Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 10-21-2007, 10:08 PM   #1
M3Pilot
Senior Member
Default "Hydraulic Oil" for floor jack
My old,offbrand,floor jack doesn't work as well as it did. Sticker on it says use hydraulic oil to refill. Looked around at NAPA for such & didn't see any. I don't want to buy a gallon either. Would power steering fluid or brake fluid work?
M3Pilot is offline   Reply With Quote
Old 10-21-2007, 10:26 PM   #2
Uncle Buck
Default Re: "Hydraulic Oil" for floor jack
Quote:
Do no do the " Use anything slick method" I am sure many grades of hydraulic fluid will work just fine however I always use the fluid labeled for use in hydraulic jacks, it says jack oil right on the label. Usually you can buy it a qt or less at a time at most auto parts stores.
Uncle Buck is offline   Reply With Quote
Old 10-21-2007, 10:29 PM   #3
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Yea, PepBoys has jack oil in small containers in their lubricant's aisle
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 10-21-2007, 10:50 PM   #4
ImportTuner
Moderator
ImportTuner's Avatar
Sears and Orchard Supply Hardware also have small containers ...
ImportTuner is offline   Reply With Quote
Old 10-22-2007, 04:33 AM   #5
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Do not use brake fluid, it will destroy the seals in the jack, very quickly.
As noted, jack oil from an auto parts place, or Mobil DTE 24 from Grainger, used in hydraulic presses, jacks, etc.
Charles
Charles (in GA) is offline   Reply With Quote
Old 10-22-2007, 05:31 AM   #6
eschoendorff
Director of Bands
eschoendorff's Avatar
Dude, you can find hydraulic jack oil in just about any auto parts or tool store. I think even Harbor Freight has some.... or maybe go to TSC. But foor the minimal cost of the stuff, I would use the proper fluid...
__________________
When you die, I want your tools.
Quote:
Originally Posted by Moose-LandTran View Post
Why bother? Natural selection will take care of them. If it doesn't, a 12-gauge can take care of the unnatural selection...
eschoendorff is offline   Reply With Quote
Old 10-22-2007, 09:44 AM   #7
jimvannoy
Senior Member
Use hydraulic jack oil. You can get it at any parts store.
jimvannoy is offline   Reply With Quote
Old 10-22-2007, 11:12 AM   #8
russlaferrera
Senior Member
ASK the counter person!
russlaferrera is offline   Reply With Quote
Old 10-22-2007, 05:47 PM   #9
M3Pilot
Senior Member
I will ask the counter person. I was in a rush to get somewhere else when I went in & getting the oil wasn't an urgent need. Thanks for the good advice y'all.
Old 10-22-2007, 05:53 PM   #10
chad s
Senior Member
chad s's Avatar
Its funny how many people will respond with the same exact answer!
chad s is offline   Reply With Quote
Old 10-22-2007, 07:53 PM   #11
Uncle Buck
Quote:
When it's a slam dunk with only one answer that is quite predictable!
Old 10-27-2007, 08:52 PM   #12
Krawlin98ZJ
Check Aisle 4 of your nearest Autozone it should be on the bottom shelf. Now you dont have to ask the counter person.
Krawlin98ZJ is offline   Reply With Quote
Old 10-27-2007, 09:40 PM   #13
Danglerb
Senior Member
Danglerb's Avatar
Quote:
Make sure you get the right one, not the Manny or Moe oil.
__________________
If you only get what you pay for, how do you explain Santa?
Danglerb is offline   Reply With Quote
Old 10-28-2007, 11:21 AM   #14
george4
Senior Member
I topped off two jacks with power steering fluid a couple of years ago, no problems yet, is it worth changing at this point? How long till I die?
george4 is online now   Reply With Quote
Old 10-28-2007, 10:20 PM   #15
Uncle Buck
Quote:
If you are concerned swipe your wifes turkey baster and suck most of the fluid out and replace it with jack oil.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
