Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 08-30-2011, 08:56 PM   #1
gumbudah
Senior Member
gumbudah's Avatar
Default 220v wire colors
i need to set up a 220v circuit. Dont recall what the load is but i think 12 gage will work. So i need a ground and two hot legs. Will std romex with black and white conductors work ordo the make special romex with black red and gnd just for 220v applications?
gumbudah is offline   Reply With Quote
Old 08-30-2011, 09:07 PM   #2
mrb
Senior Member
mrb's Avatar
Default Re: 220v wire colors
i think the red/black romex is a canada thing. in the US you use regular romex and reidentify the white. how do think 12ga is ok when you dont know what the load is?
mrb is offline   Reply With Quote
Old 08-30-2011, 10:23 PM   #3
rlwhitetr3b
Senior Member
rlwhitetr3b's Avatar
[QUOTE=mrb;1716543] reidentify the whiteQUOTE]
Do you mean marking black with either paint or tape?
That is what I remember from the NEC.
rlwhitetr3b is offline   Reply With Quote
Old 08-30-2011, 10:27 PM   #4
Falcon67
Senior Member
Falcon67's Avatar
[QUOTE=rlwhitetr3b;1716743]
Yes - I use a Sharpie to color the ends of the white wire on both ends. That's on like a 220 no neutral motor run.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 08-31-2011, 12:20 AM   #5
Norcal
Senior Member
For 220V wire colors, hot is brown & neutral is blue, & it's 50 hertz. If you want color choices for the US market & 240V you can use any color but green, white, gray, or orange , those colors are the only specified colors in the NEC, any other is trade practice for 240V if in conduit trade practice would be black & red, if using a 2 wire NM cable, re-identify the white as black,red, or blue & one is good to go...
Norcal is offline   Reply With Quote
Old 08-31-2011, 01:56 AM   #6
tfi racing
Senior Member
tfi racing's Avatar
Quote:
Originally Posted by 1969 View Post
They make romex just for 240V. Red and black conductors.
True,but there is no requirement to use it.
tfi racing is offline   Reply With Quote
Old 08-31-2011, 07:14 AM   #7
Senior Member
theoldwizard1's Avatar
Red shrink tubing.
theoldwizard1 is offline   Reply With Quote
Old 08-31-2011, 03:33 PM   #8
ranger_dood
Senior Member
When I wired my stove, the 12/3 romex that I ran had White, Red, Black, and green.
To The OP - you need ground, neutral, and 2 hots. Standard 12/2 romex is not enough... you need 12/3, which has a total of 4 conductors (they don't count ground).
__________________
Ludicrous gibs!
ranger_dood is offline   Reply With Quote
Old 08-31-2011, 03:46 PM   #9
mrbreezeet1
Location: Moundsville, WV, 15 miles South Of Wheeling WV
OP what are we wiring up?
I don't think enough information was given to know if he needs a neutral.
mrbreezeet1 is offline   Reply With Quote
Old 08-31-2011, 03:46 PM   #10
jeffmoss26
Senior Member
jeffmoss26's Avatar
Orange is normally used for 277/480. Never heard you could not use it for anything else?
jeffmoss26 is offline   Reply With Quote
Old 08-31-2011, 03:49 PM   #11
mrb
Senior Member
mrb's Avatar
theres something about orange for high leg. most new 277/480 installs are using yellow purple brown
Old 08-31-2011, 05:07 PM   #12
Senior Member
Quote:
Not true ! There are some, admittedly few, applications where a neutral is not required !!
Your stove requires a neutral because it has some items that run on 120v; timer, light, igniter.
Old 08-31-2011, 05:10 PM   #13
mrb
Senior Member
mrb's Avatar
what the heck kind of stove is 20 amps 120/240?
Old 08-31-2011, 06:53 PM   #14
Norcal
Senior Member
Quote:
Orange is required for marking the high leg of a 120/240V delta system.
Old 08-31-2011, 06:54 PM   #15
nehog
Senior Member
nehog's Avatar
(My thoughts too!)
A really itty-bitty stove?
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
Volvo S80
Holiday Rambler Ambassador 40 DFD
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 08-31-2011, 07:14 PM   #16
jvitez
Senior Member
jvitez's Avatar
Quote:
Originally Posted by Norcal View Post
For 220V wire colors, hot is brown & neutral is blue, & it's 50 hertz. If you want color choices for the US market & 240V......
Am I the only the one that found that really funny? Good one Norcal.
__________________
After the reading of the rich man's last will and testament, the family was asked "How much did he leave?"
The answer: "All of it."
jvitez is offline   Reply With Quote
Old 08-31-2011, 07:55 PM   #17
gumbudah
Senior Member
gumbudah's Avatar
The load is my Ever Eternal EE6503 car lift. On the plate it says 220V 1 ph 60 hz 2.2kw. That means to me a double breaker, and a 10 amp current, so 12 gage should be ok. The lift itself has three conductors, a white black and a white with green. So, I've got it hooked up with the white and black to hot legs and the white/green to ground on a test basis. Seems to work fine.
Old 08-31-2011, 08:21 PM   #18
Senior Member
Quote:
Yep, it should work fine !
However, electricians or inspectors looking in your panel box and seeing a white wire hooked to a breaker will certainly pause.
Red shrink tube or red permanent marker.
Old 09-01-2011, 07:39 AM   #19
nehog
Senior Member
nehog's Avatar
Or most inspectors will accept black tube or black marker. Personally I don't recommend tape, as most of the cheap tape we see today falls off after a few months of sitting. If you use 3M tape (I recommend 88 for marking wires, it is thin and doesn't build up too much) it will last longer.
__________________
Volvo S80
VW Cabriolet
Old 09-01-2011, 11:06 AM   #20
1Garageman
Senior Member
1Garageman's Avatar
Quote:
Originally Posted by nehog View Post
(My thoughts too!)
I wonder if the stove in our new camper runs off of 120v?
I know that kind of out of wack from the conversation here, but that is the only kind of stove I can possibly think of that would be a 120v.
Camper's a 30amp hookup by the way.
__________________
“Life is hard; it's harder if you're stupid.”John Wayne
1Garageman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
