Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-16-2011, 03:35 PM   #1
DodgeZ
Senior Member
DodgeZ's Avatar
Default Best way to vent a 12x16 shed
I am here in Austin Tx and was wondering what is the best way to vent a shed I am building. Sides and roof aren't up yet. I was looking for ideas. Ridge cap, the spinning vent thing, or just vents on the sides? The shed will house car parts, x-mas crap, close, camping stuff, the push mower, etc...
thanks!
__________________
Quote:
Originally Posted by NC-Fordguy View Post
When I went back into the shop to drive it off the lift, the mechanic tells me the catalytic converter is missing and he was trying to locate one (1966 model Bronco)
DodgeZ is offline   Reply With Quote
Old 06-16-2011, 03:48 PM   #2
NUTTSGT
NUTTSGT's Avatar
Default Re: Best way to vent a 12x16 shed
Most people around here just stick a gable vent in each end. I'm not sure what the exact name of them are. They might be designed for the soffit, but alot of people use them on the sheds. They are aluminum and have window screen on the backside to keep the insects out.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 06-16-2011, 04:44 PM   #3
DodgeZ
Senior Member
DodgeZ's Avatar
I had those on my last shed and they seemed to work pretty good. Here is what I was looking at though.
http://www.gaf.com/Roofing/Residenti...id-Vent-2.aspx
http://www.youtube.com/watch?v=MdYsA3F20Eo
__________________
Old 06-16-2011, 07:13 PM   #4
NUTTSGT
NUTTSGT's Avatar
Oh my, I can't believe GAF used that for advertising. At 3:24, did you see that shingle that was bowed up ?
I used some Owens-Corning ridge vent on the house garage when I built it. It was a roll not rigid link your top link. To use that ridge vent, you'll need some soffit vents, are you going to have room for them in the eaves ?
__________________
ERIC
Old 06-16-2011, 07:27 PM   #5
DodgeZ
Senior Member
DodgeZ's Avatar
the sheds I have looked at lowes and home depot vents down low on the sides. would that work?
__________________
Old 06-16-2011, 11:02 PM   #6
Boyd
Senior Member
My 10x12 has a 5' ridge vent on the roof along with 2 soffit vents (one mounted up high on the left wall and one mounted at floor level on the right wall.
Boyd is offline   Reply With Quote
Old 06-16-2011, 11:57 PM   #7
MikeGyver
Quote:
It won't vent the hot air if they are only on the bottom. One low and one on the opposite side up high would be best.
MikeGyver is offline   Reply With Quote
Old 06-17-2011, 12:05 AM   #8
NUTTSGT
NUTTSGT's Avatar
Along with the ridge vent, it should work.
__________________
ERIC
Old 06-17-2011, 12:59 AM   #9
mmhouse
Senior Member
mmhouse's Avatar
I used ridge venting and a gable vent (I just have one gable) and vented bird blocking in all rafter spaces under the overhangs. It vents very well.
This is the ridge vent I used....
http://www.cor-a-vent.com/v300.cfm
mmhouse is offline   Reply With Quote
Old 06-17-2011, 01:13 AM   #10
22rifle
Senior Member
22rifle's Avatar
There is a measurable difference in temperature between a building with a wind turbine vent and one with a ridge vent. The wind turbine will be cooler.
BTW, I am between Ft. Worth and Hillsboro and work for a shed company.
22rifle is offline   Reply With Quote
Old 06-17-2011, 08:53 AM   #11
billspit
Senior Member
I have gable vents in my shed and its amazing the hot air you can feel coming out of the vents on some days. I've been tempted to find small solar powered fan to add to one end to give it a boost.
billspit is offline   Reply With Quote
Old 06-12-2013, 04:10 PM   #12
NewShockerGuy
Senior Member
NewShockerGuy's Avatar
Arrow Re: Best way to vent a 12x16 shed
Quote:
My shed directions say to put the vent on the left upper side of the shed and then on the back lower wall towards the floor. I have a spare vent, Could I add two upper vents, one on each side (left and right) and then keep the lower vent where they recommend?
Would there be any downfall to having two upper vents and one lower vent?
All three are passive. I can't do ridge vents due to the type of shed I have it's only a single sided roof.
Thanks,
-Nigel
__________________
________
-....-> ~ NSG ~ <-....-
NewShockerGuy is offline   Reply With Quote
Old 06-12-2013, 04:53 PM   #13
Ryf
Senior Member
on the high side you want the vent, which will likely be right over the door, problem with this is the door itself will leak air on most sheds, I would almost say you want two bottom and one top to increase the odds it draws from the low away side. how big a shed and vents are we talking?
Ryf is offline   Reply With Quote
Old 06-12-2013, 05:21 PM   #14
AZ Pete
Senior Member
AZ Pete's Avatar
Two high vents and one low vent will work better for getting the hot air out.
AZ Pete is offline   Reply With Quote
Old 06-13-2013, 02:26 AM   #15
NewShockerGuy
Senior Member
This is what the shed looks like, not a typical design:
This is how they have the one vent on the upper left:
But I figured put one how they have it on the left, and the same on the upper right. Then putting the 3rd vent on the lower back right corner of the shed like they have in the instructions.
Can't really do any type of roof vents because of how the roof is not your typical A frame... so I figure this little guy will probably get hotter in the summer. 10'width by 7.5' in depth. Front most peak is 9' which tapers down to 6' in the rear of the roof.
Thanks,
-Nigel
__________________
________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
