Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-11-2007, 07:00 PM   #1
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
Default 16' Garage door Header ??
I'm hoping to be framing the opening for my 16' garage door tomorrow and
have a question about how many 2x4 jack posts will be needed on each side to support it. The header is going to double 2x12 with 1/2" ply glued and nailed in the middle.
I'm thinking 4 on each side would be sufficient. I am going to put a call into the inspector in the morning but he may not get back to me before i get to that point in the framing.
Anybody have any clues on the minimum amount?
Thanks
__________________
-Dipper
20x22 Build Pics: http://s630.beta.photobucket.com/use...e/1_Demolition
dipper is offline   Reply With Quote
Old 09-11-2007, 09:13 PM   #2
Franz©
Default Re: 16' Garage door Header ??
Given the general quality of construction lumber these days the code will probably call for 3 2x4 supports. I'd put in 4 on each side if it was my building though.
Franz© is offline   Reply With Quote
Old 09-12-2007, 12:53 AM   #3
enginerd
Senior Member
I think we have 4 with spacer blocks between the 3rd and 4th for a 12x12 door.
And we have 6x6 posts holding up the 56' truss span
It took us some time to get a custom door built to our specs...definitely not the cheap way to go, but it'll be worth it when it matches everything. hand laid stone, stucco, brick arches, etc...complicated but its all jiving well.
enginerd is offline   Reply With Quote
Old 09-12-2007, 08:19 AM   #4
Lloydthumper
Senior Member
Also depending on where he is located code may require a Laminated Beam depending on the garage design. I have them on mine even though the wall is not load bearing I like things extra strong if I can. I also have 4- 2X6 jack studs supporting it. I have found if you over build something usually the inspectors are more happy. I have 16" of header over my walk through door That was actually to fix a mistake but it turned out really strong.
Lloydthumper is offline   Reply With Quote
Old 09-12-2007, 08:41 AM   #5
gto65goat
JJG
My builder recently added my header ({2} boards 2" x 16" tall) for my 18' x 8' door.
He used (4) 2 x 4's on each end.
gto65goat is offline   Reply With Quote
Old 09-12-2007, 09:52 AM   #6
Falcon05Dad
Falcon05Dad's Avatar
There are four 2x6s supporting each end of a 12" gluelam on my 18'x9' door and three 2x6s on each end on my 10'x10'. Originally it was one less on each side but we added one to correct a goof on the openings.
Greg
Falcon05Dad is offline   Reply With Quote
Old 09-12-2007, 11:55 AM   #7
Kevin54
Senior Member
Kevin54's Avatar
I think it also depends on which way the trusses run. By this I mean is there going to be weight on the header by the trusses or is the header just going to be riding under the trusses. I know that doesn't explain what I mean very well. If the roof slope is towards the header you may be required to have more jack studs, if the slope is to the left and right of the header, then the only weight you will have on the header is the header itself. Still doesn't sound like I explained it correctly
Kevin54 is offline   Reply With Quote
Old 09-13-2007, 11:07 AM   #8
dipper
Senior Member
dipper's Avatar
Well, after measuring it out i ended up going with 5 2x4's on each side to support the double 2x12 header. This still left me enough room in the front wall on both sides to have an exterior light centered.
this is how the garage looked after finishing up wall framing yesterday.
__________________
-Dipper
Old 09-14-2007, 01:09 AM   #9
DanWheeler
here's mine. 16' span. Looks like they put 3 2x6s under the gluelam
DanWheeler is offline   Reply With Quote
Old 09-14-2007, 12:00 PM   #10
Kevin54
Senior Member
Kevin54's Avatar
Does that whole roof slope back towards the rear or am I looking at an optical illusion?
Old 09-14-2007, 12:53 PM   #11
DanWheeler
yep, 15 in the front 8 in the back.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
