Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 07-02-2011, 10:11 PM   #1
williaty
Senior Member
Default Compressor Petcock Leaking. What can I do about it?
I just bought a new 60gal compressor from Lowes. It took me a couple of weeks to get the wiring and plumbing ready for it and I fired it up for the first time tonight. Ran through the break-in procedure, tested the safety systems, etc. Played with it for a little bit and then shut it off for the night. I opened the drain petcock on the bottom to drain the water and it puked all over the place like it was supposed to. However, when I closed the petcock all the way, it's still hissing very slightly. Every other time I had closed it, it sealed properly. So I opened it a bit and then closed it again. Still hissed. Opened it all the way, let it vent a couple of seconds then closed it again. Still hissing.
Returning this compressor isn't really an option. I'd have to un-do the wiring I soldered together, find a way to lift it back onto my trailer, etc. Is it possible or even a good idea to replace just the petcock? Is there some other trick I'm missing?
williaty is offline   Reply With Quote
Old 07-02-2011, 10:13 PM   #2
Wesley B
Senior Member
Wesley B's Avatar
Default Re: Compressor Petcock Leaking. What can I do about it?
Teflon tape.
Wesley B is offline   Reply With Quote
Old 07-02-2011, 10:13 PM   #3
RivennHewn
Senior Member
RivennHewn's Avatar
Replace it
RivennHewn is offline   Reply With Quote
Old 07-02-2011, 10:14 PM   #4
williaty
Senior Member
Quote:
Originally Posted by Wesley B View Post
Teflon tape.
That makes no sense. It's leaking through the center of the petcock. How would teftape help?
Old 07-02-2011, 10:16 PM   #5
mrb
Senior Member
mrb's Avatar
Quote:
uhh....solder is not an acceptable method of splicing line voltage wiring.
mrb is offline   Reply With Quote
Old 07-02-2011, 10:18 PM   #6
Wesley B
Senior Member
Wesley B's Avatar
And how am I supposed to know it leaking through the center?
Old 07-02-2011, 10:19 PM   #7
Buckgnarly
Senior Member
Buckgnarly's Avatar
Replace it.
Buckgnarly is offline   Reply With Quote
Old 07-02-2011, 10:22 PM   #8
williaty
Senior Member
Quote:
The terrible wiring this was sold with has barely-crimped spade connectors on the motor and pressure switch wiring. I soldered the wire to the to the spade connectors (which are then screwed into the terminals, weird setup from the factory) on the advice of a professional electrician who was worried about the spades loosening due to thermal cycling and (because of the design of the inside of the switch) eventually being able to touch the hots together inside the switch.
Old 07-02-2011, 10:24 PM   #9
ZRX61
Senior Member
ZRX61's Avatar
90deg street elbow, 6-8in nipple, ball valve. sorted.
__________________
Tool Afflictionardo
I'd rather have an "airplane guy" work on my keyboard than have a "keyboard guy" work on my airplane.
ZRX61 is offline   Reply With Quote
Old 07-02-2011, 10:28 PM   #10
Keep
Senior Member
Keep's Avatar
Quote:
x2 after replacing a few on my old compressor, this was the first thing I did on the new one.
Keep is offline   Reply With Quote
Old 07-02-2011, 10:31 PM   #11
KenS
Senior Member
Listen to ZRX61 + coming out of the ball valve attach a hose barb, and add a length of hose to allow you to drain the tank with less mess.
KenS is offline   Reply With Quote
Old 07-02-2011, 10:33 PM   #12
Stephenw
Senior Member
Stephenw's Avatar
Go to home depot and get a new drain valve. While you're at it, extend the drain so you don't have to reach all the way under the tank anymore.
Stephenw is online now   Reply With Quote
Old 07-02-2011, 10:41 PM   #13
j.c.whitney
Senior Member
j.c.whitney's Avatar
ZRX61, that is a good suggestion that merits further investigation. Are those just normal plumbing fittings or something specially rated?
j.c.whitney is offline   Reply With Quote
Old 07-02-2011, 10:42 PM   #14
Zrexxer
Senior Member
Zrexxer's Avatar
Quote:
Just like that, except pass on the little knurled screw-thingy and just get a ball valve like ZRX61 said... quarter turn and it's open, quarter turn and it's closed.
__________________
I find some people work harder trying to justify doing things wrong than it would have just taken to do them right to begin with...
Zrexxer is offline   Reply With Quote
Old 07-02-2011, 10:44 PM   #15
oilslick
Senior Member
take it back or you could install a ball valve its a toss up!!!
oilslick is offline   Reply With Quote
Old 07-02-2011, 10:46 PM   #16
ZRX61
Senior Member
ZRX61's Avatar
Quote:
Just regular plumbing stuff. I used brass.
__________________
Tool Afflictionardo
Old 07-02-2011, 10:50 PM   #17
fr0mastaj
Senior Member
fr0mastaj's Avatar
Default
Definitley remove it and replace with ball valve, nipple, and street elbow as others have said. This was the first thing I did when I bought my kobalt 30 gal a few weeks ago. You can find all these fittings in the plumbing area. I used all 1/4 fittings for mine, not sure what yours uses.
fr0mastaj is offline   Reply With Quote
Old 07-02-2011, 11:06 PM   #18
melliott28
Senior Member
melliott28's Avatar
I agree, this is the best solution. The original drain valve on my very noisy Craftsman was leaky and I replaced it with a couple of street elbows, a ball valve, and a 6 inch nipple. By the way, when I took the original drain off, the only problem was that the o-ring had gotten pushed out of place and wasn't sealing properly. So you may be able to reuse your original drain valve. But, I wouldn't recommend it. Here are pics of mine:
melliott28 is offline   Reply With Quote
Old 07-02-2011, 11:15 PM   #19
welder4956
Senior Member
welder4956's Avatar
Not worth returning it due to the cheap petcock. Replacing the petcock with the same type is not going to last long either. I have the same 60 gal. compressor from Lowes and had already planned to install the elbow, nipple and ball valve because I don't like having to get down on all fours to drain it. I hope you raised yours up off the floor enough to install the elbow. I did not and wound up having to raise it with spacers and change the piping connections to allow for the new height. Do yourself a favor and put the ball valve in. You will not regret the additional small cost.
welder4956 is offline   Reply With Quote
Old 07-03-2011, 12:17 AM   #20
ZRX61
Senior Member
ZRX61's Avatar
It also saves you from getting bitten by the BlackWidow living under the tank..
__________________
Tool Afflictionardo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
