Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-26-2011, 11:12 AM   #1
bchee
Senior Member
bchee's Avatar
Default Alcohol for silicone caulk
I read you're supposed to use "denatured" alcohol to clean and smooth silicone caulk.
Have you guys had any problems using plain "rubbing" alcohol (isopropyl)?
bchee is offline   Reply With Quote
Old 05-26-2011, 11:17 AM   #2
A_Pmech
A_Pmech's Avatar
Default Re: Alcohol for silicone caulk
Rubbing alcohol is denatured alcohol.
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is online now   Reply With Quote
Old 05-26-2011, 11:22 AM   #3
Zrexxer
Senior Member
Zrexxer's Avatar
"Denatured" means that something poisonous has been added to ethanol to make it undrinkable. Isopropyl alcohol is toxic to consume on its own, and is sometimes used as a denaturing agent. By the very definition, you will only see ethanol described as denatured.
However, I don't know that isopropyl won;t work, try it and see.
__________________
I find some people work harder trying to justify doing things wrong than it would have just taken to do them right to begin with...
Zrexxer is offline   Reply With Quote
Old 05-26-2011, 11:44 AM   #4
bchee
Senior Member
bchee's Avatar
Quote:
I did some searching on this and apparently they are different.
One is ethanol with a denaturant (as zrexxer mentioned), the other is isopropyl.
I'm going to go the store and look at a bottle of this "bead tamer" to see what the exact ingredients are.
http://www.plumbersurplus.com/Prod/G...u=323038313931
I bet it's just an $8 bottle of alcohol. I just have to find out which type of alcohol.
Old 05-26-2011, 11:53 AM   #5
A_Pmech
A_Pmech's Avatar
"Rubbing Alcohol" is actually a little ambiguous. It can be either denatured ethyl alcohol or Isopropanol. Although, Isopropanol is usually associated with the name "Rubbing Alcohol".
Denatured Ethyl Alcohol can be purchased at any hardware store or home center in the paint department.
__________________
Your Finest Hammer
Old 05-26-2011, 01:05 PM   #6
Bevis
Senior Member
Bevis's Avatar
Quote:
Just ran on a moron who stated that he rubbed it on his tongue, by taking a big gulp... Yep they walk amongst us.
Bevis is offline   Reply With Quote
Old 05-26-2011, 01:12 PM   #7
Todd.Brock
Senior Member
Todd.Brock's Avatar
Water, H20, both the denatured non-potable and potable non-grey varieties all work as well
I would use some water and a wet rag to smooth it out. I always use as little caulk as possible on woodwork, etc and work it in with a wet finger and wipe off the excess.
Todd.Brock is offline   Reply With Quote
Old 05-26-2011, 01:33 PM   #8
bullfrog123
Senior Member
bullfrog123's Avatar
I use Windex to smooth caulking. Cheap and readily available.
bullfrog123 is offline   Reply With Quote
Old 05-26-2011, 01:35 PM   #9
diggerrick
Senior Member
diggerrick's Avatar
I almost always use rubbing alcohol as a precleaner for caulk and adhesives
When I was messing with R/C cars in the '90's I used to re-cap some of my tires with silicon, and to keep it from sticking I would dip my finger in a cup of water with some dish soap added.
diggerrick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
