Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 07-27-2007, 09:48 PM   #1
330Scott
Senior Member
Default What is "Swedging"?
I have a rough idea, but need a more thorough explanation of what it exactly is and how & why it is done.
Just curious.
Thanks,
330Scott is offline   Reply With Quote
Old 07-27-2007, 11:54 PM   #2
kenfath
Senior Member
Default Re: What is "Swedging"?
Swedging is the process of changing the diameter of metal tubing. Some of the metal baseball bats are produced using a swedging process. Usually it is done to join two pieces by expanding the the diameter of one piece so another wil slip inside. The only practical example I had was in a refrigeration school many years ago. The assignment was to join or connect two pieces of refrigeration copper tubing. One piece was swedged -- the inside diameter was expanded by driving a punch-like tool inside the tubing that was held in a die-like tool that formed the outside diameter. The other piece of tubing fit inside the swedged end. Next part of the assignment was to solder the joint, which was my first time at soldering copper tubing/piping. Following inspection by the instructor we sawed the joint apart to check the solder penetration. I was very impressed how the solder had flowed into the joint. The lesson learned was soldering copper was easy especially when fittings were used and you didn't have to swedge the tubing.
kenfath is offline   Reply With Quote
Old 07-28-2007, 10:35 AM   #3
lino
Junior Member
I think the proper term is "swage" or swaging. (unless I'm thinking of something else). I believe it's commonly pronounced as you've spelled above though.
Essentially it's uniformly squeezing a pipe or tube. Common usage is to attach fittings on to the ends of wire rope.
Another common usage is in tube fittings. Swagelock is one of the leading brands of high-end fittings, note the name.
For more info:
http://en.wikipedia.org/wiki/Swage
ciao
lino
lino is offline   Reply With Quote
Old 07-30-2007, 07:36 PM   #4
RPH
Senior Member
Another use is the fitting is to clamp cable ends. Allows cable to be looped and locked in place. Think of it as an industrial crimp connector. Done right can be very strong joint.
RPH is offline   Reply With Quote
Old 07-31-2007, 10:38 PM   #5
wilbilt
wilbilt's Avatar
Quote:
lino
Yes, that is the term.
wilbilt is offline   Reply With Quote
Old 08-02-2007, 10:31 AM   #6
v8garage
Senior Member
v8garage's Avatar
It is also a blacksmith term where a "swage" or "swedge" block is used to form hot metal. I think this is probably the older use of the word before it was used in reference to tubing.
v8garage is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
