Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-15-2011, 11:45 AM   #1
larryq
Senior Member
Default Cleaning rusty bolts -- how to keep them rust free after?
I have some rusty bolts from my car that I've either wire-brushed or used vinegar to clean. Now that they're back to bare metal however, they'll flash rust again in no time. And if I put them back under the hood or on the suspension the process will be even quicker.
Short of zinc-plating them professionally is there anything I can do to home rust-proof them to at least some extent?
larryq is offline   Reply With Quote
Old 08-15-2011, 11:49 AM   #2
Alchymist
Senior Member
Alchymist's Avatar
Default Re: Cleaning rusty bolts -- how to keep them rust free after?
Prime and paint, install with a grease-never-sieze mixture.
Alchymist is offline   Reply With Quote
Old 08-15-2011, 11:53 AM   #3
pipsters
Senior Member
Painting is a PITA, spray it with Boeshield T9, or rub a little grease or oil on 'em. They won't rust, to rust you must have air contact.
pipsters is offline   Reply With Quote
Old 08-15-2011, 11:54 AM   #4
4x4gearhead
Senior Member
4x4gearhead's Avatar
Just use, never-sieze and you wont have a problem removing them again.
__________________
How many ratchets will be enough?
4x4gearhead is offline   Reply With Quote
Old 08-15-2011, 11:56 AM   #5
Vinny
Senior Member
There's this new product out that I've seen in all the magazines called Rust Prevention Magic, RPM for short. It's this clear stuff you brush on then heat up and it's supposed to last forever. Google it and check out some articles. They cover steering knuckles and such in it and it holds to normal driving. One tub is supposed to be good for two or three cars.
Vinny is offline   Reply With Quote
Old 08-15-2011, 12:01 PM   #6
Danglerb
Senior Member
Danglerb's Avatar
Use new bolts and put on antisieze.
Danglerb is offline   Reply With Quote
Old 08-15-2011, 12:38 PM   #7
larryq
Senior Member
Quote:
I'll look into everyone's suggestions, thanks. With regard to never-seize or other antiseize products, assuming you don't completely slather the bolts with them is there a risk they'll be prone to coming undone? Any extra torque values needed?
Old 08-15-2011, 12:48 PM   #8
scott4
Senior Member
I like antiseize, and use it on all sorts of stuff that isn't rotating on the bolt. Aluminum is soft. Aluminum oxide is hard and abrasive. I also have a bottle of gear oil open that I might use on the exposed metal - depending.
New bolt may be a good idea as well.
scott4 is offline   Reply With Quote
Old 08-15-2011, 12:51 PM   #9
dwm
Senior Member
Replacing with new fasteners is the right thing to do. Anti-seize so they don't rust in place, unless it calls for loctite.
Note that the manufacturers consider many fasteners one-time use. Suspension fasteners frequently fall into that category. Distorted-thread locknuts are always one-time use (there are many of these on my BMW).
dwm is offline   Reply With Quote
Old 08-15-2011, 12:52 PM   #10
VWandDodge
Senior Member
Quote:
NO! Don't slather the threads. Just dab all around the bottom-most threads or "paint" a light line down the length of the threads. As the bolt is threaded into the hole the Anti-Seize will be worked around and cover the threads sufficiently. It does not affect torque and will not work the fasteners loose. I've been using it on lug nuts and lug bolts for over 20 years and never a problem. I also used it on every nut and bolt in my Ram's engine when I rebuilt it five years ago. I'm getting ready to tear down the engine to replace a faulty head gasket and know that I won't have to wrestle with frozen fasteners.
VWandDodge is offline   Reply With Quote
Old 08-15-2011, 12:53 PM   #11
scott4
Senior Member
Either the torque value changes, or it helps you achieve it easier, and changes what the proper torque is. Maybe someone will chime in on that.
I've used this on many bolts, and haven't had them come undone. You'll need to watch it to be sure.
Old 08-15-2011, 01:04 PM   #12
pipsters
Senior Member
In theory, you would lower the torque applied. In practice, in my experience which is limited to working on my own two cars, it doesn't effect it what so ever in the actual binding of the two parts.
If you are concerned about bolts backing out, such as caliper bolts or something (technically most auto COs call for replacement of those bolts) use loctite, the blue kind. Lube it up nice, the loctite will prevent the bolt from backing out, and it will also serve to seal in the threads and prevent them from rusting/galling. Kinda the best of both worlds.
Old 08-15-2011, 01:12 PM   #13
scott4
Senior Member
Quote:
I'd like to supplement something - because I made a loctite mistake before.
Quote:
271, Red: High strength threadlocker for larger diameter hardware.
262, Red: High strength threadlocker for for hardware smaller than that which uses 271 (more like heli parts). Either does a good job for our stuff, however. I see 271 most commonly in auto parts stores.
609, Green: Retaining compound, high strength, for mounting slip fit bearings to shafts. An appropriate product for tail boxes.
603, Green: Retaining compound, high strength, similar to 609 but good where the parts may be a little oily. Good for mounting oilite bushings in housings, BTW.
640: Green: Retaining compound, high strength. Similar to 609 and 603. Lacks the oil tolerance of 603. I use it where I might have trouble with adjacent bearing contamination with the product, such as start shaft bearing blocks, since it has a little greater viscosity than 603.
638, Green, rather thick: Ultra strong retaining compound for assemblies with a marked amount of slop in the fit, min 0.004". Don't try to use this stuff for our normal bearings on healthy shafts. It sets almost immediately in the tight gap, and you'll never have the chance to get the bearing into place.
290, Green: Wicking product for thread locking AFTER assembly. Medium strength, much stronger than 242 blue in my experience. Not the correct choice per loctite for bearing mounting.
242, 243 Blue: Classic medium strength threadlocker for most of our threadlocking applications. 243 is the oil tolerant version.
222MS, Purple: Low strength threadlocker for small diameter or otherwise delicate fasteners.
Old 08-15-2011, 03:27 PM   #14
Justanoldguy
Senior Member
Justanoldguy's Avatar
Gibbs Product is the best out there.
Check their website.
http://www.gibbsbrandlubricant.com/
Justanoldguy is offline   Reply With Quote
Old 08-15-2011, 03:39 PM   #15
1320stang
Senior Member
1320stang's Avatar
Guys, I think he wants to protect it's looks as well. I.E. the bolt head.
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Old 08-15-2011, 04:21 PM   #16
digdug18
Senior Member
digdug18's Avatar
Location: Williamsport, Pa(school), Ottsville, PA(Home)
I have this problem as well. I'm going the electro-plating route...
http://www.eastwood.com/ew-electropl...-tin-zinc.html
digdug18 is offline   Reply With Quote
Old 08-15-2011, 04:31 PM   #17
alex71
Senior Member
alex71's Avatar
that seems like a lot of trouble just to reuse some bolts. bolts are cheap, relatively speaking.
__________________
ASMC Industrial / WWW.ASMC.NET / 888-660-0334
Fastener distributor featuring USA made Grade 9, 8, 5, Bolts/Nuts/Washers
F
ree shipping on all website orders.
PM me for a coupon code!
alex71 is offline   Reply With Quote
Old 08-15-2011, 04:33 PM   #18
CamarosRus
Senior Member
CamarosRus's Avatar
I am a professional "amateur" classic auto restorer..............
Bolts/Nuts/Hardware need to be replated with Managanese Phosphate. This is easily done in your own shop using safe chemicals sold on line (Palmento for one example). MANG and ZINC Phosphate are not electro plating. They are a heated chem/water solution only done in stainless steel pot on propane camping stove.
You must media blast the fastener first and also wire wheel on your shop grinder (buy wire wheel to replace grinder wheel)
Then to preserve use Fluid Film (yes I'm a dealer) or BoeShieldT-9 are two of the best rust inhibitors. Dont even think about using WD-40 !!!!
I also use Locktite Marine Grade (Dark Gray in Color) Antiseize when I assemble the threads fasteners.....
The rust inhibitor must be reapplied occasionally no matter what
__________________
Chuck Sharin
Auburn,WA (between Seattle & Tacoma
CamarosRus@Gmail.com
ILWU Longshore member
Viet-Nam 68'/69'
Collect/Restore/Judge
69'/70' Camaros
CamarosRus is offline   Reply With Quote
Old 08-15-2011, 05:04 PM   #19
Vinny
Senior Member
Bolts are cheap, but it adds up. I think I spent $200+ replacing all bolts on a Beetle. You could probably drop the price more if you inventory every bolt you take off and order online. In replacing, get the good stuff, too. The highest grades, the best finishes. For SAE, they sell some pretty amazing stuff. I wish McMaster Carr would sell singles, because they have some awesome stuff that you can't find elsewhere.
Old 08-15-2011, 05:32 PM   #20
Danglerb
Senior Member
Danglerb's Avatar
Are you talking about a Parkerizing kit?
http://cgi.ebay.com/ebaymotors/ws/eB...m=370534460579
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
