Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 10-07-2011, 06:31 PM   #1
ajchien
Senior Member
ajchien's Avatar
Default Sharpening tin snips
I've got a pair of vintage tin snips that dont cut nearly as well as I'd like them to. How do you guys go about sharpening them?
ajchien is online now   Reply With Quote
Old 10-07-2011, 07:09 PM   #2
mdbeck1
Senior Member
mdbeck1's Avatar
Default Re: Sharpening tin snips
Quote:
Get an old Coca Cola bottle. Use the tin snips to try to "cut" the nick off of it. It sounds goofy but it works.
It also works on SWMBFAO's scissors.
mdbeck1 is offline   Reply With Quote
Old 10-07-2011, 07:24 PM   #3
littletoes
Senior Member
littletoes's Avatar
Drawfiling is how there were intended to be sharpened.
That is, you clamp them in a vise, and pull a file across it edge-ways. I think if you do a "search" on the net, you might find a pic or two.
Its how I was taught.
littletoes is offline   Reply With Quote
Old 10-07-2011, 08:38 PM   #4
Fordman7795
Senior Member
Fordman7795's Avatar
If used correctly you should never have to sharpen snips. More than likely they just need to be adjusted. PM me if youd like to know the proper way to adjust them
__________________
Please do not delete the sale price for an item once you sell it. Helps for people researching prices on stuff.
My Feedback
My eBay stuff for sale
My Paypal address is:
Fordman7795 at yahoo.com
Fordman7795 is offline   Reply With Quote
Old 10-07-2011, 11:44 PM   #5
AmickRacing
Senior Member
The larger pattern snip style aren't too bad to sharpen and adjust. Once you do that it's amazing how dull they really were.
I wish there was a way to sharpen (and have them work properly) offset snips tho. Or is there a way that I've missed?
AmickRacing is offline   Reply With Quote
Old 10-07-2011, 11:55 PM   #6
Provincial
Senior Member
Provincial's Avatar
Quote:
I have a pair of Wiss aviation snips that I bought at Boeing Surplus 30 years ago. They obviously were resharpened numerous times because there is so little metal left. The metal removed was at the faces that slide together as they operate, not the "top" of the jaws. The finish of the resurfaced area looks like a cup wheel was used for the process. It would take a special fixture to hold the jaws for this, and the tool would have to be completely disassembled.
Provincial is offline   Reply With Quote
Old 10-08-2011, 12:11 AM   #7
waltmcq
Senior Member
Quote:
could you give me some info. It's hard to imagine something that cuts will never get dull.
but I don't really know much
__________________
it seemed like a good idea at the time
waltmcq is offline   Reply With Quote
Old 10-08-2011, 12:15 AM   #8
mkat1951
I work with tin snips on a daily basis and I find more often than not it's the adjustment of the blades (how close the blades are to each other) that lead to poor cuts. What I usually do is adjust them and then tack the nut to the bolt to keep them from coming loose again, I find that once they've been readjusted they seem to come loose quite easily. Not that this has anything to do with fixing your old snips, but whenever I buy a pair of new snips I always take along a piece of metal to test them out, you'd be surprised at how many pairs are not right from the factory.
mkat1951 is offline   Reply With Quote
Old 10-08-2011, 07:31 AM   #9
Lomotil
Senior Member
Lomotil's Avatar
On a slightly related note, I've got a vintage pair of Wiss with a broken spring... Is this something that is warrantied?
__________________
ส็็็็็็็็็็็็็็็็็็็็็็็็็ Cross the line...
Quote:
Originally Posted by grizzlyToolz
call me what ever you like. if i get offended then i shouldn't be online
Lomotil is offline   Reply With Quote
Old 10-08-2011, 07:56 AM   #10
metaldad
Senior Member
metaldad's Avatar
g'morning amick!
i see your here also.
metaldad is offline   Reply With Quote
Old 10-08-2011, 11:44 AM   #11
AmickRacing
Senior Member
Quote:
Originally Posted by metaldad View Post
g'morning amick!
My addictions are quite consuming lol
Old 10-08-2011, 11:56 AM   #12
Jack Olsen
Jack Olsen's Avatar
Could someone post the correct way to adjust them?
Jack Olsen is offline   Reply With Quote
Old 10-08-2011, 12:03 PM   #13
mkat1951
The way I usually adjust my aviation snips is just by testing them on a piece of metal. You should be able to cut very thin pieces off the edge without it binding or folding over the metal, trial and error I guess. Maybe there might be a better way but this always works for me. Pattern snips I usually just try and get them close with out binding.
Old 10-08-2011, 12:26 PM   #14
Fordman7795
Senior Member
The way to adjust them is to close them and latch em shut. Then tighten the bolt between the blades. After its tight enough to where they dont open, open the latch and SLOWLY loosen the bolt until they pop open. At that point the blades are as close as possible without catching and will cut the best.
__________________
My Feedback
Old 10-08-2011, 01:04 PM   #15
mrbreezeet1
Location: Moundsville, WV, 15 miles South Of Wheeling WV
Sounds like your talking about aviation snips then, right?
I pictured the bigger ones from the OP, ones more like Scissors but with short blades?
Good to know though, I will have to try that.
mrbreezeet1 is offline   Reply With Quote
Old 10-08-2011, 01:20 PM   #16
AZ_Catskinner
Senior Member
AZ_Catskinner's Avatar
An old machinist taught me to hit the cutting surfaces with an India stone from time to time. They do tend to get some asperities on the blades with time, and knocking them off will improve performance.
AZ_Catskinner is offline   Reply With Quote
Old 10-08-2011, 01:28 PM   #17
jjjrmx5
Senior Member
I figured the OP was talking aviation tin snips, as the scissors type tools I normally call shears. For shears, the Craftsman shears I have have full replacable blades that bolt in. For my Wiss V10 shears like these:
http://www.hardwareandtools.com/Apex...s-6898423.html
I just send them out to my local scissors and knife shop to get sharpened.
I am interested in this thread as i have a 15 yo pair of Craftsman aviation snip that have a few slight gouges/dings in the blade edge likely from the previous owners misuse that i would love to figure out how to get out and get he blade edge smooth again.
__________________
"The best part about drinking boxed wine is you can blow up the bag and use it as a pillow at the end of the night..." LOL
jjjrmx5 is offline   Reply With Quote
Old 10-08-2011, 01:42 PM   #18
mrbreezeet1
Quote:
I bet you could carefully file them with a fine single cut mill file.
Old 10-08-2011, 01:48 PM   #19
toolmaker1
Senior Member
toolmaker1's Avatar
Quote:
Bingo! this works very well with a coarse india stone
toolmaker1 is offline   Reply With Quote
Old 10-08-2011, 11:55 PM   #20
ajchien
Senior Member
ajchien's Avatar
Sorry for the confusion, the snips/shears I am talking about look like this (not mine, just copied from eBay)
http://www.ebay.com/itm/P-C-1322-12-...5#ht_500wt_823
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
