Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Search this Thread Display Modes
Old 10-18-2011, 09:28 PM   #1
41ratrod
Senior Member
41ratrod's Avatar
Default 1999 KIA SPORTAGE won't start.
My daughter has a 99 Kia and the check engine came on , but it was running
fine no miss or rough idle. So this morning .
6:30 AM after my wife left for work I drove it into the garage it started right up
and ran fine. I when back to bed.
8:30 Started it back up ran OK light was still on , so turned it off and pulled
cable off the battery to see if the light would come back on.
Now no start. Check the fuel pump and its running ,has new filter less then 6 months old.
2.0 DOHC
Has new timing belt.
new plugs and wires. All with less then a 1000 miles.
Since I pulled the battery cable the code reader shows no code.
It does crank over.
Where should I start next?
41ratrod is offline   Reply With Quote
Old 10-18-2011, 09:30 PM   #2
Garage5.9
Senior Member
Garage5.9's Avatar
Default Re: 1999 KIA SPORTAGE won't start.
The basics is where i would start , fuel pressure , spark and compression. IF its not something obvious like a loose battery connection , starter etc
Garage5.9 is offline   Reply With Quote
Old 10-18-2011, 09:34 PM   #3
Garage5.9
Senior Member
Garage5.9's Avatar
oh yeah forgot to ask does it crank ?
Old 10-18-2011, 09:45 PM   #4
MechanicNamedJohn
Senior Member
MechanicNamedJohn's Avatar
Its most likely the crank position sensor, its a Hyundai, the CPS fails often.
__________________
MechanicNamedJohn is offline   Reply With Quote
Old 10-19-2011, 05:31 AM   #5
Drew_flux
Senior Member
what indicator lights are displayed on combination meter with ignition on ? e.g. engine light,brake light. i wonder if you are having an immobilizer issue. also the AL sportage is the only car i have ever seen NOT START from a faulty/unpluged o2 sensor.
Drew_flux is offline   Reply With Quote
Old 10-19-2011, 06:38 AM   #6
mrholeshot
Senior Member
mrholeshot's Avatar
Check under the bed to see if her boyfriend is hiding under there. masters of sabotage. lol
__________________
Try to be the person your dog thinks you are.
mrholeshot is offline   Reply With Quote
Old 10-19-2011, 06:50 AM   #7
41ratrod
Senior Member
41ratrod's Avatar
Quote:
It does cranks over and all normal lights are on when you turn the key on.
Old 10-19-2011, 06:56 AM   #8
41ratrod
Senior Member
41ratrod's Avatar
Quote:
Not a good place to hide a boyfriend she'd have to do some cleaning under it you may say its her SPORTAGE area.ha ha
Old 10-19-2011, 07:01 AM   #9
Joelfke
Senior Member
Joelfke's Avatar
Send a message via AIM to Joelfke Send a message via Yahoo to Joelfke
Quote:
x2 on this. worked for a hyundai dealer. we do those crank sensors alllllll the time. if youre lucky its on the radiator side of the block. not sure what motor is in it. if youre unlucky its behind the timing belt
__________________
"The bolt doesn't really care who made your wrench, its going to be a stubborn prick reguardless"
Quote:
Originally Posted by Merkava_4 View Post
Sears = [fill in the blank] problem. :lol:
Joelfke is offline   Reply With Quote
Old 10-19-2011, 07:35 AM   #10
41ratrod
Senior Member
41ratrod's Avatar
Quote:
2.0 DOHC I hope its not behind any covers .
Old 10-19-2011, 08:06 PM   #11
41ratrod
Senior Member
41ratrod's Avatar
Quote:
found the problem had a bad connection in the wiring .
Old 10-19-2011, 08:17 PM   #12
Original Man
Senior Member
Where?
Original Man is offline   Reply With Quote
Old 10-19-2011, 09:04 PM   #13
41ratrod
Senior Member
41ratrod's Avatar
Quote:
Originally Posted by Original Man View Post
Where?
Under the intake and above the starter there is four sets of wires w/connector
( the one on top on ours) had a bad connect .so cleaned it with contact cleaner. well get back into it this weekend and put some elect' type grease
had to remove the battery to get to them.
someone on the Kia Forum said to check this,had the same problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
