Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-20-2007, 09:33 AM   #1
gto65goat
JJG
Default Roofing: How many squares of Shingles needed?
I have a 810 square foot roof (27' X 30') which includes a 1' overhang.
How many squares am I going to need for a 4 /12 pitch roof.
Thank you,
John
gto65goat is offline   Reply With Quote
Old 08-20-2007, 09:41 AM   #2
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
Default Re: Roofing: How many squares of Shingles needed?
3 bundles of 3-tab shingles cover approximately 100 square feet, so my estimate would be 25 bundles, minimum. You'll want to have some extra, espically if you are doing a ridge vent. I would pick up 27 or 28 bundles, but that's just a guess.
__________________
-Dipper
20x22 Build Pics: http://s630.beta.photobucket.com/use...e/1_Demolition
dipper is offline   Reply With Quote
Old 08-20-2007, 10:56 AM   #3
Kevin54
Senior Member
Kevin54's Avatar
If I am reading what you typed right the 27' in the width of the garage x 30' long, and then a 1' overhang on all 4 sides. So if the gable end is on the 27' side and with adding 1' for an overhang, that will make one side of your roof 15.2' approx x 32' long which would be almost 489 square foot. Divide that by 100 and that gives you 4.89 squares of shingles per side or 9.78 square total, so figure 10 square for roofing. For ridge cap, you get 15" of ridge cap per shingle (if that is the way you are going to go) So 32' x 12=384" of ridge divided by 5 (number of inches per ridge shingle) =77 pieces of tabs for ridge cap, so there are approx 25 shingles per bundle x 3 per shingle means you need 1 bundle for ridge cap. And you always want to have a couple of extra bundles on hand for replacement, etc. So if I were you I would pick up 12 square to start with as you need a starter course on each side and you will have some scrap on your ends.
Kevin
Kevin54 is offline   Reply With Quote
Old 08-20-2007, 11:37 AM   #4
boiler7904
Senior Member
boiler7904's Avatar
Take your roof footprint area and multiply by the roof pitch factor (1.06 for a 4/12 roof). Divide that by the actual coverage of the shingles you're using. Average three tabs are usually about 3 bundles per square. Architectural shingles will need up to 6 or 7 bundles per square. Then you need to add in starter strip, ridge / hip shingles, etc.
In your case:
810 sf x 1.06 = 859 sf of roof = 8.6 square
For standard 3 tab shingles: 8.6 square x 3 bundles / square = 26 bundles
For an architectural shingle: 8.6 square x 6 bundles / square = 52 bundles
Don't forget to buy a couple of extra bundles from the same prodcution run to make the inevitable future repair.
EDIT: If your garage has a hip roof, you will need to more shingles than a standard gable roof.
__________________
2004 Ford Escape XLT
2012 Ford Fusion Sport
1997 2 car garage in progress
Quote:
Originally Posted by bmwpower View Post
Oh, and it's BMWPower. I do have powerful BM's but wouldn't want everyone to know all my secrets.
boiler7904 is offline   Reply With Quote
Old 08-20-2007, 01:24 PM   #5
gto65goat
JJG
I really appreciate everyone's reply.
I know it takes some time to do the calculations, so again I "thank you", as this info gives me a much better feeling of what I have (cost wise) in front of me.
John
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
