Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 07-11-2011, 02:22 PM   #1
gatchel
Senior Member
Default Sewer Cleanout Driveway cover - Question
I have a pad that is going to be poured in front of my garage that has a sewer clean out in the area to be poured. I was thinking of using a J R Smith Co cover box (4264L04) with a 4 inch clean cap. The issue is that I priced one of these at the local supply house and using a "buddy's" account this clean out and housing cost just under $300. OUCH!
Anyone have any suggestions or other ideas / options that will give similar results.
I like the idea that the above part number isolates the box from the sewer line as far as movement is concerned.
My other option is to just leave the existing clean out and concrete right to the pipe after getting the pipe to the correct level with where the concrete is going to be by cutting out a 2-3 inch section and reconnecting the two with a fernco fitting. The clean out that is there now is cast iron and the pipe that comes out of the ground is 4". The pipe widens at the top and there is a rubber seal/bushing that holds the threaded portion of the clean out in.
Thanks in advance.
gatchel is offline   Reply With Quote
Old 07-11-2011, 02:44 PM   #2
darkk
Senior Member
Default Re: Sewer Cleanout Driveway cover - Question
I just had close to the same problem. A drain for the area between my old garage and new garage. It was right around $300. Better to spend it now and do it right...
darkk is offline   Reply With Quote
Old 07-11-2011, 04:42 PM   #3
Frank The Plumber
Senior Member
Frank The Plumber's Avatar
The issue here is the weight of a car rolling over the clean out that is stubbed up to height.
If the car rolls over the cleanout and pushes it down it will transfer all of the weight down onto the tee in the ground and may crack it.
It's your own home which leaves you a few more options than I would have.
Here is one, Put your clean out below the grade of your drive in a bed of stone excavate a bit of stone and frame in a box in concrete that will have a lip in it for a small section of 1/4" steel plate about 8"x8" pour your frame cut your steel and lay in your peice of steel. Nice and cheap and easy, and it should be durable too.
__________________
Visit My angelfish room at
http://www.facebook.com/pages/Indian...64072983609849
Frank The Plumber is offline   Reply With Quote
Old 07-11-2011, 11:17 PM   #4
70redbee
Senior Member
70redbee's Avatar
Frank has a great idea, I was thinking the same thing. They also make a miniman hole cover made of cast iron. Don't know the cost or the correct name but I would probably go with what Frank suggesred.
70redbee is offline   Reply With Quote
Old 07-11-2011, 11:27 PM   #5
Steves32
Senior Member
Steves32's Avatar
Or just use a Christy concrete box & be done with it.
Steves32 is offline   Reply With Quote
Old 07-12-2011, 12:14 AM   #6
Norcal
Senior Member
Quote:
Make sure it's traffic rated, not good to have a failure after the job is done, I hate rework. Frank the Plumber idea is not a bad one either...
Norcal is offline   Reply With Quote
Old 07-12-2011, 12:41 AM   #7
norcaljr
X2 For a driveway this is fine.
norcaljr is offline   Reply With Quote
Old 07-12-2011, 10:56 AM   #8
Frank The Plumber
Senior Member
You could use a catch basin ring and a catch basin cover that is weight rated.
In this case you would dig a hole bigger than the CB ring. Heavily compact and bed some C7 stone as a base, using concrete bricks and type "N" mortar you would build a support base for the CB ring. You would then add more stone and compact up to the bricks. You then float a mortar base of type N and seat your CB ring on it. Patch the drive to it.
This works well but you need to use a rated cover or it will split. It's a bit large compared to the first one I gave as an example. They both work.
__________________
Old 07-12-2011, 10:58 AM   #9
brownbagg
Senior Member
just use a well cover less than 25 dollars.
brownbagg is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
