Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-10-2007, 12:10 AM   #1
PoorOwner
Senior Member
Default What is the compressive strength of plywood?
I was wondering, if you put plywood (1/2" or thicker) under jackstands, jacks etc can it handle the load?
Can you use plywood between jack and the chassis instead of a block of 2x4?
What happens when it fails?
PoorOwner is offline   Reply With Quote
Old 10-10-2007, 02:39 AM   #2
Franz©
Default Re: What is the compressive strength of plywood?
The answer depends on the type of plywood.
In today's lumber market there are even good and crap 2x4s
When it fails, it generally fails slowly, and you'll notice the effect of the compression. Jackstands generally have a very small footprint, and exert a lot of pressure per square inch. A piece of 1/8 sheetmetal between the plywood and jackstand would prevent the legs from imprinting and crushing the plywood.
Franz© is offline   Reply With Quote
Old 10-10-2007, 09:08 AM   #3
bthrb4u
Junior Member
bthrb4u's Avatar
i would say that comparable sizes the plywood would be stronger. for the simple fact that a 1x4 or a 1x6 would split alot easier than 1" thick plywood. just my 0.2 cents.
brody
bthrb4u is offline   Reply With Quote
Old 10-10-2007, 01:21 PM   #4
kbs2244
Senior Member
I do it all the time when useing jackstands on an asphalt drivway.
Heavyest thing was a Grand Cherokee.
Use real 1/2 or 3/4 PLYWOOD, not OSB! The OSB will come apart on you when the sharp edges dig into it.
kbs2244 is offline   Reply With Quote
Old 10-10-2007, 01:26 PM   #5
PoorOwner
Senior Member
OK, does it matter if the plywood face is pine or oak? Oak face are pretty and preferred to make cabinets but is it like the real wood where oak is stronger than pine.
Old 10-10-2007, 01:47 PM   #6
W-Cummins
Too much stuff
W-Cummins's Avatar
Quote:
Well other than the face veneer the oak plywood is not likely to be oak. And at the thickness of the face veneers I have seen lately I don't think your going to get much additional strength out of it.
William....
__________________
My Garage Journal shop pictures
1998 Dodge 3500 12 Valve TST 10, 3K GSK, ddp stage IV injectors, SB con-Fe
1987 Chevy 3500 24 valve Cummins, Nv4500, DD#2 injectors, Edge Comp
1955 Ford F100
1941 Chevy Panel
W-Cummins is offline   Reply With Quote
Old 10-10-2007, 04:02 PM   #7
SteveU
Senior Member
SteveU's Avatar
For that get the cheapest grade of real plywood you can. The difference is in the quality of finish, no football looking patches are allowed on the better grades but for what you are doing a C-D grade plywood is the ticket. Face veniers are 1/32" to 1/48" so no strength there. Jackstands will dent into it unless you put metal or similar to spread the load out between the jackstand & the plywood.
SteveU is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
