Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 10-05-2011, 03:11 PM   #1
wasupdu
Junior Member
Default Keeping a 950 sq ft attached garage ABOVE freezing?
Hey guys,
I finally got done finishing off my garage and I'm trying to figure out the most cost effective option to heat my 4.5 car garage. I've insulated and plastered the entire garage including adding about a dozen electrical outlets, can lighting and a light trowel finish to the blue board we put up, but I've changed my mind and I want some sort of heat source now. I've noticed that the temps are significantly warmer than before, but what would you suggest as a relatively inexpensive heat source?
I live in southeastern WI and all that I'm concerned about is keeping the temps ABOVE freezing in the garage. If the garage stayed at 35 degrees (or above) in the winter I'd be a happy camper!
wasupdu is offline   Reply With Quote
Old 10-05-2011, 04:31 PM   #2
Stinger
Senior Member
Stinger's Avatar
Default Re: Keeping a 950 sq ft attached garage ABOVE freezing?
I've found in my 700 sq ft garage, a very small electric heater that's only 1500w or so will keep my insulated garage over 55 degrees if left on high (outside temps down to 0F at night and 15F during the day) and will keep it at any temp below that with the thermostat.
I'm referring to something similar to this: http://www.amazon.com/Lasko-754200-C...7846487&sr=8-1
I'd think something like this would be more than enough to just keep yours above freezing: http://www.amazon.com/Lasko-758000-C...7846487&sr=8-5
Stinger is offline   Reply With Quote
Old 10-05-2011, 10:44 PM   #3
jlckmj
Senior Member
jlckmj's Avatar
I'm no expert, but I would imagine that if you were to install a good sized baseboard heater and a ceiling fan to keep the air distributed, you should have no problem keeping it above freezing, providing it is insulated well, and the doors is kept closed.
The real question is, how much will it cost you to do that?
Jim
jlckmj is offline   Reply With Quote
Old 10-05-2011, 11:10 PM   #4
Steevo
Senior Member
Steevo's Avatar
I put this in my 24x40x12ft ceiling shop, and left at 45 degrees, it costs about $12 a month for gas between Nov and March:
Steevo is offline   Reply With Quote
Old 10-05-2011, 11:24 PM   #5
dave67fd
Senior Member
dave67fd's Avatar
You didn't mention how long it takes to get to 55 with a 0F outside ambient. I am guessing pretty much all day.
You have several options but my own personal opinion is to heat with Propane or NG. Electric heaters have cheaper initial costs but are costly to run and will require a 240V/30 Amp circuit to run to make it worthwhile. Just the opposite with gas heaters. Radiant gas heaters are the most efficient and cheaper to run but have a high initial cost. Stay away from non-vented or contractor type torpedo heaters or similar as they introduce a high amount of water vapor and CO (carbon monoxide) so i would suggest a gas vented heater.
This is what i have and their on SALE.
http://www.northerntool.com/shop/too...6365_200316365
Steevo beat me to the punch...
__________________
Check out my Build at:
http://www.garagejournal.com/forum/s...d.php?t=102939
dave67fd is offline   Reply With Quote
Old 10-06-2011, 08:25 AM   #6
Thirsty
Senior Member
Thirsty's Avatar
Your attached garage shouldn't get much below freezing without heat. The coldest I have seen my attached garage get was 30 degrees and it was 20 below with even colder windchill. Most of the winter it is 35-40 degrees even warmer with the sun shining.
Thirsty is offline   Reply With Quote
Old 10-06-2011, 09:43 AM   #7
LB-1911
Senior Member
Get a 1500 watt oil filled heater- use the 600 watt setting on low & go from there.
Plan on an approx. $60.00 increase on your elec. bill.
Steevo & dave67fd are spot-on. If you have acess to NG it's the only way to go.
Follow the other Elec heat only thread as well.
LB-1911 is offline   Reply With Quote
Old 10-07-2011, 08:48 AM   #8
mpire
Senior Member
mpire's Avatar
Move to Florida.
mpire is offline   Reply With Quote
Old 10-10-2011, 08:10 AM   #9
chadman
Senior Member
chadman's Avatar
My attached 1000sf garage typically doesn't need any heat to stay above freezing. Before I got the floor heat hooked up I would just run a torpedo heater for long enough to get the entire garage up to 50-55 after I got home from work and then shut it off. It would hold enough heat until the next day. This was only necessary when the temps were in the single digits for a few days at a time. Even then it was only a cautionary measure. The lowest temp I actually observed was 36deg. The heat from the wall adjoining the house helps alot.
chadman is offline   Reply With Quote
Old 10-10-2011, 11:04 AM   #10
RKA
Senior Member
I use one of these on a 80 sq ft interior room of the house 12 hours a day to generate an 8 degree rise and it easily adds $30 to the monthly electric ($60 when i forget to shut it off overnight a few times a month). I would think the money you'd throw away in a single winter running one of these in your garage could be applied to something much more cost efficient.
RKA is offline   Reply With Quote
Old 10-10-2011, 11:23 AM   #11
Falcon67
Senior Member
Falcon67's Avatar
My 5000W G73 kept the old shop at around 55~60F with it set on real low.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
