Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-27-2007, 06:53 PM   #1
trovato
Senior Member
Default How does an Air/Hydraulic Jack work?
OK, well, my question in the other thread seems to have been lost in the shuffle, so I'm asking it in its very own!
OK, so while we're on this subject... using hyjacks.com as an example:
71245A List Price 551.79 Their price 386.26 shipping wt 120lbs.
71230A List Price 278.97 Their price 195.28 shipping wt 97lbs.
info pretty clearly says that the 71245 is a 71230 with the air capability.
So, my question is, what is really different about it? There's 23 lbs of something added, and it costs $190.98 to add it. I feel like it should take maybe $20 worth of hose and fittings plus maybe a few bucks for some different seals or something. How does the air part work and why does it cost so much?
trovato is offline   Reply With Quote
Old 10-27-2007, 07:29 PM   #2
epmills
Senior Member
epmills's Avatar
Default Re: How does an Air/Hydraulic Jack work?
The air/hyd unit you are looking at uses shop air to raise -in otherwords you dont pump the handle up and down to raise a vehicle, the air pressure does that for you by pressing a button. The 71230 is simple you're everyday floor jack like you find everywhere- you pump the handle to raise the vehicle.
epmills is offline   Reply With Quote
Old 10-27-2007, 08:05 PM   #3
trovato
Senior Member
Yeah, I know what it is. My question is what is different in it makes it cost and weigh so much more.
Old 10-27-2007, 11:36 PM   #4
FireZapper
There will be an air piston, hoses and valves to operate the air/hyd one. That accounts for the weight and the price is also for the above.
Normally you "pump" the handle to operate. The air/hyd uses the air piston to do that. All you do is pull the trigger.
FireZapper is offline   Reply With Quote
Old 10-27-2007, 11:43 PM   #5
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Large air piston connected to small hydraulic piston, a pilot valve, seals, internal check valves, pretty complex item.
Charles
Charles (in GA) is offline   Reply With Quote
Old 10-27-2007, 11:54 PM   #6
trovato
Senior Member
So there's a separate air piston. For some reason, I was thinking that a single cylinder was able to be operated by either air or fluid. Makes sense. Thanks.
Old 10-29-2007, 05:04 PM   #7
malibu101
Senior Member
malibu101's Avatar
Go here http://www.norcoind.com/norco/downloads/exploded/
then go down 11 lines and click on the .PDF for 71245A
It is an exploded parts diagram.
it shows the additional parts.
malibu101 is online now   Reply With Quote
Old 10-30-2007, 11:02 AM   #8
trovato
Senior Member
You know, I did a ton of web searches and never found the manufacturer web site. I guess I always searched for more than just "norco". Anyway, many thanks. That certainly clears it up.
Old 10-30-2007, 11:58 AM   #9
malibu101
Senior Member
malibu101's Avatar
Quote:
I have researched this subject for a long time. Used has got me nowhere. I'm now soon ready to buy new!
Old 10-30-2007, 12:21 PM   #10
malibu101
Senior Member
malibu101's Avatar
Have you seen the Omega with the "Air TurboMotor "?
http://www.toolking.com/omegaliftequipment_21032.aspx
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
