Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-20-2011, 08:05 PM   #1
shocksystems
Senior Member
shocksystems's Avatar
Send a message via MSN to shocksystems
Question Harbor Freight Sand Blast Cabinet - Light Upgrade
I know several members have mentioned upgrading the light on their Harbor Freight blast cabinet to better illuminate the inside of the cabinet.
What are people replacing theirs with? It looks like the light in there now is 2 20W fluorescent tubes.
Before I go looking for something I thought I would ask what has worked for others.
Cheers!
Jim
shocksystems is offline   Reply With Quote
Old 05-20-2011, 10:41 PM   #2
PCO6
Senior Member
PCO6's Avatar
Default Re: Harbor Freight Sand Blast Cabinet - Light Upgrade
My cabinet isn't a HF (it's home made) and I've tried various types of lighting in it. I seem to have had the best luck with a pair of inexpensive halogen spot lights mounted high in each corner.
__________________
PCO6 is offline   Reply With Quote
Old 05-20-2011, 10:57 PM   #3
sscustom
Senior Member
sscustom's Avatar
looking good guys
sscustom is offline   Reply With Quote
Old 05-21-2011, 07:25 AM   #4
Jeff Ivers
Senior Member
Man, that is one nice looking cabinet! Well done!
Quote:
Jeff Ivers is offline   Reply With Quote
Old 05-21-2011, 08:05 AM   #5
PCO6
Senior Member
PCO6's Avatar
Thanks Jeff. It's about 30 years old. I've made some modifications to it over the years and would like to build another one based on what I have learned. A deeper hopper would be the main thing. I set it up for both pressure and syphon feed blasting. The vacume system works well - inexpensive Sop-Vac with a home made water based filter. The lack of gloves in the door probably looks odd. I have long gauntlet gloves that I wear and simply put my arms through the holes. They seal well and it allows me to pass small parts through without opening the door. It's seen a lot of use over the years.
__________________
Old 08-22-2014, 12:16 PM   #6
FORMUD
FORMUD's Avatar
I know digging this up from the past, but I found this while searching lighting ideas........Could you post up some more info on the "Water based filter" For me?
FORMUD is offline   Reply With Quote
Old 08-22-2014, 12:33 PM   #7
PelicanPines
Senior Member
PelicanPines's Avatar
The water based filter is the white bucket with black lid with two hoses on top.
The hose from the box to the bucket is long (into the bucket)... the hose from the bucket to the vac is SHORT into the bucket. Water is about 1/2 way up the bucket... submerging the long hose but not the vac (short) hose. When dust particles go thru that system.. they get trapped in the water.
I have one I purchased a long time ago to do dry wall sanding. Couldn't find a link to one... on a quick search.
__________________
...Sent using real computer equipment, instead of something from a fruit company.
...We have all the tools and knowledge to change it, to fix it, to make it worse... it's up to you.
...Working in my garage is like playing advanced Tetris... Something has to move to get to the next tool.
...For the nuts here... you probably own a wrench to fix yourself.
...This is the most expen$ive free forum on the internet.
...People who think they know everything... are wrong.
PelicanPines is offline   Reply With Quote
Old 08-22-2014, 12:44 PM   #8
PCO6
Senior Member
PCO6's Avatar
FORMUD - Here are a few threads that provide some pictures and an explanation along with some other links. With mine, I use 3" or 4" of water in the white pail and neither hose is below the water level. I understand some others do it differently. I purchased the 2 port plastic lid at Busy Bee Tools but they are pretty easy to make.
Mine creates a cyclone effect above the water line and the sand being heavier than air falls into the water. I use a small 5.5 amp, 4 gallon Shop-Vac without a bag and cabinet is very dust free.
Hope this helps.
http://garagejournal.com/forum/showt...r+dust+control
http://garagejournal.com/forum/showt...dust&showall=1
__________________
Old 08-23-2014, 05:23 AM   #9
1982fxr
Senior Member
1982fxr's Avatar
just turn the shoplights off
1982fxr is offline   Reply With Quote
Old 08-23-2014, 08:36 AM   #10
steel 35
Senior Member
steel 35's Avatar
Quote:
Works for me
steel 35 is offline   Reply With Quote
Old 08-25-2014, 10:20 AM   #11
FORMUD
FORMUD's Avatar
Hope this helps.
Thanks for the info. Now I know what to get. I'll see if I can't find a plastic or metal container with a clamp style lid for easy removal.
I stole your halogen work light set up. Only tried one 150watt light, Definitely going need one coming from the side too.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
