Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-22-2011, 11:31 AM   #1
mondc
Junior Member
Default no wrap over sheathing on new garage
I had a garage built recently and took pictures during the process and noticed that no wrap was put on the garage before installing the vinyl siding. Is this normal? This a small garage 16 x 20. I also opted for no gutters but there is a 12 inch overhang around the garage. Should I have gutters?
mondc is offline   Reply With Quote
Old 09-22-2011, 11:37 AM   #2
Will67
Senior Member
Default Re: no wrap over sheathing on new garage
I would say not having some type of house wrap is not normal, it might depend on your area and climate. I'm in California central valley and pretty much every home I have seen build out here since 1988 or so has had some form of house wrap (tyvek or 15#felt).
Yep I would recommend gutters
Will67 is offline   Reply With Quote
Old 09-22-2011, 11:48 AM   #3
dirttracker18
Senior Member
dirttracker18's Avatar
It is code here. Did you have a permit and get the inspection?
I like gutters, you can direct the water away from the foundation instead of it creating a drip dip in the ground and/or running back to the garage.
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Old 09-22-2011, 12:45 PM   #4
csp
Senior Member
If it's a detached garage and not going to be a conditioned space (heated/cooled), then no wrap is really a requirement, IMO. Housewrap is to control air infiltration and any water that might get past the siding. A detached garage that the builder assumes is for parking cars in doesn't really need air infiltration to be minimized.
csp is offline   Reply With Quote
Old 09-22-2011, 01:07 PM   #5
Falcon67
Senior Member
Falcon67's Avatar
Last shop I built I did not use any wrap. Not really an issue in this climate, can go either way.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 09-22-2011, 01:09 PM   #6
mondc
Junior Member
I did check with my local building code department and they said that the wrap is not required for a garage with unconditioned space.
Old 09-22-2011, 01:11 PM   #7
tcianci
Senior Member
tcianci's Avatar
Send a message via AIM to tcianci
Like others said, it depends on whether or not the space is conditioned. If you're siding is vinyl you need a wrap to protect the sheathing from water and Tyvek won't do that for you. Felt would be best. Also there are new wall sheathng panels that do not require a wrap, they are pre coated at the factory and then a tape engineered especially for the panel is used on the joints.
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
tcianci is offline   Reply With Quote
Old 09-22-2011, 02:03 PM   #8
Gary S
Senior Member
Wrap isn't a code requirement for detatched garages here either, and it isn't a problem even in cold weather. When the sheathing is properly installed, there will be no cracks for air to get through.
Gary S is offline   Reply With Quote
Old 09-22-2011, 02:08 PM   #9
dirttracker18
Senior Member
Quote:
The wrap is not to stop air infiltration it is to stop moisture from reaching the sheathing if it gets under the siding (or whatever the covering is). In a cold climate area the outside walls need to breath so impermeable wrap is not used.
BTW - Post # 1000
__________________
Johnny S.
Old 09-22-2011, 05:38 PM   #10
mpraddict
Senior Member
mpraddict's Avatar
Quote:
Why do you say that? Tyvek is intended for use as a water barrier and it works very well in that capacity under vinyl siding. It is not a vapor barrier.
I agree that you need some type of wrap under vinyl siding, as it is not a sealed system on its own.
__________________
visit the nest ... www.roadrunnernest.com
my garage build
http://garagejournal.com/forum/showthread.php?t=7600
mpraddict is offline   Reply With Quote
Old 09-22-2011, 06:14 PM   #11
K'ledgeBldr
Senior Member
K'ledgeBldr's Avatar
DuPont™ Tyvek® HomeWrap® helps protect a home against damaging wind and rain that can penetrate through the exterior cladding.
The unique nonwoven structure of DuPont™ Tyvek® HomeWrap® blocks excess water from entering into walls.
The breathable structure of this house wrap allows moisture vapor to pass through to help promote drying in wall systems which can aid in preventing the growth of mold and mildew.
The unique non-woven fiber structure of DuPont™ Tyvek® HomeWrap® stops air movement through the walls helping to provide a more energy efficient home.
Taken directly from Dupont's website-
Remember the difference between "housewrap" and "vapor barrier"- as mpr said.
__________________
"Knowledge is the Antidote to Fear."- R.W.Emerson
K'ledgeBldr is offline   Reply With Quote
Old 09-22-2011, 06:15 PM   #12
NitroPress
Senior Member
NitroPress's Avatar
There's also a difference between "water barrier" and "vapor barrier" - most wraps I'm familiar with will block water large enough to be a droplet but permit vapor to pass.
__________________
Si Opus Quadratum vis, angulos praecidere noli.
Admiring your chains doesn't make you free. Go Renegade!
NitroPress is offline   Reply With Quote
Old 09-23-2011, 07:18 AM   #13
jake26
Senior Member
If there is no exterior wrap, is it then necessary to have a vapor barrier on the inside of the walls if they are to be finished (ie: insulated and drywalled)?
jake26 is offline   Reply With Quote
Old 09-23-2011, 07:25 AM   #14
camarotoolman
Tyvel is water proof, I use it for tarps. Also it makes a great termit barrier.
camarotoolman is offline   Reply With Quote
Old 09-23-2011, 07:28 AM   #15
dirttracker18
Senior Member
Quote:
No you need a vapor barrier when finishing regardless of exterior finish but that varies by climate area.
To the OP, are you saying you NEVER plan to heat this space, ever? This is one of those things that is hard to go back and change later. You may not require it for an unconditioned space but I still would have done it. It is relatively cheap to guy and easy to put up. Also a good layer of insurance on your exterior sheathing.
I am not sure why having the space conditioned or not would make a difference in whether it is needed. No logic there since it is to stop moisture from reaching the sheathing from the outside??
__________________
Johnny S.
Old 09-23-2011, 07:38 AM   #16
5lima30
Senior Member
5lima30's Avatar
IMHO I would demand that something like Tyvek (there are several other brands) be installed under the vinyl siding to minimize water infiltration into the sheathing PRIOR to paying for the job. For that size building the cost savings (less than $100.00) does not justify not using house wrap. If water gets past the vinyl, which it will sooner or later, you can plan on the bottom 12"-18" of the sheathing being rotted in 7 years or so. YMMV.
5lima30 is offline   Reply With Quote
Old 09-23-2011, 08:22 AM   #17
Kevin54
Senior Member
Kevin54's Avatar
Quote:
If vinyl is installed correctly you won't get water in behind it. Why would it?
I've seen homes that were vinyl sided years ago with no Tyvek or any type of moisture barrier and the OSB looked as good as the day it was installed.
I never put an wrap on my garage when built and have not had any problems at all and my garage is maybe 10 years old now.
__________________
THE ADDITION
Kevin54 is offline   Reply With Quote
Old 09-23-2011, 07:11 PM   #18
tcianci
Senior Member
tcianci's Avatar
Woah, here we go again! It was great to see the information taken from the Tyvek website. The only thing you're all missing is that where there's liquid water, there's water vapor. PERIOD. Laws of physics, gentlemen. You get water back there, sometime later the water has "dried up". Can you say 'phase change" it simply doesn't disappear, it goes from a liquid to a vapor and where the vapor goes is dependent on on about 2 zillion variables, most of which will bite you in the ass over time. You can all probably search my posts and the endless shit I took for my distaste of Tyvek and other spunbonded olefin house wraps. Let it suffice to say I have made plenty of good weeks pay ripping out rotted sheathing, punky studs and soaked insulation,all because the original contractor (myself included) thought the stuff was Gods gift to the building trade.
One more comment to anyone who thinks vinyl siding is a weather tight assembly... Take a hose to a vinyl house or wait for your basic driving rainstorm. Zip a few courses of the shit off the building and tell me its dry back there
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
