Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 08-10-2011, 07:31 AM   #1
toyotadriver
Senior Member
Default 200 amp service wire sizing
Around here, the most common wire size and type that you see for 240 volt service is aluminum 4/0 4/0 2/0 or occasionally you'll see aluminum 4/0 4/0 2/0 2/0.
What is the recommended wire sizes for 200 amp service and why?
Thanks.
toyotadriver is offline   Reply With Quote
Old 08-10-2011, 08:03 AM   #2
chickenhauler
Senior Member
chickenhauler's Avatar
Default Re: 200 amp service wire sizing
I used 3/0 copper for mine. Pricey, but I don't like aluminum wire on or in my house. A lot depends on your electric company. Mine only required 3 lines, and then #6 ground at the service breaker.
chickenhauler is offline   Reply With Quote
Old 08-10-2011, 08:31 AM   #3
Aceman
Senior Member
Quote:
There's nothing wrong with aluminum wire feeding your home.
There are a gazillion homes in the US wired with 4/0 4/0 2/0 AL. But if spending more money on copper helps you sleep at night.....
Aceman is offline   Reply With Quote
Old 08-10-2011, 08:44 AM   #4
ishiboo
Senior Member
Agreed. The terminations of aluminum SE in the main panel have proven basically bulletproof. All the issues were with switch/receptacle connections. Everyone uses aluminum feeders around here.
ishiboo is online now   Reply With Quote
Old 08-10-2011, 10:09 AM   #5
mrb
Senior Member
mrb's Avatar
are you actually speaking to service entrance conductors? Or a feeder?
mrb is offline   Reply With Quote
Old 08-10-2011, 05:56 PM   #6
toyotadriver
Senior Member
My house, built in 2008, has 4/0, 4/0, 2/0 aluminum wire 200 amp service.
Old 08-10-2011, 05:57 PM   #7
toyotadriver
Senior Member
Quote:
Service entrance.
Old 08-11-2011, 12:07 PM   #8
mtne
Senior Member
2011NEC - Table 310.15(B)(7) Service or Feeder rating - 200A - 2/0 copper or 4/0 aluminum
Why? 'Cause it's the code. And you only want three wires for the service entrance.... hot, hot, noodle.........
mtne is offline   Reply With Quote
Old 08-11-2011, 12:10 PM   #9
v8garage
Senior Member
v8garage's Avatar
Thanks.
Where is "around here"?
V/8
__________________
Long live the V/8
______________
WTB: Bonney single offset box-end wrenches. PM me if you have any of these for sale.
v8garage is offline   Reply With Quote
Old 08-11-2011, 12:18 PM   #10
mtne
Senior Member
Quote:
V/8
Good point.......... No idea what code is outside of the USA..... and it can vary depending on where you are which edition is accepted and then it always falls to the AHJ to say what goes.
Shouldn't be too much, or any variance with services tho....
Old 08-12-2011, 06:56 AM   #11
toyotadriver
Senior Member
Around here is MO.
Rural areas have no codes to comply with.
Old 08-12-2011, 07:59 AM   #12
Norcal
Senior Member
Thanks.
That depends what the SE is for... Anything other then a dwelling & it's not correct.
Norcal is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
