Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-13-2007, 02:13 PM   #1
AspDotNetGuy
Junior Member
Default Garage Door Binding or buckling
My garage door binds or buckles when its opening (nearly opened all the way).
Any suggestions to fixing it?
I have craftsman opener with no big springs - there is a chain down the middle and the door is on tracks...
AspDotNetGuy is offline   Reply With Quote
Old 09-13-2007, 07:32 PM   #2
russlaferrera
Senior Member
Default Re: Garage Door Binding or buckling
The springs serve 2 functions. 1 to help lift the door and 2. to help keep it straight in the tracks. When the door is up and binds look and see where and why.
russlaferrera is offline   Reply With Quote
Old 09-13-2007, 08:04 PM   #3
nova65ss
Senior Member
nova65ss's Avatar
Is it buckling in the middle? How wide is it?
__________________
www.garagedoorspecialist.net
nova65ss is offline   Reply With Quote
Old 09-16-2007, 06:38 PM   #4
JohnZ
Senior Member
Sectional door? Plain steel or insulated?
JohnZ is offline   Reply With Quote
Old 09-16-2007, 06:52 PM   #5
thefairlaneman
First disconnect the opener and raise and lower the door by hand so you can feel it when it binds. Lubricate all of the hinges and the rollers. Be sure the tracks for the rollers are clean and not bent.Check for proper side alignment also.
thefairlaneman is offline   Reply With Quote
Old 09-20-2007, 09:40 PM   #6
PhantomEB
Senior Member
PhantomEB's Avatar
Send a message via MSN to PhantomEB
My moms garage door has binded up and buckled as well, but never hooked it back up to the opener over the past 3 years. Last week I extended the tracks so the door now goes up PAST the header, not hanging down 2" below it. NO binding any more, but to guarantee it never does it again, I am capping the top edge with 1.5 angle iron the full length of the door and tieing in the pull point down to the second set of rollers. I THINK this will make it all good once again for mom to be able to use the door opener when she gets her parking spot during the snowy winters once again.
PhantomEB is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
