Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 07-12-2005, 06:07 PM   #1
stioc
Senior Member
stioc's Avatar
Default Arbor press usefulness ?
I don't have room for a shop press but I could sure store a 1 ton arbor press.
My question is, how useful are they ? Does anyone here have one ? What do you use them for ? I was thinking I could flatten the ends of roud tubing with it to make chassis braces and for other welding projects ?
I'm thinking about something like this: http://www.harborfreight.com/cpi/cta...temnumber=3552
stioc is online now   Reply With Quote
Old 07-12-2005, 08:44 PM   #2
DynoDave
Senior Member
DynoDave's Avatar
Default
I've often wondered the same thing. I never spent the $ for one, figuring I'd wait until I had room for a hydraulic press.
__________________
DynoDave
WPC #12304
POCI #72200
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
1988 Pontiac Firebird TransAm
DynoDave is offline   Reply With Quote
Old 07-12-2005, 09:52 PM   #3
Glen
Default
I have a 12 ton shop press from Harbor Freight. It's not the perfect tool for any of these jobs but with an assortment of various tubes, rods, and sockets I have been able to use to r&r control arm bushings, ball joints, sub-frame bushings, and bearing races.
IMHO, an arbor press is limited in what it can do because of it's size. What do you want to use it for?
Glen is offline   Reply With Quote
Old 07-12-2005, 10:28 PM   #4
Satatic
Senior Member
Satatic's Avatar
Send a message via AIM to Satatic
Default
The others you can get away with a hammer and socket, but bearing races are definatly a reason to buy a press.
Satatic is offline   Reply With Quote
Old 07-13-2005, 12:16 PM   #5
filthy_shovel
Garageaholic
Default
To me, arbor presses are the way to go. Alot more control and feel when pressing in bearings, shafts, etc.
Would go for a 3 ton model instead. But 1 ton is fine.
fs
filthy_shovel is offline   Reply With Quote
Old 07-13-2005, 12:57 PM   #6
kartracer55
Senior Member
kartracer55's Avatar
Default
You will find arbor presses in most machine shops. They are usuallly used to press a mandrell into something with a hole that is already bored, for turning on a lathe. They are also used to press other shafts in or out of things, like filthy shovel made mention of. Using an arbor press to crush tubing wasnt really in its original design, but hey, I have used it to do that too lol.
Jim
kartracer55 is offline   Reply With Quote
Old 07-13-2005, 09:09 PM   #7
TOMWELDS
Garageaholic
Default
You can get benchtop hyd. presses. Or make one. I made a narrow one to leave at a jobsite were i use it alot. All the tonnage you'll need.
__________________
LICENSED ELECTRICIAN
BAKERY MECHANIC
TOMWELDS is offline   Reply With Quote
Old 07-13-2005, 11:56 PM   #8
stioc
Senior Member
stioc's Avatar
Default
Old 07-14-2005, 03:17 PM   #9
Satatic
Senior Member
Satatic's Avatar
Default
Quote:
Originally Posted by Russell
Haha man just look at harbor freight presses. Buy some steel and a bottle jack. I'll probably make one in the future.
Old 07-14-2005, 06:59 PM   #10
TOMWELDS
Garageaholic
Default
I dont have any pics but at the Hobart site, HankJ is making one and posting alot of pics.
__________________
BAKERY MECHANIC
Old 07-14-2005, 09:59 PM   #11
imported_banzaitoyota
Senior Member
Default
I find an arbor press easier to use when installing bearings and races in various components. I wouldnt trust a cheap-o harbor frieght chi-com POS to have the ram perpendiculiar to the table. The Arbor Press is square and easier to control
imported_banzaitoyota is offline   Reply With Quote
Old 07-27-2005, 08:21 AM   #12
BOSS351C
Garageaholic
Default
I've looked at those harbor freight arbor presses and I would be afraid to put a real strain on it. I would (and am) look for a used Dake if $$ is an issue. My father got one on a big welding table he bought at an auction years back and that thing will take one heck of a beating. I've used that one alot to change u-joints in driveshafts. Way better than a shop press on that job. As far as a shop press, just build your own, you get a lot more for your $$ that way.
BOSS351C is offline   Reply With Quote
Old 02-18-2013, 11:50 PM   #13
e-tek
Senior Member
e-tek's Avatar
Default Re: Arbor press usefulness ?
OUTRAGEOUS! The OP is just looking for an excuse to buy another tool - and you're all enabling him!
....and now I need an Arbor Press too - shit.
e-tek is offline   Reply With Quote
Old 02-19-2013, 12:02 AM   #14
rsanter
Senior Member
rsanter's Avatar
I have a JET arbor press and it's a decent unit, better than I see at HF
Bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 02-19-2013, 12:30 AM   #15
Provincial
Senior Member
Provincial's Avatar
In my experience you will find that a one ton arbor press won't apply much pressure. I have a four ton press and it is pretty limited in what it will do. I used a ten ton Dake in a machine shop years ago, and it was working pretty hard to broach a 1/2" keyway in a sprocket.
I have an older 20 ton American made hydraulic press (25 ton with a 20 ton Hein Werner jack in it) which is quite useful. It isn't so big as to be cumbersome, but does a lot of work! I rarely need a larger press, and can farm out what little work I have of that size.
Provincial is offline   Reply With Quote
Old 02-19-2013, 03:04 AM   #16
dragracer98
Senior Member
I wonder if he got one since it has been a few weeks since his first post.
Randy
__________________
Any man who stands up and puts his life between what is right and wrong, deserves thanks from those he has defended- Author Jack Evans
dragracer98 is offline   Reply With Quote
Old 02-19-2013, 03:25 AM   #17
PCO6
Senior Member
PCO6's Avatar
And you deserve one ... and me too.
I was reading your restoration thread and admiring the work you did on the stainless steel trim. That turned out great. I was wondering if an arbour press would be useful for trim restoration if used with some kind of home made punches and dies made out of hard wood.
I've pressed larger sheet metal peices this way with my hydraulic shop press and they've turned out well. For small trim I would think the faster action of a small hand operated arbour press would be a lot better than using a hydraulic press.
With a shop press I've never felt the need for an arbour press but I'm staring to rethink that ... or justifying the excuse to buy another tool.
__________________
PCO6 is offline   Reply With Quote
Old 02-19-2013, 06:23 AM   #18
Outlander
Senior Member
Outlander's Avatar
Half price at Princess Auto in this weeks flyer. How's that for enablement
__________________
Outlander - Office guy with tools
Can-am Garage
Trailer threads are my favorite!
Outlander is offline   Reply With Quote
Old 02-19-2013, 07:40 AM   #19
PCO6
Senior Member
PCO6's Avatar
Thanks Outlander. At 1 ton that ought to be plenty for what I am thinking of. The throat depth looks to be OK too.
I planned to go to Princess Auto tomorrow. It's less than 5 minutes from where I live. I'm not sure if that's a good thing or not.
__________________
Old 02-19-2013, 08:37 AM   #20
BD1
Senior Member
BD1's Avatar
They work for crushing aluminum cans too.
BD1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rate these in usefulness l_bilyk General Tool Discussion 11 03-19-2006 09:34 AM
