Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Hey guys,
What do you guys use to paint your garage cabinets? Right now im "trying" to use Rustoleum hammered paint through a HVLP on my custom cabinets i made. Its not working out so hot. This stuff is very hard to get even. I finially figured out to use Penetrol, 4 oz per quart. I think part of it is the heat right now. Its over 100 degrees. Anyway, im thinking abut using a 100% acrylic instead. Like Dunn Edwards Evercoat. This oil based stuff is a PITA to clean and its getting on my nerves. Do you guys spray? roll? |
#2 |
Senior Member
I rolled on Primer and then Rolled on Rustoleum Enamel Paint.
Really Important to get a coat of Primer on First. |
#3 |
Senior Member
Over 100 degrees, your HVLP paint will dry before it hits the surface. High humidity also affects it. Unless you've got a temp controlled environment, I'd wait a month or two till it cools down some to try and paint.
__________________
My garage reorganization thread... http://www.garagejournal.com/forum/s...d.php?t=108382 |
#4 | |
Senior Member
Quote:
I think once the weather gets down to around low 80's ill retry. I'll recut some new panels and try the waterbased stuff this time. I like the hammered look but trying to roll/spray it on has been a real pain. Still curious as to what everyone else does though... |
#5 |
Senior Member
You want lower humidity for air spraying. You also want temps between 70 to 85 max. You also need to make sure that when you cut the paint, that you only use the recommended thinner. It should tell you on the can exactly what to use and the ratios. Mixing spray paints is a lot more tricky than just rolling or brushing. I'm no expert at it for sure, but I've been reading and learning a lot. If in doubt, call Rustoleum support line or your local paint shop and they should be able to tell you. I'm also sure that since you're in AZ, there may be some climate tips since it's super dry there.
__________________
#6 |
Senior Member
I'm spraying mine in HVLP as well, but will be in cooler temps. I have the Rustoleum Professional Gray Primer layed down, but am finishing up the steel workbench before I lay down the Rustoleum Smoke Gray paint from the same HVLP gun. I may opt to scuff sand that and then lay down a coat or two of polyurethane for added protection.
__________________
1970 Mach 1 1970 Mustang Fastback 2003 Mustang 2005 F150 FX4 Licensed Professional Engineer, PE (Civil) Licensed Structural Engineer, SE |
#7 |
Senior Member
When I painted my old cabinets I just wanted them all one color and I'm not too much of a perfectionist when it comes to how they look, anything looks better than they were; beat to death and every one of them were a different color. I just wiped them down with laquer thinner and shot them with Rustoleum Industrial Grey. The key to making Rustoleum lay out nice is to thin it a little more than the recommended 8:1, I do something more in the lines of 4:1. Yes I know I preach to read the directions but this is one time I veer from my words LOL. They still look good after about 5 years seeing as how I didn't do any prep to them.
__________________
Never argue with morons, they will only bring you down to their level and beat you with experience. Lover of all things Chevelle...... oh yeah and chicks gotta love the chicks!! |
#8 |
Senior Member
agree, I had to thin mine quite a bit to get it to lay down. Rustoleum is pretty thick stuff and I think their thinning directions are for brushing and not spraying, but I could be wrong.
__________________
#9 |
Senior Member
I found 8:1 was pretty good with the hammered. I think if it was cooler i might get more of hammered effect then what i was getting since it wouldn't dry so quick. Using penetrol instead of Xylol def gave me more hammered effect. The can does say that you can spray it. Says to thin 1.5 to 2 pints per gallon. Which 2 pints would be 25%, but i hardly got an hammered effect at all at 4:1.
Is there any reason you guys aren't using regular house paint from like sherwin williams or ben moore? You all seem to use rustoleum... |
#10 |
Senior Member
Rustoleum here too, but they were metal kitchen cabinets. Sprayed with my HF HVLP gun - primer then about 3 coats of regal red on the doors and white on the cabinets. Thinned about 5:1.
#11 |
Senior Member
#12 |
Senior Member
My favorite medium duty water based enamel for durability is Krylon Industrial Iron Guard. It sprays well through a HVLP gun (although in 100 degree heat is tough) It doesn't come in a bunch of colors but a gallon goes a long way when spraying. I used it on my Rousseau cabinets ( Vidmar / Lista type) and it has resisted dings & chips and cleans easily.
__________________
"My wife is a Saint for putting up with me because she realizes I will have fully matured when I am dead" My Various Garage Projects: http://garagejournal.com/forum/showthread.php?t=100158 My Welding Table Build: http://garagejournal.com/forum/showthread.php?t=193399 |
#13 |
Senior Member
I like the Tractor Enamel paint by valspar at Tractor supply. I used rustoleum but could not get it to lay flat. I used it thinned 20% with acetone. That is what it said to use on the can?
The TS paint I used the TS thinner. Worked great. |
#14 | |
Senior Member
Quote:
Same here I used the Ford blue on my cabinets since my garage is Ford Themed . I also used a detail gun to spray all of my cabinets . Rick |
#15 |
Senior Member
Its cheap, readily availiable, and as stated most of these are metal cabinets. When it comes to me painting wood I like enamels myself, it has a nice old school look to it and it doesn't peel when you pick at it like latex does. Granted it takes more coats and thus you use more paint but that is just a preferance of mine.
__________________
#16 | |
Senior Member
Quote:
Linda http://www.garagejournal.com/forum/s...d.php?t=107674 |
#17 |
Senior Member
Figured i would post a few pics of what i have done so far...
The panels are Rustoleum Hammered Gray. The posts are Rustoleum Aged Iron Spray Paint. You can see some of the hammered effect in the first pic. What you can't see is that one side of my panel is rougher and not as glossy. Which is the part that bothers me. You cant tell the difference from 3 ft away unless you wipe your hand across it. Im just anal, so it bothers me. The quart of hammered actually go pretty far, but its still $15 a quart. I have a lot of stuff to build and paint so im thinking i might switch it so 100% acrylic paint as its cheaper and i can clean with soap and water. Im not sure i like the color combo either. What do you guys think about red for the panels? Small cabinet panels and posts ![]() Large cabinet panels and posts. ![]() Panels on the right are primed still waiting for paint. ![]() And to help with vizualization a pic of what they look like put together - minus the back board.
#18 |
Senior Member
I painted my wood cabinets first with S&W oil based primer for wood. I then top coated them with the gray Rustoleum oil based enamel rolled on with a foam roller. I chose enamel for the durability and easy cleaning of a gloss finish. Everyone asks if I sprayed them. The foam roller is the key IMO.
#19 |
Senior Member
When I built my workbenches I sprayed Zolatone hammered gray over the plywood doors with my primer gun (larger fluid tip/nozzle). They are now a little over 15 years old and holding up great.
Mike.
#20 |
Senior Member
Stand alone HVLP systems have hot air so the heat problem is compounded. Plus they aren't known for that smooth of a job. I'd look into a cheap pressure pot system. That will move heavier material (even though you should thin it) with cooler air. You can trim a PP to spray with less overspray, not so much a suction system. Gravity systems are in the middle.
If you meant an HVPL gun powered by compressed air, well the hot air point does not apply. |
| Tags |
| cabinets, hvlp, paint |
| Thread Tools | |
| Display Modes | |
