Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 07-30-2011, 10:16 PM   #1
strnjss
Senior Member
Default Halogen bulb T2.5 vs T3
Hi, I just purchased a replacement halogen bulb for a fixture. What I didn't notice was the new one I got is a T3 halogen 150W bulb, and my old one was a T2.5 150W bulb.
They both look identical, they seem to be the exact same shape, length, ratings etc.
My first question is, what does the T mean? What's the difference between 2.5 and 3?
Also, can I use the T3 bulb I got even though my original bulb was a T2.5?
Thanks!
strnjss is offline   Reply With Quote
Old 07-31-2011, 12:04 AM   #2
Greatbear
Senior Member
Greatbear's Avatar
Default Re: Halogen bulb T2.5 vs T3
Double check the base of the bulbs. If they are the type with pins, the spacing of the pins could be different.
Greatbear is offline   Reply With Quote
Old 07-31-2011, 01:04 AM   #3
strnjss
Senior Member
Well, they look pretty much identical. I put the T3 into the fixture that the T2.5 came from, and it fit fine, it also works fine too.
They are J-type bulbs, like this:
both seem to have the same ends too.
There must be a difference between the two, but I just don't know what.
I wonder that the T designates?
Old 07-31-2011, 06:27 AM   #4
BTC
Location: Lansing, Michigan via Kentucky, Georgia & Tennessee
I believe the T designates the bulb as tubular and the number is the diameter size in eighths of an inch.
BTC is offline   Reply With Quote
Old 07-31-2011, 11:30 AM   #5
strnjss
Senior Member
thanks that makes sense.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
