Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Or maybe any Quincy in general...
Q: When the compressor kicks off due to hitting the shut off pressure (150psi in my case), is there a noticeable pressure release sound that is supposed to occur to signify the head is depressurizing? I don't really hear anything like I do on my Craftsman, which make an audible "hiss" after shutting off. I'm gonna be ordering some maintenance parts for mine so I wanted to see if there was something I should be looking to replace.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4 my garage build | my wanted list |
#2 |
Check the parts list for your particular model for an item called Head Unloader. On some machines it may also be called a centrifical unloader.
The Crapsman probably employs an unloader on the pressure switch with little or no muffler on it. Totally different concept from the Quincy. |
#3 |
I believe I found the parts you're talking about...the question is, where do I start?
BTW, I have a hydraulic unloader (loadless starting) if that makes any difference.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4 my garage build | my wanted list Last edited by bmwpower; 09-26-2007 at 10:28 AM. |
#4 |
Senior Member
I would suggest that you don't mess with the head, unless there is a specific reason to do so. I don't hear any sounds when mine shuts off, nor do I ever hear any loss of air, however, I know that the tank will leak down overnight due to the valves in the top of the head leaking. Mine was repaired twice under warranty, and it still isn't any better now than the day that I purchased it. It still isn't any worse either after 15 years, so I call this "a draw". I watched as the service guy took mine apart, cleaned it and reassembled with new parts. It appears that it is a complicated mechanism, because the time that I called for service, they said that there was only one mechanic that did the valve servicing and I would have to wait till he had time to get to my machine. Being a homeowner, they put me at the bottom of the priority list. If it isn't broken, don't fix it....
__________________
Philosopher Emeritus Of Garage Journal Men wake up as good-looking as they went to bed. Women somehow deteriorate during the night. Never argue with an idiot. He'll drag you down to his level, then beat you with experience. |
#5 | |
Quote:
__________________
#6 | |
Quote:
#7 |
Senior Member
The problem may be in the control valve. The valve is located on the side of the crankcase. There should be a 1/4 line from the unloader valve on top of the head going down to the valve on the crankcase. There is a brass valve that gets moved by oil pressure when the compressor starts (thus hyd. operated) Make sure this valve is clean and free.
Oil type makes a lot of difference in this compressor. |
#8 | |
Quote:
The pump builds oil pressure fine. Not sure how to take apart this valve to check things.
__________________
#9 |
It sounds like it is fine. When the head unloads, all pressure is relieved from the top end and the piping between the compressor and the tank. The tank check valve holds the pressure in the tank.
#10 |
Senior Member
I have a set of big Quincys at work and they do not make a big show when unloading. Good stuff.
#11 |
Let it pump up to shutoff.
Pull the electrical disconnect for your safety. Wait a couple minutes. Grab onto the pulley/flywheel, and try turning it over in the proper direction. If you can turn the pulley, the unloader is working. Leave it alone. It's a Quincy they outlive the original buyers generally. Change the oil, and forget it for a year or so. |
#12 |
Maybe I will take a movie of the thing. It's easier when you can hear it yourself.
I agree - leave it alone.
__________________
#13 |
Won't help me a bit, I'm on dialup.
#14 |
Ok. 2 movies. One with video, one only audio?
__________________
#15 | |
Quote:
OK...this may be my problem. With the tank full, I removed the line from the head to the tank...no air loss. There is air coming from the unloader seals up top (8.2). To me that means air is getting past the brass valve you are talking about. No air is supposed to pass this valve when the compressor is OFF right?? It's leaking enough that I can hear it across the garage. Only air should be in that line, correct?
__________________
#16 | ||
Quote:
Quote:
#17 | |
Quote:
__________________
#18 | |
Quote:
If you are losing pressure with the pump stationary, I would assume the valve that is connected to the tank is the culprit. I am not sure why there would be a tank pressure connection, but I am not familiar with Quincy "loadless" starting. |
| Thread Tools | |
| Display Modes | |
