Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 10-06-2011, 05:25 PM   #1
ixlr8
Senior Member
Default Square D breakers- Homeline vs QO
I am having the breaker panel replaced in my house, I have an old FP panel and I need to add some breakers and I figure it is time to replace the old fire hazard. I have decided to put in a Square D panel, I was going to go with a QO panel.. my electrician is recommending I install a Homeline panel to save myself some money. So I have these questions, with the exception of the QO's being narrower and having a trip indicator...
Is there any difference in level of protection between the Homeline and QO breakers? Is it really worth paying 2x for the QO line vs the Homeline?
TIA
__________________
Jim
Toys;
16 BMW X5 3.5i
15 GMC Sierra 2500
13 Kioti CK40 TLB
02 VW TDI Golf, 288,000 miles, 56 mpg
01 550
00 Toyota Solara
ixlr8 is offline   Reply With Quote
Old 10-06-2011, 05:31 PM   #2
Gooch
Senior Member
Send a message via AIM to Gooch Send a message via MSN to Gooch
Default Re: Square D breakers- Homeline vs QO
TIA
no reason not to go with the Homeline breakers, they are fine for residential use.
Gooch is offline   Reply With Quote
Old 10-06-2011, 05:31 PM   #3
Alchymist
Senior Member
Alchymist's Avatar
There's a reason for that price difference - the QO is a better quality panel.
The HO is an adequate panel, but I chose the QO. The HO panel has aluminum buss bars, the QO has tinned copper bars. One is considered commercial, and one is homeowner. For a onetime extra cost, I think it's worth the difference. YMMV.
Alchymist is offline   Reply With Quote
Old 10-06-2011, 05:33 PM   #4
Alchymist
Senior Member
Alchymist's Avatar
Then again, anything new is better than FP.....
Old 10-06-2011, 05:34 PM   #5
Gooch
Senior Member
neither one has copper buss. you would have to get into a QOB panel or a or a QO Panelboard instead of the Load Centers. none of which will be in a homeowners budget.
although SQD's website say they have tinned copper, pretty sure almost all of them i've installed were alum buss.
Old 10-06-2011, 05:50 PM   #6
Alchymist
Senior Member
Alchymist's Avatar
From Schnieder's website:
"The QO load center and circuit breaker family is designed to satisfy individual requirements with a comprehensive selection: Exclusive shielded copper bus features electro tin plated copper bus bars sandwiched between two rugged polymer shields to insulate and secure the interior".
It's here:
http://products.schneider-electric.u...-load-centers/
Guess I'll have to go check mine?
Old 10-06-2011, 05:59 PM   #7
MrMark
Senior Member
MrMark's Avatar
Are there any QO combination meter main/load center that you have seen?
MrMark is offline   Reply With Quote
Old 10-06-2011, 06:46 PM   #8
StumpjumperDave
Senior Member
StumpjumperDave's Avatar
I've been selling Square D equipment for 29 years.... I'd take a QO Loadcenter over the Homeline anyday.. You should never have to worry about it. I would recommend installing a Surge Protector in the new loadcenter... hopefully the others will agree with me on this..
__________________
Riding is Crashing... Crashing is Riding
StumpjumperDave is offline   Reply With Quote
Old 10-06-2011, 06:53 PM   #9
Norcal
Senior Member
Quote:
Just Homoline, the QO combos were dropped when the HOM frame breakers was introduced.
Norcal is offline   Reply With Quote
Old 10-06-2011, 07:25 PM   #10
cowboyjosh
Senior Member
QO is what I spec for my new builds, sometimes when the HO wants to save money we'll change to Homeline or Eaton BR, junk. For a one time expense, go wih the best.
cowboyjosh is offline   Reply With Quote
Old 10-06-2011, 07:43 PM   #11
Gooch
Senior Member
not used around here. Services here are a seperate meter box mounted outside the building, with the panel inside the dwelling.
Old 10-06-2011, 08:50 PM   #12
Norcal
Senior Member
Quote:
Then you would have to use a Cutler - Hammer "Classic" panel, QO panels for the last 25 years have been cheesy.
Old 10-12-2011, 09:10 PM   #13
6768rogues
Senior Member
I have two QO panels at home and a Homeline in a barn at my farm. Both work well and no problems with either one. Yea, the QO is an upgrade. A Cadillac is an upgrade over a Chevy, but both get you where you are going. Want to go in style?
__________________
Why a cool garage? Chicks dig 'em. Alcohol may intensify the effect. As John Belushi said in Animal House, "I suggest you drink and drink heavily."
6768rogues is offline   Reply With Quote
Old 10-13-2011, 06:33 AM   #14
climbabout
I have been in the electrical supply business since 1973. My family has owned the same supply house since 1936. We have been Square D distributors since the 1940's. While we are now a Square D premier distributor and only carry their load centers, we did carry Murray, Federal Pacific, Bryant, Challenger and Cutler Hammer years ago. While the Homeline is a fine breaker, the QO has the fastest trip mechanism of any breaker. Years ago we had a device designed to compare which breakers tripped the fastest. It tested all the major brands at the time, including GE and those mentioned above. It also pitted each breaker against a plug fuse. The plug fuse was always the fastest trip against any breaker mechanism due to it's simplicity. But hands down the QO tripped fastest among ALL of the circuit breakers EVERY time. QO, incidentally stands for "quick open" and it's not just advertising hype. Anyone who has handled hot wires and accidentally shorted a circuit and not had the breaker trip instantly as is typical with most brands know what I am talking about. So why skimp on a device that is designed to protect your life? I find it amusing that customers who have just spent tens of thousands of dollars on granite countertops, expensive cabinets, and other items for their remodel or building project will complain about the cost of a smoke alarm or circuit breaker.
Tim
climbabout is offline   Reply With Quote
Old 11-06-2011, 07:41 PM   #15
raley
ixlr8. sorry I don't have anything to add to this thread. Just curious what steps it takes to replace a panel? Im guessing talk to the power company, have them turn off the power at the pole, then you can replace, then get it turned back on?
raley is offline   Reply With Quote
Old 11-06-2011, 08:34 PM   #16
ishiboo
Senior Member
Quote:
Basically, yeah. In most areas they actually disconnect the power at the pole.
Around here, the power company requires an inspection for most things before turning the power back on. My exterior service just failed and I had to replace it, in doing so I added a 100A outdoor breaker directly off the meter. Now, when I have to replace my panels in the house (which is on the to-do list) I can disconnect it outside.
I have a lock on both the main breaker (QO) and the enclosure, to be extra sure nobody turns it back on while I'm working (Or the house off while I'm not!)
ishiboo is offline   Reply With Quote
Old 11-06-2011, 08:53 PM   #17
ishiboo
Senior Member
Quote:
Tim
I believe the "quick open" feature is only on 15 and 20A breakers, and I don't believe that QO stands for quick open, though it may.
I'm surprised you are not aware that the Homeline and QO breakers are one and the same, at least for recent times. They will have the same trip curves and performance characteristics. I believe that they used to be different, as I used to have better luck with the QO breakers. I've had many CH and Homeline breakers fail over the years, not particularly frequently, but it has happened. Only one QO failure, and most of my panels are QO.
Both QO, Homeline and CH are great products IMO. I prefer the QO, and then the Homeline due to the layout and features of each.
Old 11-06-2011, 10:17 PM   #18
79firebird
Senior Member
dont go Homeline my old panle was that had 2 15 amp brakers melt into it. my buddy who has been doing wireing for years has relaced more Homeline ones then fp due to probs
79firebird is offline   Reply With Quote
Old 11-07-2011, 05:31 AM   #19
Gooch
Senior Member
Quote:
nope
Old 11-07-2011, 08:34 AM   #20
TWX
Senior Member
TWX's Avatar
I like the QO breakers because I find them in every store that carries any kind of circuit breaker. On top of that, if you need something odd, like a 50A single-pole breaker you can find it.
Even though the QO breakers are narrower, they do make tandem breakers for them, if that's a concern.
TWX is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
