Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 08-01-2011, 02:45 PM   #1
99tjadams
Junior Member
Default Urethane over epoxy
I am doing an epoxy floor with a heavy chip broadcast and even though you guys recommend urethane the paint supplier i used was worried about how it would react with the epoxy basecoat, so he sold me two part waterbased clear epoxy to go on over the chips. I decidedto go ahead and am now in the middle of the job and just scraped the chips and am about to clear coat.
Question is.... Should i do a urethane over top of the clear expoy as well, and where in canada ( vancouver) can i buy urethane and can it go on in two weeks as i'll be out of town soon or do i need to do it when the clear epoxy is tacky.
99tjadams is offline   Reply With Quote
Old 08-01-2011, 03:49 PM   #2
LegacyIndustrial
Alliance Member
LegacyIndustrial's Avatar
Default Re: Urethane over epoxy
The urethane is a good idea. It would be best if you applied once the clear coat has tacked off (can put your thumb into the floor without leaving an imprint).
We have a great single component urethane that ships to Canada.
http://legacyindustrial.net/cart/hd3...gal-p-179.html
LegacyIndustrial is offline   Reply With Quote
Old 08-01-2011, 05:58 PM   #3
rlitman
Senior Member
The urethane will provide a more slip resistant surface than the clear epoxy if it gets wet.
The epoxy should be dry, before applying the urethane.
edit:
read that as "just dry"
When you can walk on it, it is ready for the next coat. Pretty simple.
rlitman is offline   Reply With Quote
Old 08-01-2011, 09:28 PM   #4
LegacyIndustrial
Alliance Member
Dry yes, fully cured no. You still need the epoxy to chemically bond with the epoxy.
If you move outside the 24 hour cure window a de-gloss will be necessary to obtain a mechanical bond.
Old 08-02-2011, 02:15 PM   #5
thegarageguy
Senior Member
thegarageguy's Avatar
Quote:
Really?? News to me.
__________________
www.bodenkraft.com
Serving NY, NJ & CT
Follow us on:
Twitter: http://twitter.com/Bodenkraft
FaceBook: http://www.facebook.com/Bodenkraft
Pinterest: http://www.pinterest.com/bodenkraft/
Instagram: http://instagram.com/bodenkraft
thegarageguy is offline   Reply With Quote
Old 08-02-2011, 03:12 PM   #6
Cruzin90
Senior Member
How about skipping epoxy and use a polyaspartic instead (it's a 2-part aliphatic polyurea)? It's more durable, better elongation, won't fade.
Cruzin90 is offline   Reply With Quote
Old 08-02-2011, 03:55 PM   #7
thegarageguy
Senior Member
I agree w Cruzin90, but I prefer the epoxy as primer and base coat and like to reserve the polyaspartic as a top coat
__________________
www.bodenkraft.com
Serving NY, NJ & CT
Follow us on:
Old 08-02-2011, 04:43 PM   #8
LegacyIndustrial
Alliance Member
My vote makes three. Polyaspartic is the bomb. Unfortunately it exceeds some budgets.
http://legacyindustrial.net/cart/pol...gal-p-152.html
Old 08-02-2011, 08:48 PM   #9
99tjadams
Junior Member
Thank you all for replying
In the end i should have allready ordered it and it is allready tack free. But i am very very pleased with the floor so far and could not have done it without all the great info on this site, now all thats left is seeing if it holds up. I will plan to use urethane when i do my brothers
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
