Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 09-22-2007, 04:22 PM   #1
winks2
winks2's Avatar
Send a message via AIM to winks2
Default Help me find an Air Compressor
I live in a fairly small town... Enid, Oklahoma. My wife is in pilot training here. I don't have a lot of stores to choose from here. We have a Sears, and Atwoods, Kmart, Walmart, and a few ACE hardwares... I am looking for an air compressor for my birthday at the end of September, it will go into my 1 car garage. I need the compressor to handle an impact wrench and air ratchet. It doesn't need to be anything that a professional would use, I do however want it to last at least 15 years with weekend warrior use.
I was looking at this craftsman...
http://www.sears.com/shc/s/p_10153_1...+%26+Inflators
I like the size, i am just wondering what other things I have to worry about...
I would prefer it to be right around $200-$300...
Thanks Guys!
winks2 is offline   Reply With Quote
Old 09-22-2007, 05:02 PM   #2
Danglerb
Senior Member
Danglerb's Avatar
Default Re: Help me find an Air Compressor
Thats ballpark size/price I am looking for, but I think its on the edge for capacity, SCFM Delivery At 90 psi:4.9 SCFM. I'm not sure if any modern cheap compressor is going to last 15 years, maybe with a couple repairs, if a repairable unit.
You would have to be doing a heck of a lot of work to run out of air unless you have something like a sander that runs for long periods. 4.9 scfm its going to take some time to fill, and cycle more frequently. Normal 110 vac socket can't deliver much more power than it takes, but I think some compressors are closer to about 6.0 scfm @ 90 psi.
This is also something I would wait for a good sale on.
Danglerb is offline   Reply With Quote
Old 09-22-2007, 05:02 PM   #3
SteveU
Senior Member
SteveU's Avatar
If you KNOW that you will not want to run more than an impact & ratchet the IR Garagemate compressor is a good one. If you think there is any chance that you will want to paint, run cut off's, air die grinders, air sanders, etc. you will want to look into getting something that runs on 220v & is 12+ cfm.
SteveU is offline   Reply With Quote
Old 09-22-2007, 05:20 PM   #4
ColdDuckTime
Senior Member
Personally, I'd look for as quiet a unit as possible.
Not to change the subject, but have you considered buying a small cordless impact plus a plug-in 1/2" one?
ColdDuckTime is offline   Reply With Quote
Old 09-22-2007, 05:31 PM   #5
jimvannoy
Senior Member
I don't think I would count on that one lasting 15 years. The type with the pump/motor built as one unit are not built as well as the separate motor and pump types. Plus on the separate unit types you can replace a motor or rebuild a pump. 26 gallons is also not a lot of capacity if you are doing a lot with it it's going to be running a whole lot and if you ever want to try your hand at painting I would forget it.
jimvannoy is offline   Reply With Quote
Old 09-22-2007, 05:58 PM   #6
goodfellow
Senior Member
goodfellow's Avatar
This is a very "touchy" subject on this kind of board because many of us started out with small units and eventually moved up (serveral times) to ever larger units. I started out in a one car garage; that meant portable air. At the time I went and bought an underpowered Sears direct drive unit that was noisy, annoyed the neighbors and burned up the pump after three years.
My suggestion is to get a good 115v 30 gal unit, with cast iron cylinders and splash lubrication. Two years ago I needed to add air to my new woodshop so I did my homework and decided the best value for my dollar was a Lowes model.
Kobalt
1.6-HP (Running) 30-Gallon Cast-Iron Air Compressor
Item #: 215921 Model: KLA1883054
$379.00
5.7 CFM @ 90 PSI
115 volt motor
3-year warranty on cast iron pump
One-piece cast iron crankcase
Pneumatic wheels for portability
It's a great deal and works quite well. Maybe a bit more than you want to spend, and you might have to make a trip outside your area, but it's one of the largest 115v units on the market.
goodfellow is offline   Reply With Quote
Old 09-22-2007, 06:17 PM   #7
ColdDuckTime
Senior Member
Another answer would be to buy a decent quality, tolerably quiet small unit (Thomas maybe?) that you would plan on using for portable pneumatic tools (nailers) in a few years when you buy the gigando garage model.
Old 09-22-2007, 06:21 PM   #8
Danglerb
Senior Member
Danglerb's Avatar
Guy that put in my rollup garage door used a Dewalt cordless impact, and while it doesn't have huge power, it sure does smaller jobs well. One trip to pick a part could pay for it, or maybe half, since its like $150.
I am watching the used stuff, because many people do step up, and many also buy a nice one for one or two big projects.
Old 09-22-2007, 06:42 PM   #9
winks2
winks2's Avatar
Wow all great ideas! Thanks! I don't think i will be doing any painting. I am part of the craftsman club so i might get that compressor for cheaper who knows. I'm sure i will upgrade in the future but i think for now all i need to do is use my air for blowing, impact wrenching and other small things, I would how ever like to be able to use a die grinder.... Hmmmm... I would love to get an IR... this town is horrible for retail stores, we do have a LOWES though i forgot to mention.
Old 09-23-2007, 02:25 PM   #10
SteveU
Senior Member
SteveU's Avatar
Die grinders are serious air hogs, especially the cheap ones. I have a 5 hp 20 cfm Eaton & my cheap die grinder will pull it down to 100 psi & keep it there with the compressor running nonstop. The Aircat does a lot better & the compressor will pump up to 125 running the die grinder nonstop but that is still a lot of air. Best bet is to get an electric or battery powered one since the air ones use 20+ cfm & with a small compressor you would be waiting far more for it to catch up than you would be working.
Old 09-23-2007, 02:50 PM   #11
chad s
Senior Member
chad s's Avatar
I think I have the same compressor as yours (mine is a 2 stage). I run a die grinder a lot (IR 3102). I dont always hear my compressor as its in the basement in the house, but I know it runs when using a die grinder, but I have never had an issue where I didnt have enough air. Ive never had to stop to wait for the compressor to catch up.
chad s is offline   Reply With Quote
Old 09-23-2007, 03:05 PM   #12
SteveU
Senior Member
SteveU's Avatar
Chad, I was refering to the 115v 5.7 cfm units. I don't have any problem running one either, the example I gave was mashing the button down on one & running it non stop which you wouldn't do when actually working with it. Still don't think anyone with a 115v compressor would get more than a few seconds use out of a die grinder at a time & their compressor would be running nonstop trying to catch up. Doing this often would lead to exceeding the duty cycle & shorten the life of the unit not to mention being very frustrating & unproductive.
Old 09-23-2007, 03:12 PM   #13
chad s
Senior Member
chad s's Avatar
Absolutely agreed!
Old 09-23-2007, 11:51 PM   #14
Danglerb
Senior Member
Danglerb's Avatar
One of the other forums I follow has a lot of head and intake porting guys, and there seems to be an individual preference for air vs AC, so you might want to spend some time with both types before making a choice. Issues I think were speed control, vibration, and comfort/weight of the tools.
Old 09-24-2007, 01:08 AM   #15
Mandres
Senior Member
imo there are a basic guidelines when buying a compressor.
1. Don't even consider a direct-drive unit like that craftsman. They're noisy (ridiculously, ear-piercingly noisy), cheap and aren't built to last. I remember reading that the life expectancy of a direct drive motor / pump is less than half of a belt-driven cast iron pump.
2. Buy used wherever possible. Watch Craigslist, e-bay and local sales / auctions very closely and you just might strike gold. The real deals are for "broken" compressors that people aren't inclined to mess with. I picked up a 2 hp, 25 gal, belt drive Sanborn for $40 because it leaked. A new check valve ($15) and a little paint and it's running great. These are very simple machines to fix, as long as the tank is in good shape.
3. If it's going to live in your garage seriously consider a 230v model. They're more than twice as powerful and that power opens up a much wider range of tools. Sanders, grinders, blasters, painting (especially hvlp), etc. are pretty much unusable on a 5 cfm 120v unit.
Mandres is offline   Reply With Quote
Old 09-24-2007, 03:06 AM   #16
Danglerb
Senior Member
Danglerb's Avatar
Not sure how it would fly as birthday present, but I saw an old Wards Heavy Duty (what isn't according to the label) compressor, obviously a workhorse in a shop environment, with a Doerr motor I assume was a replacement, and I am pretty sure $40 and it would come home with me, but yipes it didn't have a lot of curb appeal.
Old 09-24-2007, 10:24 AM   #17
winks2
winks2's Avatar
Yeah I would love 220V compressor, but I am living in a condo that only has two 120V outlets and its only a one car garage. Their are some other air compressors at Atwoods (like fleet farm) but they aren't brand name by any means... craigslist doesn't even have a city close to Enid on their boards the closest place is Oklahoma City or Stillwater... hmmm. I have been cruising the classifieds but nothing...
Old 09-24-2007, 12:04 PM   #18
wrigh003
Senior Member
wrigh003's Avatar
Send a message via MSN to wrigh003
I bought the Craftsman professional 25gal horizontal, the oil lubricated one that usually runs $400. Got it for $320 because I waited for it to come on sale, one of those online-only midnight-to-6AM sales, then I went and picked it up at the store. When I was looking, it seemed to have the most CFMs for a "portable" (the thing is a PIG, good thing it has nice pneumatic wheels with good bearings on it) compressor. I am not deep deep into the hobby yet, still kinda in the tool collecting phase, but I wanted something that would run just about anything I could throw at it (nailers, etc., as well as impacts, sanders, grinders, and all that other fun stuff). On paper, at least, I think this will do all those things just fine- by the time I need a bigger/more CFM one, I'll probably be building a detached shop for it to live in.
And it's quiet, which is key for everybody's sanity. My current shop is in the basement of my house, and you can just barely hear it kick on/off upstairs.
What you need depends on what you want to do, but since I wasn't sure what all I'd be getting into, I went relatively big, and for now I am happy with it.
wrigh003 is offline   Reply With Quote
Old 09-25-2007, 10:30 AM   #19
winks2
winks2's Avatar
I am really considering the one you got wrigh003. I was always eyeing the professional line. But i never thought about that 10% off between then 12-6AM thing. also i'm hoping that it might be a CC membership discount next month! We'll see!
Old 09-25-2007, 01:39 PM   #20
Mandres
Senior Member
Quote:
Yea, understandable. In that case I'd agree that the two best options are the Sears Professional model mentioned above:
http://www.sears.com/shc/s/p_10153_1...nal+compressor
or the Kobalt 30 gallon at Lowe's:
http://www.lowes.com/lowes/lkn?actio...054&lpage=none
They're both in the $300-400 range but it's worth hunting for a coupon or sale. Lowe's has a 10% coupon for registering on their site: http://www.lowesmoving.com/ and you can get an additional 10% off if you sign up for their credit card. I'm sure Sears has similar deals.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
