Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#21 |
Senior Member
Did you special request yellow accents or is that they way the come now?
#22 |
Senior Member
I think thats how they come now.. I've seen more than a couple of them with the yellow ramps and such lately
#23 | |
Senior Member
Quote:
#24 |
Very nice write up. I could have really used it a couple of months ago when I installed mine! I purchased a used HD-9ST from a private owner. Went with a friend to take it down from the seller's garage and then installed it by myself in my garage. I love it; although, I would also go with the wider HD-9 as well if I was buying it new now. My 928 is a tight fit, and my Esprit may be too tight.
![]() -Gary Last edited by lotus_guy01; 10-26-2011 at 08:53 PM. |
#25 | |
Senior Member
Quote:
#26 |
Senior Member
Bridge Jack
In addition to the 4 post lift itself I also have the RJ-45 rolling bridge jack. The idea of not being able to do suspension and brake work on the lift limits the use for me since I do a fair amount of work like that. This should really make the task of getting the car up of the lift easy, but then use the lift to raise the work level. Needless to say I won't be working on a vette in the up position while the other one sits underneath!!!! Dropped wrenches would be a bit costly! Good to have the engine hoist to help with the placement into the lift. With the runways in the narrow position the jack drops right in without extending its reach. In place and added the drip trays, how dare I insinuate that the vette could have a leak! ![]() I was concerned about the height of this jack but all looks good, you can see that even with my C4 corvette the rolling jack will move under the car. The C5 vette is lowered and that might be a bit close, at least the plastic air dam piece may get moved as I pul the jack through. I don't have any shots of the jack in use yet as it has not made it's maiden voyage. For now I think I'll just run a airline to the jack as needed, but I can see the idea of the air line kit that Bendpak offers as an upgrade would be a nice clean installation. I may have to consider that as an upgrade in the future. More To Come.... |
#27 | |
Quote:
-Gary |
#28 | |
Senior Member
Quote:
I've bought drop-n anchors for mine (don't want to use the included wedge anchors) but haven't got around to installing them yet. ![]() I have the rolling jack as well- modified by BendPak to sit lower. I just put it on a furniture dolley, raised lift up & rolled it underneath. Dropped lift, rotated the jack 90 degrees, raised lift back up & voila- done. Last edited by Steves32; 10-27-2011 at 09:33 PM. |
#29 |
Senior Member
Nice lift and nice write up. Thanks.
#30 |
Senior Member
Good write up and "how to" thread.
I wish I'd seen it about 4 months ago before I set up my HD9ST.
__________________
Andrew "Whether you think you can, or you think you can't, you're right."— Henry Ford My Garage Build |
#31 |
Senior Member
Upgrade to aluminum ramps
Well after lugging the standard ramps on and off a few times I figured it made sense to go with the lighter aluminum ramps. For me I want to take the ramps off once putting a car up for storage and the ramps are right at the height that as I move around working in the garage I could do some real damage running into them. Also, as the hang down about 6" from level once the lift is raised without the lock in place pieces, I need that extra room to drive the cars under. So the upgrade was simple. but it does require the installation of ramp brackets that use longer bolts at the end of the runways. Pretty simple but the biggest issue in this for me is getting those holes to line up. What I recommend is to do this one bolt at a time to help keep things aligned. Also the trick I used of the pipe clamp helped out again to keep the runway right in place while I installed the bracket. Once it is all installed the ramps just slide down onto the brackets, they too will drop at an angle if left on the lift when lifted, but they are so light it is easy to pull them off and store out of the way. One thing to consider is these ramps attach right at the end of the lift and will make the overall length a bit longer, maybe about 4" or so. You need to factor that into your lift placement. I just got lucky!!!! Look how close to the garage door it is! The one idea I would have for BendPak is to add welded on brackets on the back side of 2 posts that would allow you to store the ramps in a vertical hanging position, then they would be out of the way but have a spot right where you need them. More to come... |
#32 | |
Senior Member
Quote:
#33 |
Senior Member
Nice, the crane matches the lift.
![]() Really nice write up and photos. Thank you!
__________________
Less QQ, more pew pew. |
#34 | |
Senior Member
Quote:
I'll give that a try in the next couple days and let you know. I had two wheel stops included in the package. |
#35 | |
Senior Member
Quote:
![]() Look in this shot it includes my electric impact gun!!!! Blue and Yellow and actually the same goodyear brand as the crane. To be fair the crane was borrowed from a buddy, but I noticed the color coordination as well. |
#36 |
Senior Member
The ramps being in the way are a big issue for me, so I made my own flip ups for about $300.00. No problem now.
#37 |
Senior Member
c39er, Well done! Those look great.
#38 | |
Senior Member
Quote:
#39 |
Senior Member
#40 |
Senior Member
OK, well I worked with the Bendpak team on the bridge jack, got a different set of runners that will drop the unit down lower, to make it better for the corvettes and other low cars.
The change was real easy, I just dropped the lift with jackstands under the bridge jack and replace the two end pieces Bendpak sent me. Maybe a 15 minute job tops! Now the bridge jack sits nice and low, not going to hit it even with these low cars. ![]() And then I hooked up the airline to give the unit a test. ![]() More to Come....... |
| Thread Tools | |
| Display Modes | |
