Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 06-06-2011, 10:22 AM   #1
JML2
Senior Member
JML2's Avatar
Default Air Compressor/Pump for Inflating Tires
Has anyone any experience with this AC-powered air compressor?
Craftsman 1.5 Gallon Portable Air Compressor with Hose and 8PC Accessory Kit | Sears Item# 00915309000 | Model# 15309
All I want is an AC-powered unit to use for inflating car tires; I do not need a compressor for air tools or painting, and I do not want a 12V inflator. The online reviews are pretty positive, and the competing models from various other sources seem to have plenty of negative reports.
JML2 is offline   Reply With Quote
Old 06-06-2011, 10:47 AM   #2
pipsters
Senior Member
Default Re: Air Compressor/Pump for Inflating Tires
If all you are going to be doing is inflating tires, they have dedicated units out there that will do that. You just hook the hose up and turn the compressor on and it pumps directly into the tire, vs. going into a tank then into the tire. CH makes one I used at the in-laws, it worked well. 120v unit. They are also a lot smaller.
pipsters is offline   Reply With Quote
Old 06-06-2011, 11:49 AM   #3
Todd.Brock
Senior Member
Todd.Brock's Avatar
I have a 2 HP 8 gallon CMAN portable compressor for doing trim work with brad nailers, etc. That thing has to cycle on just to put air in 2 tires. I would get the bigggest you can afford/have room for. Its not normally a huge deal, but they are so damn noisy when they cycle on.
Todd.Brock is offline   Reply With Quote
Old 06-06-2011, 11:53 AM   #4
JML2
Senior Member
JML2's Avatar
I forgot, but in addition to doing 35 PSI for my car, I might as well get a unit that can go up to 120 PSI for road bike tires. Will likely get one of these Prestaflators to go along with the compressor:
The noise from a compressor doesn't bother me, as it'll be used infrequently.
Old 06-06-2011, 05:41 PM   #5
jeb1978
jeb1978's Avatar
I have this same model.
It works OK. Be prepared for it to run or cycle constantly when using it for anything. Works OK for car tires around 30 to 35 psi, seems to struggle when I try to inflate my truck tires to 60 psi. I have a 50' Flexzilla hose hooked to it, which might store more air than the little tank that's on it.
I've used it to inflate an air mattress a few times... it's better than inflating it yourself, but it has to run the pump constantly to keep the air flowing.
Mine is about 7 years old, only problem I've had with it was the hose that connects the pump to the tank burst. A few hose clamps and a section of fuel hose from the local hardware store fixed it. The case is assembled with Torx screws that are buried pretty deep, it takes a screwdriver with a pretty long reach to undo them.
All in all, it has worked for me. I found mine at local Sears on closeout for $25... figured I couldn't go too wrong. I would struggle a bit to pay the full $100 or so it normally lists for... would be better to spend the extra $20 or so to get a compressor with a larger tank.
jeb1978 is offline   Reply With Quote
Old 06-06-2011, 07:36 PM   #6
JML2
Senior Member
JML2's Avatar
Thanks for the information and suggestions! I also found that the Prestaflator website has an almost-hidden page with specs and information about a good number of compressors for this purpose: http://www.prestacycle.com/air_compressors.php
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
