Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-16-2005, 06:15 PM   #1
slapshot
Boat Cop
slapshot's Avatar
Default power tool to remove stucco
OK tool gurus.......need some info.
I need a POWER tool to chip some thin stucco of a concrete block wall. I've been doing it with hammer and heavy duty scraper, and that isn't cutting it.
I remember back in my Coast Guard days, the boat guys had some type of grinder/chisel type thing they used to remove corrosion from the boat hulls.
My friend has a grinder, so that would be an option to get the heavy stuff off anyway.
I'm looking for something I can rent....
thanks!!!
__________________
1991 Corvette Coupe, 6 spd, 38k miles
2002 HD V-Rod
2004 Chevy Avalanche Z66
slapshot is offline   Reply With Quote
Old 08-16-2005, 06:58 PM   #2
reklund5
Certified Garage Junkie
Default
air hammer with a wide bladed chisel. I even welded a piece of 1/4" to a standard air hammer chisel to widen it to about 6". You can go wider but it depends on how well the stucco is stuck to the wall.
Ryan
reklund5 is offline   Reply With Quote
Old 08-16-2005, 07:11 PM   #3
slapshot
Boat Cop
slapshot's Avatar
Default
I considered that. I already tried a hammer drill with a chisel type bit. The stucco is very thin and it is hard to even get the thin blade of the paint scraper underneath.
__________________
2002 HD V-Rod
Old 08-16-2005, 10:18 PM   #4
rsitzejr
Garageaholic
Default
New here, what about a needle gun? Like we used to chip rust off with in the Navy.
http://www.northerntool.com/webapp/w...=12817&R=12817
rsitzejr is offline   Reply With Quote
Old 08-16-2005, 11:03 PM   #5
Cebby
Senior Member
Cebby's Avatar
Send a message via AIM to Cebby
Default
What about this thing? I think it has a carbide wheel on it.
http://www.amazon.com/exec/obidos/tg...73618?v=glance
Cebby is offline   Reply With Quote
Old 08-17-2005, 04:33 AM   #6
Luckydevil
Senior Member
Luckydevil's Avatar
Default
Quote:
Ah yes, I spent many a days needle gunning and painting the hull on the USCGC Chase. That damn boat had more rust than metal.
I remember using two different things to remove paint and non-skid. The needle gun and the pneumatic air chisel. That air chisel may be a bit much for what you are doing though. I say give the needle gun a shot.
__________________
- Luke
Luckydevil is offline   Reply With Quote
Old 08-17-2005, 10:26 AM   #7
SteveL
Senior Member
SteveL's Avatar
Default
You could use a air scraper like the one on sale at Harbor Freight. Here's a link that shows the sale price
SteveL is offline   Reply With Quote
Old 08-17-2005, 07:39 PM   #8
slapshot
Boat Cop
slapshot's Avatar
Default
YESSSSSSS......the needle gun is what I was thinking of. I will check the local tool rental places to see if they have them.
This chippin stucco by hands sucks...1 little piece at a time. Some sections come off easily, most do not.
__________________
2002 HD V-Rod
Old 08-17-2005, 08:18 PM   #9
red caddy
red caddy's Avatar
Default stucco stripper
Have you tried a commercial grade pressure washer? My 4200 psi washer with a turbo nozzle peeled a small block house (850 sq.ft.) in just a little under 10 hours. Hint, if you lay down some bird netting or nylon roll screen, the cleanup is much easier, and EPA required in some places. RED caddy
red caddy is offline   Reply With Quote
Old 11-07-2009, 03:08 PM   #10
stockups
Junior Member
Default Re: power tool to remove stucco
Red do u think i can get away and use a 3200 psi power washer
Thanks
stockups is offline   Reply With Quote
Old 11-07-2009, 03:50 PM   #11
mrshaun
Senior Member
mrshaun's Avatar
needle scaler same as needle gun?
mrshaun is offline   Reply With Quote
Old 11-08-2009, 11:51 AM   #12
Iron-Iceberg
Senior Member
Iron-Iceberg's Avatar
How about a multi tool they have a scraper blade. And the one at harbor freight is only about $60
Iron-Iceberg is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tool Manufacturers kartracer55 General Tool Discussion 316 11-16-2014 10:28 PM
Post a picture of your power tool room dink General Tool Discussion 8 02-20-2006 09:15 AM
Tool Descriptions JohnHenrys48 General Tool Discussion 2 12-05-2005 08:28 AM
Advice on hand and power tool storage dink General Tool Discussion 4 09-25-2005 08:25 PM
Power tool storage in garage or shed dink General Garage Discussion 11 09-19-2005 11:18 PM
