Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-25-2011, 03:28 PM   #1
Mr.Nutcase
Senior Member
Mr.Nutcase's Avatar
Default 1/4 Drive torque wrench. (Differential Preload)
I am rebuilding the differential in transaxle (A131L) .
I need a 1/4 drive torque wrench to measure Preload
GearWrench (KD 85050)
http://www.tooltopia.com/gearwrench-85050.aspx
KD Tools (KD 2955)
http://www.tooltopia.com/kd-tools-2955.aspx
Which is a better choice?
Where is the best place to get the bearings, seals, gaskets/o-rings for the differential?
Does Transgo sell thse parts?
Do they sell good parts?
__________________
cheap tools give me headpain and headaches...... he he
Mr.Nutcase is offline   Reply With Quote
Old 05-25-2011, 03:33 PM   #2
griff99
Senior Member
Default Re: 1/4 Drive torque wrench
Are you going to use it again? If not I'd get the cheaper one, the 2nd one will require less maintenance and won't have to be recalibrated. If you are going to spend the $$$ for the first one and are going to use it again there are other brands I'd look at, specifically PI or CDI. Just my $0.02.
griff99 is offline   Reply With Quote
Old 05-25-2011, 03:43 PM   #3
Mr.Nutcase
Senior Member
Mr.Nutcase's Avatar
Does any one know when it free shipping over 50 bucks?
Thanks......
__________________
Old 05-25-2011, 04:11 PM   #4
BlindViper
Senior Member
Default Re: 1/4 Drive torque wrench. (Differential Preload)
Don't think ur going to have much luck using a click type torque for setting preload. The preload on my front axle pinion was like 27 inch pounds for a new bearing. The gearwrench(click type) starts at 30. The beam type isnt labeled so you might want to check that out.
edit google shows 0-60 in/lb for the kd tools one it would be the one I would buy if I was being cheap. Otherwise I would be looking for a 1/4 snapon torqometer
BlindViper is offline   Reply With Quote
Old 05-25-2011, 04:32 PM   #5
scott37300
Senior Member
There was a thread last week about this, I can't remember what the title was. You can't use a click type for preload. The second one will work good. Tooltopia's free shipping is over 100, it's only like 6 bucks or something for other orders.
I just ordered the gear wrench click type 1/4" torque wrench last week from them and I love it, but it won't work for pre loads.
scott37300 is offline   Reply With Quote
Old 05-25-2011, 04:40 PM   #6
gibbon_guy
Senior Member
You need this Snap-on TE12A or something like it.
gibbon_guy is offline   Reply With Quote
Old 05-25-2011, 05:36 PM   #7
Steve_P
Senior Member
I have the KD beam one, have used it a lot, it works fine, including for pinion brg preload.
Steve_P is offline   Reply With Quote
Old 05-25-2011, 05:37 PM   #8
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Electronic, dial, or beam.......... cannot use a clicker to measure an unknown torque.
Charles
Charles (in GA) is offline   Reply With Quote
Old 05-25-2011, 05:44 PM   #9
t100
Senior Member
t100's Avatar
Quote:
I was taught to use torque meter as in your link, not torque wrench.
__________________
Quote:
Originally Posted by RbrtAWhyt View Post
Next time tell them "Yeah, well, if my aunt had a dick she would be my uncle..."
t100 is offline   Reply With Quote
Old 05-25-2011, 05:53 PM   #10
marcusicp
Senior Member
What torque ranges are typical for bearing preload in most automotive applications? I have been looking for a Snap-On torque meter for a while but I am unsure what range would best suit me.
marcusicp is offline   Reply With Quote
Old 05-25-2011, 06:03 PM   #11
Valkyrie Rider
I bought a good used Snap-On dial type wrench for about $60 on ebay a couple months ago. Measures 0-250 in/lbs.
Valkyrie Rider is offline   Reply With Quote
Old 05-25-2011, 07:39 PM   #12
Buckgnarly
Senior Member
Buckgnarly's Avatar
Quote:
Ford 8.8 is about 15-25 IIRC depending on new or used bearings.
Buckgnarly is offline   Reply With Quote
Old 05-25-2011, 07:46 PM   #13
t100
Senior Member
t100's Avatar
normal range is between 15-35 inch pound.
I've never used it on wheel bearings, only on pinion bearing preload when setting a diff. you want to see a constant drag when turning the pinion.
http://www.youtube.com/watch?v=8APYO2sZyJU
__________________
Old 05-25-2011, 10:19 PM   #14
gibbon_guy
Senior Member
Old timers use the age gauge by the way ;-)
Old 05-25-2011, 10:35 PM   #15
Black89LX
Senior Member
Black89LX's Avatar
as mentioned, in order to measure a preload you will need to use a dial torque wrench
Black89LX is offline   Reply With Quote
Old 05-25-2011, 10:36 PM   #16
Skyline
Senior Member
Skyline's Avatar
This is really the best tool to use. Even better is if you find the version with the second hand that records the maximum torque. I think the model is TE12FUA (FU for follow up hand).
What I really don't get is why Snap-on does not make a 1/2 drive version of this Torque wrench (with a 0-50 in lb range). It's really not ideal to use 2 adapters to get to the 1/2" drive socket you need for the big pinion nut.
__________________
Click on the link below to see the used professional tools at great prices in my eBay store from Snap-on Mac, Matco etc.:
http://stores.ebay.com/ExpertTools?_rdc=1
Skyline is offline   Reply With Quote
Old 05-25-2011, 11:20 PM   #17
Fedwrench
Alliance Member
Fedwrench's Avatar
you need a dial type toque wrench to measure rotational resistance.
It doesn't have to be snap on.
http://www.tooltopia.com/precision-i...-d2f150hm.aspx
__________________
It's not the tools in the toolbox, it's the mechanic who knows how to use them that matters.
KEEP CALM AND RETURN FIRE!!
Fedwrench is offline   Reply With Quote
Old 05-26-2011, 01:00 AM   #18
mtnkrake
Senior Member
How about this?
mtnkrake is offline   Reply With Quote
Old 05-26-2011, 11:56 AM   #19
Skyline
Senior Member
Skyline's Avatar
The problem with that one is that the range is too much. You're going to need to focus on under 30 in lbs, and that's below the accuracy standard for that wrench. Ideally you would want one that's 0-50 in lbs, not 0-150.
But I believe that Precision Instruments makes the torque wrenches for Snap-on. So sure...avoid the mark up.
__________________
Old 05-26-2011, 12:02 PM   #20
Skyline
Senior Member
Skyline's Avatar
Quote:
Originally Posted by rotty View Post
While a beam type wrench CAN work, it's tough. With differential pre-load, you're measuring rotating resistance. A dial type with a follow up hand is absolutely the way to go.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
