storage ?
#15 |
Senior Member
Very nice build. I like the fully kicked out dormers that really make some good useable space upstairs.
I too was wondering what was going to happen under the stairs. |
#16 |
Senior Member
Lots of great ideas here! I plan to build a 30 by 40 workshop with attic. Doors will be in the long wall, due to my lot layout. Subscribing to keep track of your progress!
Met with my first builder yesterday, so it's starting... |
#17 |
Senior Member
My builder boxed in the stairs. I installed an outlet and above light fixture inside the boxed area which is switched on the outside wall. There will be a door installed for access. I had originaly contemplated having the compressor here but have thrown around a couple of ideas from a small parts paint spray booth with venting to various types of storage. I temporarily have some items stored under the first tier stairway.
What ideas can you guys come up with? |
#18 |
Senior Member
Very nice looking place you have there! I like it very much!
#19 |
Senior Member
Too many to write down. Look at the index on post three of this link. Shopnut did a LOT of good stuff. ..and the stairs ain't bad either.
http://www.garagejournal.com/forum/s...ead.php?t=3148 |
#20 | |
Senior Member
Quote:
Anyway, Here's cutting up the rest of the 16" batts for the rim joist and one of the finished ceiling. ![]()
| Thread Tools | |
| Display Modes | |
