Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 05-31-2011, 04:20 PM   #1
Hobbit
Senior Member
Hobbit's Avatar
Default Chemical testing scrap epoxy flooring
I have several pieces of scrap Epoxy-Coat flooring that I had to scrape & peel off of my slab due to it setting to fast on a sun heated slab. I will be conducting chemical exposure experiments and posting before & after photos of each test. I want everyone to chime in on what chemicals they would like me to tryout and how long you think each exposure should be. So far on the list are the usual chemicals found in a garage, Gasoline, motor oil, brake fluid, starting fluid, WD40, beer, stomach acid, stomach acid w/beer. Lets hear it!!!
Hobbit is offline   Reply With Quote
Old 05-31-2011, 06:13 PM   #2
Edger
Senior Member
Send a message via Skype™ to Edger
Default Re: Chemical testing scrap epoxy flooring
Epoxy is pretty tough stuff and is resistant to most nasties, but some will soften it over time. Try brake fluid after 4 hrs and then after 48 hrs. What about Coca Cola for short and long exposure? Try possum piss, but make sure it is male otherwise you might end up with a garage full of them.
Edger is offline   Reply With Quote
Old 05-31-2011, 06:16 PM   #3
tncatadjuster
Senior Member
tncatadjuster's Avatar
why? Unless you have it adhered to a piece of concrete?
tncatadjuster is offline   Reply With Quote
Old 05-31-2011, 07:49 PM   #4
Hobbit
Senior Member
Hobbit's Avatar
My intent here is to test for any drastic changes to the color or wet looking finish. I'm not worried about any changes in it's ability to adhere to the concrete. I have already established that it adheres onto the slab quite well and these pieces still have some attached. As for opossum piss I'll have to wait untill this winter for that test I only catch them in the winter around here. I'm sure dog piss will be coming sooner.
Old 05-31-2011, 07:53 PM   #5
Bad Idea
A combination of brake cleaner and dirty oil can shred some very expensive coatings.
Bad Idea is offline   Reply With Quote
Old 05-31-2011, 07:53 PM   #6
Agusta02
salt, whatever that crap they spray on the roads in the winter(supposed to be pretty nasty stuff).....i cant think of anything else right now
Agusta02 is offline   Reply With Quote
Old 05-31-2011, 08:14 PM   #7
Hobbit
Senior Member
Hobbit's Avatar
I already have a sqaure with brake cleaner & oil in process.
Old 05-31-2011, 08:17 PM   #8
Hobbit
Senior Member
Hobbit's Avatar
Road salts are not a commonly used chemical in Bama.
Old 05-31-2011, 08:38 PM   #9
OceanStateTuning
CRC Brake cleaner (green can)
Dog pee, probably female
OceanStateTuning is offline   Reply With Quote
Old 06-02-2011, 12:13 PM   #10
Candoo
Junior Member
How about rusty nut loosener, that stuff seems quite aggressive.
Candoo is offline   Reply With Quote
Old 06-02-2011, 01:51 PM   #11
dd564
Quote:
We Minnesotan's would still appreciate this type of test!
dd564 is offline   Reply With Quote
Old 06-02-2011, 02:06 PM   #12
rugerlady
Senior Member
I am curious to see the results of your tests! On another note, we have heard regular old yellow mustard is rough on epoxy too!
__________________
Christine McGuire
rugerlady is offline   Reply With Quote
Old 06-02-2011, 02:08 PM   #13
xrdad
Senior Member
xrdad's Avatar
How about fire?
Not sure if you can do that test or not, but I suspect my floor will likely see melted rubber bushings on fire, the odd rag, sparks from the MIG, whatever catches on fire during my car/bike restorations.
Maybe slag from a melted bolt?
__________________
The Sutton Shop build thread
xrdad is offline   Reply With Quote
Old 06-02-2011, 10:17 PM   #14
srode
Senior Member
Quote:
Ok, no more kids with hot dogs in the garage!
I'd definitely like to know what road salt does to it - I'm in trouble here if it's a problem though.
srode is offline   Reply With Quote
Old 06-03-2011, 10:01 AM   #15
rugerlady
Senior Member
Road salt is not a problem. We are in Michigan and know all too well about road salt.
__________________
Christine McGuire
Old 06-03-2011, 02:41 PM   #16
Hobbit
Senior Member
Hobbit's Avatar
I am going to revise my posting of photos to include only those tests that produce an adverse affect on the Epoxy-Coat finish. I have completed several 24hr exposure tests with no affects at all from these chemicals. Motor oils-4 & 2 cycle; engine degreaser; starting fluid; WD40; Liquid Wrench; carb & choke cleaner; brake cleaner; Corona Extra & A/B+blood (mine). Posting photos of tests without negative results would be a waste of space on the site. More tests to come in the future.
Old 06-03-2011, 05:26 PM   #17
pimp-boy
Did you get a chance to try out brake fluid?
pimp-boy is offline   Reply With Quote
Old 06-03-2011, 06:13 PM   #18
Falcon67
Senior Member
Falcon67's Avatar
I used Chemtool to clean stuff off my epoxy floor - never did anything but shine it a bit.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 06-03-2011, 09:18 PM   #19
mrobins297aaa
Senior Member
mrobins297aaa's Avatar
thats great info hobbit, looking forward to more results
mrobins297aaa is offline   Reply With Quote
Old 06-03-2011, 09:41 PM   #20
neonnblack
Senior Member
neonnblack's Avatar
So, eitehr you cut yourself to test the floor or you have supplies of your own blood incase you need it, or youre a vampire.
__________________
Judge if you want, we're all going to die. I intend to deserve it.
neonnblack is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
