Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-13-2011, 01:26 AM   #1
roadtripcrazed
Junior Member
Default OVERHEAD DOORS - dealing with vaulted ceilings
First post from a new member!
I am in the initial stages of building a new home and will have my first detached garage/workshop. During the negotiations with my wife, I made it clear that I wanted a nice sized garage with a high ceiling. I am a cabinetmaker by trade and am constantly tinkering on projects, etc.
We ended up having to have the garage built by our home builder due to existing architectural controls in the area ... Too bad, as I wanted to build it myself. In the end, I still get the garage that I wanted, but there is one small quirk.
They refuse to install the two overhead doors so they will follow the 3/12 pitch of the vaulted ceilings.
I know it can be done, but they rattled off some silly explanation of it voiding the warranty or something. So I turn to all of you for advice on changing this setup so it will follow the ceiling and give me optimal ceiling height.
Let me know if you need any more information and I appreciate any assistance that you can provide!
-=D
roadtripcrazed is offline   Reply With Quote
Old 08-13-2011, 01:35 AM   #2
weegaz22
Senior Member
weegaz22's Avatar
Default Re: OVERHEAD DOORS - dealing with vaulted ceilings
Roller Door?
weegaz22 is offline   Reply With Quote
Old 08-13-2011, 01:40 AM   #3
roadtripcrazed
Junior Member
Roller doors are not an option due to architectural controls. These will be standard 4 (8') and 5 (10') panel doors with suspended tracks. Not ideal!
I cannot change the doors, but am more than capable of installing new openers and/or track if necessary.
Old 08-13-2011, 06:29 AM   #4
Matt M, PA
Senior Member
Matt M, PA's Avatar
In one of my bays where the HD9 is, the door and tracks follow a substantial angle. I'd say about 30 degrees or a bit more. The door is the same as the other two in the garage and the tracks have a different curve at the top of the door. Torsion spring.
If it helps, i can snap a pic and post it.
While I don't need an operator for that door, i just put operators by Sommer on the other two, and they told me that as long as their opener is parallel with the track, it can be used on an angle.
Matt M, PA is offline   Reply With Quote
Old 08-13-2011, 10:10 AM   #5
nova65ss
Senior Member
nova65ss's Avatar
-=D
Find a new door company!
__________________
www.garagedoorspecialist.net
nova65ss is offline   Reply With Quote
Old 08-13-2011, 10:25 AM   #6
pattenp
Senior Member
pattenp's Avatar
Look at this post, it has a picture of a high lift door on an angled ceiling. http://www.garagejournal.com/forum/s...light=highlift
The warranty issue is a new one to me. Just raise and angle the tracks.
pattenp is offline   Reply With Quote
Old 08-13-2011, 10:32 AM   #7
v8garage
Senior Member
v8garage's Avatar
Are you saying that the building codes in your area specifically prohibit roller doors? Also if the builder won't work with you get another builder.
V/8
__________________
Long live the V/8
______________
WTB: Bonney single offset box-end wrenches. PM me if you have any of these for sale.
v8garage is offline   Reply With Quote
Old 08-13-2011, 10:33 AM   #8
Conn'swhiterose
Conn'swhiterose's Avatar
I went through the same thing about a month ago....same sob story from every door company in town...."can't do it...blah, blah"...silly b@stards, the impossible only takes longer...
I finally found a private guy that had his head screwed on straight..and he did exactly as I wanted, only in my case the interior slope is 2/12.
He did however, use a heavier than standard spring set up, and we opted for the jackshaft style opener to really reduce any overhead clearance issues....my doors are 16'X8'...here's a couple of shots that I already have on hand..
Hope this helps a little.
__________________
"Just goes to show Nothing shrinks time and distance like cubic inches and a far-out induction system."-1969 Plymouth advertising campaign
Conn'swhiterose is offline   Reply With Quote
Old 08-13-2011, 10:50 AM   #9
roadtripcrazed
Junior Member
We are working with a production home builder, not a custom builder so there are a few limitations in the process. Their unwillingness to install the doors as I would like is likely based on their inexperience in doing it. Most people are fine with the standard install and don't ask questions!
I looked at the post you referred to before posting, but couldn't quite figure everything out. I will wait until the garage is completed and see what I need to do. Once I can get pictures and final measurements, you can all have a better idea of what I am up against.
Enjoying the forum. I will try to post a build log as my garage is built and it evolves over time. It is nothing all that special, an slightly oversized two bay garage with a little extra space for a dedicated woodworking space. Looking forward to it!
-=D
Old 08-13-2011, 10:56 AM   #10
roadtripcrazed
Junior Member
This helps a TON! Thank you for the pictures.
Maybe it's an Alberta issue as we are building in Cochrane and I see you are from Calgary ... builders here always seem a bit hesitant to accommodate unique requests.
Would you be able to tell me who you used to install your doors? I made a few calls around town and came up empty.
-=D
Old 08-13-2011, 11:04 AM   #11
Conn'swhiterose
-=D
Sure I'll send you a PM
__________________
Old 08-13-2011, 12:53 PM   #12
kbs2244
Senior Member
Builders are a conservative bunch.
They don’t like to do things they haven done before.
For sure if it is a “production” builder.
Margins are thin and call backs to fix things can kill any profit.
Go through the threads.
Print out the PICs
You will need different springs and new or custom cut tracks.
I would expect a good local door co. can do it for you.
I think the idea of letting them do it their way and then fixing it to your wants is best.
When you sign off on his “standard” way he is covered legally.
If you start customizing it he can rightly say that you are on your own.
kbs2244 is offline   Reply With Quote
Old 08-13-2011, 03:35 PM   #13
camarotoolman
I have same problem. I've been thinks about cut a piece outof the curved part or the tract, which would change the angle of my ceilng tract to the ceiling. Maybe you could get a throw any tract and try it.
camarotoolman is offline   Reply With Quote
Old 08-13-2011, 06:29 PM   #14
TheShrine
Senior Member
TheShrine's Avatar
I just added an additional spring. Works like a champ.
__________________
The "Shrine" Project....
Unfortunately most of my years of pics are missing! PhotoBucket sucks BTW!!
The build http://www.garagejournal.com/forum/s...tbox&showall=1
The finish http://www.garagejournal.com/forum/s...tbox&showall=1
TheShrine is offline   Reply With Quote
Old 08-14-2011, 09:47 PM   #15
jstroede
Senior Member
It's called roof pitch track. You aren't going to get it at home depot. Most door installers (home builders are not door installers, look for someone that advertises that they do commercial work, they may be more experienced with different track setups) should have no problem with this. Some may be able to do it the field, but since this is a new door they should just order the door from the supplier (again NOT home depot) with the desired roof pitch. The install does not go any different from a standard lift door really.
John
__________________
Garage Door Guru
jstroede is offline   Reply With Quote
Old 08-14-2011, 10:09 PM   #16
koditten
Senior Member
koditten's Avatar
You might not get it at Home Depot, but I got mine at Lowe's. They don't stock the systems, but it only took a week to get mine. Mine uses the stock torsion spring. I see (feel) no difference int the effort to raise the doors by hand. One of my doors is conventional and one is the ceiling hugger.
These should be standard if you have vaulted ceiling in your garage, in my opinion.
koditten is offline   Reply With Quote
Old 08-15-2011, 10:24 AM   #17
Colonial Cobra
Senior Member
Colonial Cobra's Avatar
Mine is the same as the "Shrine project". Works like a champ.
__________________
Brad Drummond
Yorktown, VA
Factory Five Racing, Cobra. FFR2573
Factory Five Racing, Daytona Coupe. FFR3265CP
1967 Mustang GTA Coupe 289 HIPO C-4
1967 Mustang Coupe 5.0 EFI AOD
1969 Mustang Fastback 351W C-6
1984 M923 AM General 6x6 Cargo Truck
1968 Ford 3000 Tractor/ Loader, Gas
1978 Ford 3600 Tractor, Diesel
Ford 340 Skid Steer, Wisconsin VH4D
Garage Addition Project
http://www.garagejournal.com/forum/s...ad.php?t=28390
Colonial Cobra is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
